Lexmoto gladiator in serious need of help
Conorday
PostPosted: 15:21 - 26 Feb 2013    Post subject: Lexmoto gladiator in serious need of help Reply with quote
14:15:47 Conorday: I have a question I've got a lexmoto gladiator that Wont do anything when I turn the key also the front forks are bent any advice on how much I would get if sold as is? Has a few scratches but damage
paddlesat16
PostPosted: 15:30 - 26 Feb 2013    Post subject: Reply with quote
Check the fuses first, then get a tester on the battery to see if it has any charge.
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
pits
PostPosted: 15:51 - 26 Feb 2013    Post subject: Reply with quote
https://www.polyvore.com/cgi/img-thing?.out=jpg&size=l&tid=50201766
https://file014b.bebo.com/2/large/2006/08/01/18/273749144a1547767279b236396425l.jpg
Three dollars and fiddy cent Thumbs Up
HTH
PostPosted: 16:59 - 26 Feb 2013    Post subject: Reply with quote
Do they do much normally when you turn the key?
If it truly "won't do anything" then sure, electrical. Fuse, battery, frame earth. If it does anything at all, do yourself a favour and tell us what.
A pair of front forks will set you back £107.52 plus postage.
I'd bite pit's hand off if I were you.
map
Mr Calendar
PostPosted: 17:34 - 26 Feb 2013    Post subject: Reply with quote
With a scooter have you tried pulling the left brake lever and with that still held in pushing the start button? If battery flat do the same with the lever and try kick starting it. Obviously turning ignition to the ON position first for either of those.
As said above forks can be replaced. Not worth hassle of straightening for something like that.
Sell for whatever you can get, don't expect a lot (also see above) Wink
PostPosted: 17:36 - 26 Feb 2013    Post subject: Reply with quote
£70
Conorday
PostPosted: 15:39 - 04 Mar 2013    Post subject: Reply with quote
Good news I've had it fixed electrics are working and it is not the forks which are bent just the handlebars that need tightening, and ideas on how to do it? I have tried unscrewing the plastic but it isn't budging at all
The last post was made 13 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.51 - MySQL Queries: 16 - Page Size: 54.07 Kb
