fit electric start to a kick start tzr 125? + other tzr mods
jordey
PostPosted: 18:02 - 11 Mar 2013    Post subject: fit electric start to a kick start tzr 125? + other tzr mods Reply with quote
im looking to buy a tzr 125 as it seems like the best 125 for me (well, that or dt but alot of them are either too expensive or seem dodgy).
theres really not many of them abotu so im having difficulty finding one, i want a 4dl but cant find any for reasonable prices. ive seen a fairly good tzr 125 2rk for 500 so am tempted to buy it as ive been searching for ages and there really isnt very much choice. its kick start though, would it be possible/ difficult to change the kick start to an electric start?
also, what other swingarm could i put into the frame? the stock one of the 2rk isnt very nice (4dl has a much nicer one) i also have rs 125 spare wheels and tyres which i would like to fit so would be good if the swingarm could fit these wheels (was going to fit the rs swingarm but chain is on the other side).
PostPosted: 18:57 - 11 Mar 2013    Post subject: Re: fit electric start to a kick start tzr 125? + other tzr Reply with quote
It doesn't sound like the best bike for you at all?
It sounds like you want the bike for the looks and you don't like the looks.
Why do you want electric start?
It's very costly and a load of hassle in most cases to convert a bike - when you're talking an XR650 used in baja racing, it makes good sense.
For a TZR125, not at all.
jordey
PostPosted: 19:17 - 11 Mar 2013    Post subject: Re: fit electric start to a kick start tzr 125? + other tzr Reply with quote
yeah i want the 4dl but will have to make do with what i can get because there really isnt many about.
if i cant make it electric start its not a big deal just wanted to see if it was possible on the cheap.
as for looks, i would only be changing wheels/ swingarm, mainly because the wheels arent that nice, and also that i have rs wheels lying around and a bunch of spare tyres, so i could swap them over for free (or for the price of a swingarm that will fit)
PostPosted: 19:34 - 11 Mar 2013    Post subject: Reply with quote
Not really cheap and easy. You would probably need a load of parts from the Italian market models (assuming they are similar enough to fit onto the engine), and a load of wiring mods. Certainly possible but probably cheaper and easy to hang looking for the one you want.
With the RS wheels there are several problems. Chain is on the wrong side so the rear wheel would have to run backwards. Wheel spindles are certainly a different size, hence needing spacers. Probably be a pig to get the speedo drive to work. Front disk is very different size hence you would need to make a spacer to mount the caliper.
PostPosted: 19:40 - 11 Mar 2013    Post subject: Reply with quote
Why would you want to remove the coolest part on the bike?
jordey
PostPosted: 19:49 - 11 Mar 2013    Post subject: Reply with quote
yeah as i was typing that i realised the wheel would have to go in reverse.. so thats not gonna work. i was also going to change the front wheel and forks (as i have 2 sets of rs wheels/forks), but two problems here, not sure if the yokes/bolt would fit into the frame, and since i cant now use the rs rear wheel the front wheel wouldn't match, but i may be able to get a front wheel to fit into the rs forks that matches the rear. does anyone know of a swingarm that would fit fairly easily into the tzr frame, with wheels similar size as the rs?
btw, when i get a bike i will be riding it as standard, but just thinking about future mods as i will be having the bike for 2 years due to the new licensing
jordey
PostPosted: 19:56 - 11 Mar 2013    Post subject: Reply with quote
the kickstart? i didnt want to remove it, just add an electric start aswell, i know some dirtbikes have that. it seems like its going to be very expensive/ difficult though so i think im gonna forget about it
PostPosted: 20:06 - 11 Mar 2013    Post subject: Reply with quote
Swapping in a swinging arm is likely to be not easy. Anything is possible but it will require a fair bit of fabrication, with some accurate machining required or spacers and / or the swinging arm.
jordey
PostPosted: 20:20 - 11 Mar 2013    Post subject: Reply with quote
i would be putting a fairly similar sized swingarm in, just better looking and able to take a slightly larger wheel, from maybe a mito or a 250. i was under the assumption i could get a swingarm that is slightly slimmer where it joins the bike, then get spacers to make it snug, but i think i may be oversimplifying this.
and as for the forks, i can only see if the rs ones will fit when i get the tzr as i dont know if the bolt will fit, so will have to wait and see for that one
PostPosted: 20:33 - 11 Mar 2013    Post subject: Reply with quote
For the swinging arm you need to consider the width of the mounting, position of the brake torque arm, where the shock mounts, the type of linkage, the diameter of the swinging arm spindle, length of the swinging arm, provision for brake lines, and a few other odds and sods. Also if the linkage changes then you will probably need to get a shock with a different spring / damping rate, and the shock will probably be compressed at a different rate for the same amount of wheel movement.
For the front wheel / forks, you need to consider the speedo drive (unlikely the Aprilia one will be geared to match the Yamaha speedo for example), length of the forks, length and diameter of the steering head stem, etc. Heavier / lighter bike will likely mean different springs. And you might well struggle to get a bearing to fit the head stock of the frame.
P.
PostPosted: 20:55 - 11 Mar 2013    Post subject: Reply with quote
You could just buy a Derbi GPR engine. Electric start, no kick start. Engines retro fit.
jordey
PostPosted: 21:13 - 11 Mar 2013    Post subject: Reply with quote
theres alot more to think of then i thought!
for the width, im sure spacers would solve that. shock mount may not be too difficult but i would have to see when i get a bike.
for the spindle, whichever hole it doesnt fit (most likely the frame mount) can be drilled out? not sure on this though
i would also try and use the shock from whatever the swingarm i choose if the original tzr wont work. as for length i was under the impression all of the 2 stroke 125 sports had similar length swingarms.
as for the forks, my main concern was the headstem. as for the weight, the tzr is about 20kg lighter, but with bigger/ heavier wheels, forks, tyres and swingarm i think the weight difference wont be an issue. forks were just an idea as the rs forks are better than stock tzr forks and i have rs forks lying around so would be free.
PostPosted: 21:41 - 11 Mar 2013    Post subject: Reply with quote
Suspect most swinging arms would be wider than the standard TZR arm hence might need machining down instead.
Might need chopping off the frame or swinging arm and welding back in position. For example some shocks are offset to one side (eg, RS125).
Maybe. Depends on the frame design.
They can vary massively in length.
That is the main thing. Starting point is to measure the lengths and various diameters.
Better is relative if they are not set up for the bike and / or are a bit shorter and change the steering head angle.
jordey
PostPosted: 22:04 - 11 Mar 2013    Post subject: Reply with quote
for the swingarm, im trying to look for the closest possible to the tzr in terms of mounting points/ length so its less of a hassle to fit, so will be looking around alot of the 125/250/ possible some 400 swingarms to see which may be closest/ easiest to fit, whilst still allowing a bigger rear wheel and look nicer.
and as for the forks, i have rs forks already, so when i get a tzr and can just see if they fit and are a good length, if not i'll just leave the tzr ones on as im not massively fussed about it
jordey
PostPosted: 22:07 - 11 Mar 2013    Post subject: Reply with quote
tbh the yam engines the main reason im buying the tzr!
PostPosted: 22:10 - 11 Mar 2013    Post subject: Reply with quote
Afraid screwing up the handling just for looks wouldn't be my idea of fun Wink .
The TZR frame is pretty narrow, hence likely quite limited on what will fit.
Yamaha sold their basic engine to other makers. Think Sachs might also have used it. However not 100% sure that the early TZR125 has the same engine mounts as the later engines.
jordey
PostPosted: 22:32 - 11 Mar 2013    Post subject: Reply with quote
yeah thats what i was saying, im only gonna put the rs forks in if its not too much work and it all works as it should.
im not changing the engine though, ill jusrt keep the tzr one in there and stick with the kick start. i have sachs shocks fro the rs so i can see if hey can be used.
main thing now is first looking for a tzr (ive got one in mind that ive contacted the owner, but looking for a better one if possible) and looking for an appropriate swingarm
PostPosted: 23:11 - 11 Mar 2013    Post subject: Reply with quote
Fair enough. Odd size tyres won't help, nor will suspension that doesn't match.
Realistically once you add the cost of odds and sods (brake hoses, spacer, bearings, etc) you probably could buy a 4DL easily.
Keith (and if you find an early blue fully faired 2RK, please don't hack it about!)
Ariel Badger
PostPosted: 23:20 - 11 Mar 2013    Post subject: Reply with quote
Converting to electric start is easy if you know how, you would of course need a full engine strip down and some re-machining of the crank. the castings would need to be altered at best but I would think you would need to make new patterns, get them cast and machined and then there is the rewiring. £2000 or so?
jordey
PostPosted: 23:39 - 11 Mar 2013    Post subject: Reply with quote
tbh its not just that the 4dl's are expensive, theyre also really hard to find aswell!
the bike i will be getting im only going to be paying about 500 so its not going to be mint. if im changing the front end to an rs ive already got forks, hose, cylinder, disc etc. (may not fit the new wheels i get though). so the cost would basically be swingarm, rear brake assembly and wheels/ tyres. but ive also got to look the feasibility of this up a bit more. im thinking maybe mito swingarm and wheels, they're pretty cheap and look small. im gonna ask around for sizes of the mounting points and spindle
PostPosted: 23:52 - 11 Mar 2013    Post subject: Reply with quote
It still is likely to be easier, cheaper and quicker to wait a bit and buy the actual bike you want - you'll also get more time riding it (or more time being seen ridden it, if that's what's important to you Smile ).
Ariel Badger
PostPosted: 00:02 - 12 Mar 2013    Post subject: Reply with quote
That is what I said Mr. Green
P.
PostPosted: 09:46 - 12 Mar 2013    Post subject: Reply with quote
That uses the Yam engine Wink
Timmeh
PostPosted: 20:51 - 12 Mar 2013    Post subject: Reply with quote
I'm on my second 4DL2. It cost me 700 quid.
I wouldn't really call that expensive tbh, if you compare it to pre-99 RS125s and Mitos.
They have 26bhp as standard, will do about 90, the ride is harsh and unforgiving and the handlebars only turn about 70 degrees so don't handle at all well at slow speeds. U-turns are practically impossible.
That said, they are fun to ride, but you really do need to take the bull by the horns as they are can be quite twitchy. I'm quite light so I have to shift my weight and countersteer to get them to lean in. I wouldn't call them learner bikes by any stretch of the imagination.
Karma
jordey
PostPosted: 15:34 - 13 Mar 2013    Post subject: Reply with quote
Karma
tbh over the months ive been looking, ive only seen a few 4dl's being sold in the country. im looking now but i can only find mint ones for 1500 +, i dont really want to spend more than 500/600. the main reasons i wanted a tzr is for the reliability, price, and lower power than the other two strokes with me being on a restricted license.
im near 14 stone though so dont really have a problem with being too light!
ive been looking for bikes for ages (sport bikes) and only really the tzr seems appealing in terms of living with it (unless theres another bike i should be looking out for that i've missed?). i also wouldnt mind a dt but any decent ones that are road legal tend to fetch quite a bit. i could get an rs but know from experience they're fairly annoying to live with
The last post was made 12 years, 131 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 3.33 - MySQL Queries: 13 - Page Size: 142.48 Kb
