| alexanderdipl... |
 alexanderdipl... L Plate Warrior
 Posted: 19:42 - 23 Jan 2013 Post subject: Honda CG125 BRK Points & Stator... whoops! |
I have a '94 CG125. I recently took the flywheel off because of problems and created more problems.
Once I had changed the points I refitted the flywheel and kicked the engine over.
No spark!?
I took the flywheel back off and found that I hadn't tucked the wires up and one has been torn out!
Can anyone tell me where the black/white wire from the terminal on the points should go? One goes back to the loom but I have no idea of the second?!
I have checked the Haynes and looked at more images on Google that anyone can imagine!!! ____________________ '94 CG125 BR-K |
| ricklincs45 |
 ricklincs45 Nitrous Nuisance
 Posted: 21:07 - 23 Jan 2013 Post subject: |
It eventually finds its way to the ignition coil
Will explain why you've got no spark  ____________________ Author '80 Bikes, and counting...' Currently getting frustrated with an MZ 125 TS. |
| mudcow007 |
 mudcow007 World Chat Champion
| alexanderdipl... |
| Cyclingbiker |
 Cyclingbiker Spanner Monkey
| alexanderdipl... |
 Posted: 21:41 - 23 Jan 2013 Post subject: |
Shazbatt! Coil end I'm afraid!!!
Hit me with it doctor... How bad?!
Are stators easy to get hold of?
Sorry to keep asking questions, I'm at the end of my tether!?  ____________________ '94 CG125 BR-K |
| Cyclingbiker |
 Posted: 21:57 - 23 Jan 2013 Post subject: |
If you can get the points off and fit a soldering iron in there you should be able to solder it back on, that assuming there is a length of wire protruding from the coil to solder on to. If your next option is to get a new plate than there is no harm in trying to repair what you have.
Stators should be easy to obtain. I had to buy a new one just before Christmas as mine burnt out and wouldn't power the lights any more. I got mine from a chap on Gumtree who was breaking a CG125 engine and had the stator available. I would assume that you'd have luck with checking regularly for bikes that are being broken for spares.
At the moment though there is only one stator on eBay, and that is at £55. I paid £35 for mine though so that should give you an idea of how much they sell for.
https://www.ebay.co.uk/itm/HONDA-CG-125-GENERATOR-STATOR-WINDINGS-/370733406284?pt=UK_Motorcycle_Parts&hash=item56516ed84c
Other than that you can always get the stator rewound by a specialist but I have no idea of what they charge so you'd have to ask them.
https://www.westcountrywindings.co.uk/applications.htm ____________________ Honda CB500s (1999) - Honda CG 125 BR-J (1991)
Mod 1 - Passed - 12/11/12 --- Mod 2 - Passed - 26/11/12 |
| mudcow007 |
 Posted: 22:00 - 23 Jan 2013 Post subject: |
| Cyclingbiker |
 Posted: 22:04 - 23 Jan 2013 Post subject: |
I believe that one is incompatible with the OP's bike. The one you've linked to is for the 6v, pre-1985 models and the OP has a Brazil 12v model. I don't think they ever made a pattern BR stator unfortunately  ____________________ Honda CB500s (1999) - Honda CG 125 BR-J (1991)
| mudcow007 |
 Posted: 22:07 - 23 Jan 2013 Post subject: |
| Cyclingbiker wrote: |
I believe that one is incompatible with the OP's bike. The one you've linked to is for the 6v, pre-1985 models and the OP has a Brazil 12v model. I don't think they ever made a pattern BR stator unfortunately  |
ahh rats!
no worries OP please ignore my linkage! |
| alexanderdipl... |
 Posted: 22:22 - 23 Jan 2013 Post subject: |
Thanks guys. You've been a great help, i may even get a little sleep tonight?!
Will be cruising for a new stator me thinks....
Though £55 on the bay seems a little steep, maybe, maybe not!?
Will have to see what comes up!
This has been bugging the sh*t out me since my bike died 2 weeks ago! I don't even know if this is the initial cause of the bike dying in the first place! But I guess I need to get this rectified before I can continue on further....
Thanks again  ____________________ '94 CG125 BR-K |
| ricklincs45 |
| alexanderdipl... |
 Posted: 18:15 - 24 Jan 2013 Post subject: |
Okay here's an update:
PLAN A
I had another look at the Stator plate, the wire must have broken from the centre of the coil as I couldn't see a broken strand protruding...
I removed the plate and found it has a crack through it! (Probably from being levered against to remove the flywheel)
I then removed the coil and examined... It looks sealed in that sh*tty resin! I then removed the second coil, dropped it, snapped a second wire and lost my rag with it!!!
PLAN B
I phoned every breaker on the first two pages of Google and every reaction was the same...
Me: "Hi, I'm looking for a stator plate for a Honda CG125!?"
Breaker: "Sure, what year is the bike?"
Me: "It's a '94 Brazil model"
Breaker: "With points.... Then no! Good luck with that!"
Me: "FICK!"
So I bit the bullet and bought the expensive one from the Bay! Let's hope I don't regret it!  ____________________ '94 CG125 BR-K |
| Cyclingbiker |
 Posted: 20:23 - 29 Jan 2013 Post subject: |
| alexanderdiplock wrote: | Okay here's an update:
PLAN A
PLAN B
Me: "FICK!"
So I bit the bullet and bought the expensive one from the Bay!  Let's hope I don't regret it!  |
How are you getting on?
BTW don't lever against the stator to get the flywheel off. Use a proper puller that thread into the flywheel itself and has a threaded rod to push against the shaft to pull the rotor off cleanly
https://www.ebay.co.uk/itm/27mm-Diameter-Magneto-Flywheel-Puller-New-/281014545104?pt=LH_DefaultDomain_3&hash=item416dc5aad0 ____________________ Honda CB500s (1999) - Honda CG 125 BR-J (1991)
| N cee thirty |
 N cee thirty Banned
| alexanderdipl... |
 Posted: 21:05 - 29 Jan 2013 Post subject: |
Update...
Put the stater plate on, replaced the flywheel, set the points gap and...
BINGO! We're back in business!
Celebrated by buying a new chain & sprockets!  ____________________ '94 CG125 BR-K |
| Cyclingbiker |
 Posted: 21:18 - 29 Jan 2013 Post subject: |
Good, glad to hear you got it sorted
Strangely I also have a new chain and sprocket set on the way, weird...  ____________________ Honda CB500s (1999) - Honda CG 125 BR-J (1991)
| ricklincs45 |
 Posted: 07:27 - 30 Jan 2013 Post subject: |
The last post was made 13 years, 14 days ago. Instead of replying here, would creating a new thread be more useful? |
