Author |
jordey |
 jordey Nitrous Nuisance
Back to top |
G |
 G The Voice of Reason
Back to top |
jordey |
Back to top |
Kickstart |
 Posted: 19:34 - 11 Mar 2013 Post subject: |
Not really cheap and easy. You would probably need a load of parts from the Italian market models (assuming they are similar enough to fit onto the engine), and a load of wiring mods. Certainly possible but probably cheaper and easy to hang looking for the one you want.
With the RS wheels there are several problems. Chain is on the wrong side so the rear wheel would have to run backwards. Wheel spindles are certainly a different size, hence needing spacers. Probably be a pig to get the speedo drive to work. Front disk is very different size hence you would need to make a spacer to mount the caliper.
Back to top |
Pete. |
 Posted: 19:40 - 11 Mar 2013 Post subject: |
Why would you want to remove the coolest part on the bike? ____________________ a.k.a 'Geri'
Back to top |
jordey |
Back to top |
jordey |
Back to top |
Kickstart |
Back to top |
jordey |
Back to top |
Kickstart |
 Posted: 20:33 - 11 Mar 2013 Post subject: |
For the swinging arm you need to consider the width of the mounting, position of the brake torque arm, where the shock mounts, the type of linkage, the diameter of the swinging arm spindle, length of the swinging arm, provision for brake lines, and a few other odds and sods. Also if the linkage changes then you will probably need to get a shock with a different spring / damping rate, and the shock will probably be compressed at a different rate for the same amount of wheel movement.
For the front wheel / forks, you need to consider the speedo drive (unlikely the Aprilia one will be geared to match the Yamaha speedo for example), length of the forks, length and diameter of the steering head stem, etc. Heavier / lighter bike will likely mean different springs. And you might well struggle to get a bearing to fit the head stock of the frame.
Back to top |
P. |
 P. Red Rocket
Back to top |
jordey |
 Posted: 21:13 - 11 Mar 2013 Post subject: |
Kickstart wrote: | Hi
Keith |
theres alot more to think of then i thought!
for the width, im sure spacers would solve that. shock mount may not be too difficult but i would have to see when i get a bike.
for the spindle, whichever hole it doesnt fit (most likely the frame mount) can be drilled out? not sure on this though
i would also try and use the shock from whatever the swingarm i choose if the original tzr wont work. as for length i was under the impression all of the 2 stroke 125 sports had similar length swingarms.
as for the forks, my main concern was the headstem. as for the weight, the tzr is about 20kg lighter, but with bigger/ heavier wheels, forks, tyres and swingarm i think the weight difference wont be an issue. forks were just an idea as the rs forks are better than stock tzr forks and i have rs forks lying around so would be free. |
Back to top |
Kickstart |
 Posted: 21:41 - 11 Mar 2013 Post subject: |
jordey wrote: |
for the width, im sure spacers would solve that. |
Suspect most swinging arms would be wider than the standard TZR arm hence might need machining down instead.
jordey wrote: | shock mount may not be too difficult but i would have to see when i get a bike. |
Might need chopping off the frame or swinging arm and welding back in position. For example some shocks are offset to one side (eg, RS125).
jordey wrote: | for the spindle, whichever hole it doesnt fit (most likely the frame mount) can be drilled out? not sure on this though |
Maybe. Depends on the frame design.
jordey wrote: | i would also try and use the shock from whatever the swingarm i choose if the original tzr wont work. as for length i was under the impression all of the 2 stroke 125 sports had similar length swingarms. |
They can vary massively in length.
jordey wrote: | as for the forks, my main concern was the headstem. |
That is the main thing. Starting point is to measure the lengths and various diameters.
jordey wrote: | forks were just an idea as the rs forks are better than stock tzr forks and i have rs forks lying around so would be free. |
Better is relative if they are not set up for the bike and / or are a bit shorter and change the steering head angle.
Back to top |
jordey |
 Posted: 22:04 - 11 Mar 2013 Post subject: |
Kickstart wrote: | jordey wrote: |
Keith |
for the swingarm, im trying to look for the closest possible to the tzr in terms of mounting points/ length so its less of a hassle to fit, so will be looking around alot of the 125/250/ possible some 400 swingarms to see which may be closest/ easiest to fit, whilst still allowing a bigger rear wheel and look nicer.
and as for the forks, i have rs forks already, so when i get a tzr and can just see if they fit and are a good length, if not i'll just leave the tzr ones on as im not massively fussed about it |
Back to top |
jordey |
Back to top |
Kickstart |
Back to top |
jordey |
 Posted: 22:32 - 11 Mar 2013 Post subject: |
Afraid screwing up the handling just for looks wouldn't be my idea of fun  .
The TZR frame is pretty narrow, hence likely quite limited on what will fit.
Yamaha sold their basic engine to other makers. Think Sachs might also have used it. However not 100% sure that the early TZR125 has the same engine mounts as the later engines.
Keith |
yeah thats what i was saying, im only gonna put the rs forks in if its not too much work and it all works as it should.
im not changing the engine though, ill jusrt keep the tzr one in there and stick with the kick start. i have sachs shocks fro the rs so i can see if hey can be used.
main thing now is first looking for a tzr (ive got one in mind that ive contacted the owner, but looking for a better one if possible) and looking for an appropriate swingarm |
Back to top |
Kickstart |
Back to top |
Ariel Badger |
 Ariel Badger Super Spammer
Back to top |
jordey |
 Posted: 23:39 - 11 Mar 2013 Post subject: |
Fair enough. Odd size tyres won't help, nor will suspension that doesn't match.
Realistically once you add the cost of odds and sods (brake hoses, spacer, bearings, etc) you probably could buy a 4DL easily.
Keith (and if you find an early blue fully faired 2RK, please don't hack it about!) |
tbh its not just that the 4dl's are expensive, theyre also really hard to find aswell!
the bike i will be getting im only going to be paying about 500 so its not going to be mint. if im changing the front end to an rs ive already got forks, hose, cylinder, disc etc. (may not fit the new wheels i get though). so the cost would basically be swingarm, rear brake assembly and wheels/ tyres. but ive also got to look the feasibility of this up a bit more. im thinking maybe mito swingarm and wheels, they're pretty cheap and look small. im gonna ask around for sizes of the mounting points and spindle |
Back to top |
G |
 Posted: 23:52 - 11 Mar 2013 Post subject: |
It still is likely to be easier, cheaper and quicker to wait a bit and buy the actual bike you want - you'll also get more time riding it (or more time being seen ridden it, if that's what's important to you ). |
Back to top |
Ariel Badger |
Back to top |
P. |
 P. Red Rocket
Back to top |
Timmeh |
 Timmeh World Chat Champion
 Posted: 20:51 - 12 Mar 2013 Post subject: |
I'm on my second 4DL2. It cost me 700 quid.
I wouldn't really call that expensive tbh, if you compare it to pre-99 RS125s and Mitos.
They have 26bhp as standard, will do about 90, the ride is harsh and unforgiving and the handlebars only turn about 70 degrees so don't handle at all well at slow speeds. U-turns are practically impossible.
That said, they are fun to ride, but you really do need to take the bull by the horns as they are can be quite twitchy. I'm quite light so I have to shift my weight and countersteer to get them to lean in. I wouldn't call them learner bikes by any stretch of the imagination.
 ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
Back to top |
jordey |
 Posted: 15:34 - 13 Mar 2013 Post subject: |
Timmeh wrote: | I'm on my second 4DL2. It cost me 700 quid.
tbh over the months ive been looking, ive only seen a few 4dl's being sold in the country. im looking now but i can only find mint ones for 1500 +, i dont really want to spend more than 500/600. the main reasons i wanted a tzr is for the reliability, price, and lower power than the other two strokes with me being on a restricted license.
im near 14 stone though so dont really have a problem with being too light!
ive been looking for bikes for ages (sport bikes) and only really the tzr seems appealing in terms of living with it (unless theres another bike i should be looking out for that i've missed?). i also wouldnt mind a dt but any decent ones that are road legal tend to fetch quite a bit. i could get an rs but know from experience they're fairly annoying to live with |
Back to top |
The last post was made 12 years, 131 days ago. Instead of replying here, would creating a new thread be more useful? |
