is a bandit 1250 to big for first bike?
saint gaz
PostPosted: 21:26 - 23 Jan 2013    Post subject: is a bandit 1250 to big for first bike? Reply with quote
I have seen a couple of nice bikes lately that have caught me eye, one being a 09 bandit 1250sa for around 3k, not that I intend paying that for it.
Is it to much for a first bike? and what are the things i should lookout for as potential problems.
Mid life crisis has started,
Let the fun begin.
Honda VTR 1000 Firestorm
Snorty
PostPosted: 21:27 - 23 Jan 2013    Post subject: Reply with quote
Personally I don't think it is too big. It may be a 1250 but it's not quite as powerful as a CBR600RR. Just has more torque so you'll feel it as soon as you twist the throttle.
It will be noticeably heavier than a YBR 125 though.
Slacker24seve...
PostPosted: 21:32 - 23 Jan 2013    Post subject: Reply with quote
They are, however physically big and really very lardy.
OP - I'm guessing you're rapidly approaching middle age and therefore have a modicum of self restraint - have you got any other bikes in mind?
The best thing you can do really is to draw up a shortlist of others that take your fancy and test ride as many as possible.
A cautionary tale though, my old instructor had just finished a 'post test' ride before my lesson with a 40-something DAS noob before on an R1200RT and he simply couldn't handle it - it was physically too big, too powerful and he was getting himself in all sorts of trouble.
Banger rallies are ace
BigDan1190
Depends on your age, road experience, size/strength, general common sense and self control.
I say size/strength because the bandit is a heavy girl.
I would always recommend someone to start on an older, cheaper bike. I personally started on a GPZ500s and it was a brilliant bike, good handling, fun to ride, not masses of power but it kept up if you ragged it, and when I dropped it and when I got crashed into on it, I wasn't as gutted as if I would be if I had a big expensive bike.
Its not like you can't start on a cheap shitter for 6 months then sell and buy a nicer bike.
General advice... I'd start on a bandit 600 or similar if I were you. But, the 1200 is managable - I moved from the GPZ500 to the Bandit 1200 as my second bike and was fine.
EDIT: In regards to the Bandit 1200 vs. 600 sports bike argument... If you do get into trouble on a sports bike, the brakes and handling are better, so more likely to get yourself out of trouble. The brakes and suspension are not very good on the bandit in all honesty.
PostPosted: 21:37 - 23 Jan 2013    Post subject: Reply with quote
True, but the Bandit will start to get into trouble in a more manageable way at a lower speed, thus you have more chance of saving it.
The only thing I would question is spending £3k on a first bike, which you're quite likely to drop. Even if it's just a car park scrape. Why not get an old Bandit 1200, or GSX1400?
saint gaz
PostPosted: 21:47 - 23 Jan 2013    Post subject: Reply with quote
[quote="Slacker24seven"]
yep its creeping up on me lol
yes thought of the usual's really, fazer, hornet, sv etc
thought of the bandit 600 but a couple of mates have had them and all got shut after a few weeks because they got bored quickly and lost money on them.
Let the fun begin.
physical
PostPosted: 22:17 - 23 Jan 2013    Post subject: Reply with quote
have ridden all sorts over the years and really enjoy the bandit 1250, it could do with a little bit more power at time but it has loads of creamy torque.
GSF 1250S GT
Snorty
PostPosted: 22:29 - 23 Jan 2013    Post subject: Reply with quote
I started on a GPZ 500, but I only paid £400 for it, so by the time I got bored of it, the amount I'd spent, it was worth hanging onto it, and I'd not spent a ton.
TheBikerStig
PostPosted: 22:55 - 23 Jan 2013    Post subject: Re: is a bandit 1250 to big for first bike? Reply with quote
A lot of 125s cost over 2k brand new so a second hand 1250 for 3k sounds ok to me. I say go for it but check its been looked after. Also there was a recall for 1250s so check that has been done too.
I am usually naked when posting to this forum.
robbieguy2003
PostPosted: 23:21 - 23 Jan 2013    Post subject: Reply with quote
I've a 1250 and a 600RR at the moment, so not in a bad place to comment.
I suppose it depends, any bike can bite you. I'd tend to agree with Wafer Thin Ham, in that the bandit tends to be more progressive and forgiving in 'most' respects.
The difference in braking, handling, and where they come on song is totally different from the bandit to the RR. The one thing that the bandit has over the RR is the amount of torque it kicks out - on colt wet roads, having good throttle control is important.
Overall though, the RR is harder to ride, and harder to ride fast, it takes a different technique, I ride both bikes in quite different ways. I think the Bandit 600 could be a good compromise, or perhaps if you're bigger/want to take a pillion a bit, then you couldn't go massively wrong with a VFR800 or the like.
Still, there's plenty of choice. I'd start by writing down what you'll actually do with the bike - commuting/riding for fun/touring/short blats/shopping/visiting places and walking around once there - based on all that kind of stuff, you'll start to find what you might want from a bike (storage/fun factor/economy/speed/space). You also cant beat going to a shop, having a sit on a good few bikes and feeling them for size is worth a pop.
Current Bikes: Honda CBR 600RR - '07, Suzuki GSX1250 FA ST '11
Old Bikes: Suzuki Intruder 125 LC - '2001, Honda CBR 600F - '92, Honda CBR 600RR - '03
Richy CB1000
PostPosted: 23:35 - 23 Jan 2013    Post subject: Reply with quote
They're just a bit weighty like the majority of the "Old School" retro type bikes, always keep that in mind. I don't know what a modern 600 weighs in at thesedays, but mine is around 235kg without me and fuel!
Harder to manually push about to a novice especially if you're lacking in the muscles dept! Technique will build up with experience so take it very easy in the early days.
Riding... different. Depends what style of riding you're looking for. As has been said, creamy smooth torque, enough power in the real world make for a shall we say more relaxed slighty slower style of riding more rewarding and less tiring! Kind of just taking it easy on a ride out, going with the flow.
Try to hussle them round a back road and you'll soon find out they need a bit more skill and experience to get the best out of them or to put it the other way round get yourself into big trouble very quickly, that weight is difficult to shift around quickly.
Brakes and suspension will generally be more basic, nothing wrong there, just not as fancy as the sportier lighter 600-750's.
That's where some other issues could creep in. They gather pace very very rapidly indeed without some of the screaming revs a lower cc bike would produce so you kind of initially wouldn't realise how bloody quick you're going. Example, not redlining but giving the old girls throttle a 3/4 - full twist, 1st, 2nd change to 3rd, look down 110mph before you know it.
The more I think about it the more obsolete they're becoming in my head. Perhaps if that style of bike catches your eye a 750 bracket bike kind of fills the gap over the 600 without some of the lardy 1000 issues?
Mind you it's a 1000cc and you're old ticker will be pacing away nicley after a few surges, after all that's why you want to ride it isn't it?
Safety hat on I would say no, go for a 600-750, bike hat on, take it easy mate you may just be alright.......?
physical
PostPosted: 23:44 - 23 Jan 2013    Post subject: Reply with quote
If its the ABS model nothing to worry about in the brakes, they quite happily deal with 800-1200 mile days and just swallow the miles nicely, one thing i would say is its worth getting the MRA touring screen for. The recall was for a minor electrical gremlin but is worth getting fixed/checking it has been done. Other one to watch for is they tend to rot at the collector box if they haven't been looked after. The price is probably about right to be honest.
Millennium Motorcycles in thatto heath have loads at the minute around that price as they have just had a bunch of ex hire ones. They even have a GT model for an asking price of £4000 with quite low miles that you could probably get nearer £3500 for cash if you are good at bargaining.
Suzuki suggest the valve clearances being checked at 14,500 miles and it is a pig of a job on the 1250s or expensive if you get someone else to do it.
GSF 1250S GT
doggone
PostPosted: 00:02 - 24 Jan 2013    Post subject: Reply with quote
I used to think my 1200 bandit remarkably compact and manageable.
though powerful and able to sit at 100+ when in Germany Razz it seemed smooth and predictable plus easy to manouevre in tight spots
I tried a friend's 1250 and it seemed like a big barge - completely different and quite a handful to turn and park.
As usual over time you get used to anything.
physical
PostPosted: 00:08 - 24 Jan 2013    Post subject: Reply with quote
had both and know what you mean there mate, took a while to get used to but can honestly say massively prefer handling on the 1250 now just feels totally planted all the time. Took getting the right tyres on it though the OEM tyres just felt wrong for me.
GSF 1250S GT
GaZ
PostPosted: 00:13 - 24 Jan 2013    Post subject: Reply with quote
I started off on a B6 and as much as i loved it as my first bike i would have been much better off with the B12, the B6 just gets boring after a couple of months and there's only so much Renthals and a stubbyexhaust can do.
GaZ
robbieguy2003
PostPosted: 00:45 - 24 Jan 2013    Post subject: Reply with quote
What tyres are you on? mine came with Bridgestone BT020 or BT021, cant remember which one now.
I didn't particularly like them on my RR - tried them once when commuting a bit, they were 'ok', but they've not seemed bad on the 1250, but always interested to hear if something seems to have worked better Thumbs Up
Dean-J
PostPosted: 01:15 - 24 Jan 2013    Post subject: Reply with quote
My 2p for what its worth, with only 4/5 months experience on "big" bikes ( Sv650 and a Thundercat) a mate chucked me the keys to his Bandit 1250 and told me to have fun.
Didnt have any problems with it whatsoever, didnt feel like the big heavy beast it is, felt very well composed on the road and as has been said the torque is just phenomenal. Ok so i didnt wring its neck, but i had a good spin and really enjoyed it. I almost bought one as a result of that ride.
if your not a weedy fella, and you have enough common sense/self control to take your time getting used to it, i dont see why you couldnt get on just fine with a 1250...
physical
PostPosted: 12:01 - 24 Jan 2013    Post subject: Reply with quote
Pirelli angel STs mate
they seem to grip just as well in the wet as the dry, give you a little bit of warning before they just let go and have been great all year round and over lots of miles, get arround 8,000 miles or so out of a rear but im not really very gental on them and do a fair few miles full luggage etc..
I was really surprised at the life as only ever got around 6000 miles out of a BT021 but its all in the dual compound goodness.
review from Kevin Ash: https://www.telegraph.co.uk/motoring/5257743/Tyre-test-Pirelli-Angel-ST.html
GSF 1250S GT
robbieguy2003
PostPosted: 12:24 - 24 Jan 2013    Post subject: Reply with quote
Nice one, thanks for the reply mate, it's appreciated. I went from BT-016s tyres to the Pirelli Diablo Rossos on my RR and the difference was remarkable, fast turn in, and they seemed to grip a hell of a lot.
They sound nice, I think it'll be due for a pair soon, so I think a set of these is in order.
Rob
saint gaz
PostPosted: 22:36 - 24 Jan 2013    Post subject: Reply with quote
Thanks for the input guys, really appreciate it.
think I will go and see what deal I can on it and then decide, I change my mind on a weekly basis so maybe its just time to bite the bullet and pick one.
Let the fun begin.
The last post was made 13 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.99 - MySQL Queries: 16 - Page Size: 116.98 Kb
