UPVC Door/Window fitters/Locksmiths....Please Help.
Raffles
PostPosted: 22:42 - 06 May 2013    Post subject: UPVC Door/Window fitters/Locksmiths....Please Help. Reply with quote
I am currently having trouble with the latch/locking mechanism of an exterior UPVC door. The handle is ''drooping'' slightly and is failing to dissengage the latch from the keep.
What I need to know is is this an easy thing to fix? Can the latch be repaired/replaced or do I need to replace the entire muli point locking mechanism?
Any help would be very much appreciated.
Marmalade
PostPosted: 09:44 - 07 May 2013    Post subject: Reply with quote
You can buy parts for most upvc doors, even from b&q.
If you know the supplier you should be able to get it from them but a lot of items fit other makers doors
Speed
PostPosted: 11:16 - 07 May 2013    Post subject: Reply with quote
The gearbox mechanism inside the door can be hit or miss, they like spewing their internals out or cracking the spindle (monkey metal). They used to rivet them on and a whole new mechanism would need to have been bought but most of the ones I come across nowadays have a screwed on gearbox. If that’s the case then take it off and pop it to a locksmiths or somewhere like B&Q and they’ll match it…hopefully. There are so many different ones out there it’s unreal. If you can’t leave the gearbox out of the door then trace around it and re-fit. Make notes of any brands or numbers on the face plate as this helps massively.
The last post was made 13 years, 172 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.38 - MySQL Queries: 16 - Page Size: 37.56 Kb
