aprilia forks .. keith??
conpants
PostPosted: 13:19 - 19 Nov 2004    Post subject: aprilia forks .. keith?? Reply with quote
as you know i got an aprilia af1 50,
in error i bought some af1 125 forks (as mine are all pitted)
however these forks i bought are the right length but there width is different also they are upside down forks (i think the ones on the 50 are too, but these are very different)
what im asking is, would there be a way of fitting these forks
https://i20.ebayimg.com/02/i/02/c7/c5/59_1_b.JPG
to my af1 50??
PostPosted: 14:35 - 19 Nov 2004    Post subject: Reply with quote
Err, I have seen a pair bodged onto an RS50 (indeed, in Leeds where I bought some bits and I suspect you won the forks from the same guy on Ebay). Basically someone had bodged the AF1 forks and yokes into the RS50 frame, despite the steering head stem on to the 125 being about 5cm longer!
Do do the job properly would require either getting some new yokes made up (very expensive), or if you are lucky you could press out the stem from the 125 forks and press in the stem from the 50. You would also need the front wheel , wheel spindle, speedo drive, brake disk, brake caliper, mudguard, handlebars, etc, but could maybe use the wheel from the 50 with a lot of bodging.
You could do it but I really would not recommend it.
You can get the forks rechromed, but suspect the forks from an RS50 could be fitted. ABE (All Bike Engineering) might well do replacement fork tubes.
By the way, if these are the forks from Leeds (and the picture you posted is from that Ebay listing) then should you decide to sell them on then let me know as I saw they were in good condition.
M1ke
Ped Boi
PostPosted: 21:19 - 19 Nov 2004    Post subject: Reply with quote
Like keith says you can get your current ones rechromed or just buy new stanchions which I was quoted £55 per leg on a pair of USD forks.
conpants
PostPosted: 02:39 - 20 Nov 2004    Post subject: Reply with quote
well, they are no use to me, you are welcome to them .. yes they are from leeds .. pm me
The last post was made 21 years, 320 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 2.64 - MySQL Queries: 16 - Page Size: 42.53 Kb
