cg oil
ts50x0
PostPosted: 19:20 - 24 Nov 2004    Post subject: cg oil Reply with quote
if someone has a haynes manual for a cg can they tell me please how much oil i need to fill it up from empty,
ive heard it was half a litre, is this correct.
cheers
sam
p.s. ive orderd a manual it just hasnt come yet,
pipnet11
PostPosted: 19:53 - 24 Nov 2004    Post subject: Reply with quote
half a litre sounds SERIOUSLY small. from totaly empty my GS took 1200ml and 850ml if you hadnt taken the filter off or anthing. Id wait till you got the manual though because its unlikely to be the same. Could pour it in slowly till it gets to the right height on the level window
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
mchaggis
PostPosted: 19:59 - 24 Nov 2004    Post subject: Reply with quote
A minimum of 0.9 litres will get to the bottom of the dipstick. 1.5 litres will get to the top, and perhaps slightly past the top of the hatched area in the dipstick. Hence I normally put in about 1.3 litres.
I must not be a troll...
Mmmm, Guinness
ts50x0
PostPosted: 20:28 - 24 Nov 2004    Post subject: Reply with quote
ive just done it and i put 1 litre straight in and it was way too much, had to take out about 0,2 or 0,3 litres, wonder whats going on there. its still slightly over the top of the dipstick. dont want to take more out as that seems not to be enough oil. what deos your manual say?
mchaggis
PostPosted: 20:36 - 24 Nov 2004    Post subject: Reply with quote
Well, the thing is, my engine isn't neccesarily the same as all CG engines, as it's not the same bike, though it is the same basic engine design. My manual tells me to put in at least 0.9, and then it gets just to the bottom of the dipstick.
Embarassed My bad. Sorry if I led you down the garden path without thinking. I'd go and have a look at the Haynes manual for the CG I do regularly seem to be fixing, but it's at home and I'm not.
According to this, the oil capacity is 1.1 litres.
Mmmm, Guinness
ts50x0
PostPosted: 20:45 - 24 Nov 2004    Post subject: Reply with quote
thats for the brand new desighn though. mines 1987 model,
mchaggis
PostPosted: 20:53 - 24 Nov 2004    Post subject: Reply with quote
Sorry I can't help you then, without the manual which I don't have access to. Just putting 0.8 litres or so in would make sense to me. Run the engine for a minute or two so the oil gets round all the galleries and things, then check the dipstick as normal. Add or remove if there isn't enough or is too much.
Mmmm, Guinness
ts50x0
PostPosted: 21:12 - 24 Nov 2004    Post subject: Reply with quote
just worked out that i put in exactly 0.8 litres, seems to be ok, im sure that 0.8 litres is enough anyway. at least untill my manual arrives and i orderd it the toher day so.
thanks for you help anyway mate,
sam
pipnet11
PostPosted: 21:29 - 24 Nov 2004    Post subject: Reply with quote
You mean they changed it??? thought they were machanicaly unchanged from when they started. The GS is almost unchanged. Only difference was the old cylinder heads used to eat valve guides for some reason. sorted in about '84 or something and only the electric starter has changed since. Would be surprised if the CG is much different.
ts50x0
PostPosted: 21:45 - 24 Nov 2004    Post subject: Reply with quote
yes theyve brought out a new bike for 2004. still the same basic desighn but has some more HP and a new shape. must be something different. they didnt change the engine up untill 2003 but then theyve brought out that new cg along with the cbr125.
Retro-Man
PostPosted: 21:52 - 24 Nov 2004    Post subject: Reply with quote
your right mate
there are all sorts of minor tweaks to the cg dating from right back when it started, the new model is quite technically different. differences can be subtle as in minor carb changes or cyl head measurements.
Cheers
Retro
https://domharnessphotography.webs.com
pipnet11
PostPosted: 22:19 - 24 Nov 2004    Post subject: Reply with quote
Shows how much I pay attention Laughing
The last post was made 19 years, 158 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.98 - MySQL Queries: 17 - Page Size: 76.44 Kb
