Charging battery when bike has an alarm
Wonko The Sane
PostPosted: 16:38 - 20 Apr 2013    Post subject: Charging battery when bike has an alarm Reply with quote
I know I need to disconnect the battery in order to charge it without blowing the fuse in the bike,
What I'm unsure about is the fact the bike has an alarm on it (standard Kawasaki alarm that came fitted, bike is the ZZR600, '99 reg
If I disconnect the battery, will I have to set-up the alarm to recognise the remote or will it be ok?
Annoyingly the alarm is as loud as ever but the bike doesn't have enough power to start it.
PostPosted: 16:40 - 20 Apr 2013    Post subject: Reply with quote
I never heard of having to disconnect the battery for charging to save blowing a fuse - what makes you think that's necessary?
J.M.
PostPosted: 16:44 - 20 Apr 2013    Post subject: Reply with quote
I've always just left everything connected when charging the bike.
2004 R1 & 2018 XSR900
goodlifefarm
PostPosted: 16:53 - 20 Apr 2013    Post subject: Reply with quote
You don't need to disconnect the battery, all optimates come with cables you leave connected to the battery to make it easy to charge them without having to remove the seat and battery.
https://www.demon-tweeks.co.uk/oncirrus/3/images/product/enlarge/opt_3_batt_charger_d3.jpg
Charlie
Dont worry about removing, should be fine.
Wonko The Sane
PostPosted: 16:55 - 20 Apr 2013    Post subject: Reply with quote
pretty much everyone I've asked before has said it needs to be disconnected including my instructor who's charger I've borrowed.
J.M.
PostPosted: 17:19 - 20 Apr 2013    Post subject: Reply with quote
I once got told by a mechanic to turn the lights on whilst the bike is idling because it makes the alternator make more power so the battery charges faster.
I didn't argue only because he jump-started the bike for free.
Wonko The Sane
PostPosted: 17:21 - 20 Apr 2013    Post subject: Reply with quote
charger attached and power light is on, but little green charging light doesn't seem to be, but it is daylight out there so could be feint. We'll see how we go.
MattEMulsion
PostPosted: 17:25 - 20 Apr 2013    Post subject: Reply with quote
If it is an Optimate then the charging light is Orange. If it isn't on - it isn't charging. Check the connections first, (are you using the crocodile clips?) and the little plug on the Optimate lead.
Yamaha YZF-R6
Wonko The Sane
PostPosted: 17:27 - 20 Apr 2013    Post subject: Reply with quote
it's not an optimate.
It's croc clips wired into the unit, they're clipped onto the terminals and the red power light is lit, I'm not certain if the charging light is lit or not, it's a light green led
Walloper
PostPosted: 17:54 - 20 Apr 2013    Post subject: Reply with quote
I hope the cnut took the time to discuss the virtue of changing powerbands??
PostPosted: 18:40 - 20 Apr 2013    Post subject: Reply with quote
I would sound a tiny note of caution in that I suspect that I may have fried the electonomics on my car by connecting a charger to it without disconnecting the battery.
Probably not, but I do tend to err on the side of caution now.
Wonko The Sane
PostPosted: 18:48 - 20 Apr 2013    Post subject: Reply with quote
Well, it seems the charger didn't do anything in the couple of hours it was connected up to it so not really sure what to do now.
Tempted to give up and have someone come look at it to get it sorted.
Marmaduke
PostPosted: 19:02 - 20 Apr 2013    Post subject: Reply with quote
Did the charger get warm? Do you not have a multi meter?
Current: '03 Tuono RSV1000, '05 Van Van, '91 Zephyr 550
Previous: Multistrada 620,Bandit 600,Kawsaki ER-5, BMW K-75
Wonko The Sane
PostPosted: 19:08 - 20 Apr 2013    Post subject: Reply with quote
Nope to both Marmaduke.
The last post was made 12 years, 272 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.98 - MySQL Queries: 16 - Page Size: 90.04 Kb
