Author |
Bendy |
Bendy Mrs Sensible
Posted: 20:44 - 26 Nov 2004 Post subject: Why? |
Why do the exhausts on bikes come out the front of the engine and have to snake their way all the way underneath and then up the side(s) to get to the can at the back? Why don't they just come out the back in the first place?
(I know cock all about engines, it's just something visual that struck me, and I look forward to the answer being devastatingly obvious ) |
Back to top |
Demonic69 |
Demonic69 The Pink Rhino
Back to top |
tatters |
tatters Exxon Valdez
Posted: 21:19 - 26 Nov 2004 Post subject: |
thats why some people have put the engine in backwards so air is ramed into the carbs and also they can have louder shorter pipes, also think about V4,s ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650 Present:G650XC,C12,KZ750,1190ADV |
Back to top |
cagiva gezzer |
Back to top |
TheShaggyDA |
TheShaggyDA Repost Police
Posted: 22:50 - 26 Nov 2004 Post subject: |
Might have originally been a problem with carbs icing up - stick them behind the engine, and you have a warmer pocket for them. Out front they are unprotected.
This was the reason that Minis (the real ones, not the BMW "lets ride on the coat-tails of a well known name" compact car) have their engines that way round. It was estimated that the engine lost nearly 10% of it's power by gearing it to run that way round, too. ____________________ Current: CB500 Previous: CB100N, CB250RS, XJ900F, GT550, GPZ750R/1000RX, AJS M16, R100RT, Enfield Bullet
[i:6e3bfc7581]But still I fear and still I dare not laugh at the madman...[/i:6e3bfc7581] |
Back to top |
Retro-Man |
Retro-Man Traffic Copper
Posted: 22:51 - 26 Nov 2004 Post subject: |
In case of an accident, would seem reasonable to me....
It makes sense to me at least to keep the fuel system as close to the centre of the bike as possible keeping it out of harms way.
the by product of this safety feature is that the exhaust has to come out the front (or at least that is easiest way), due to the very nature of engine basic designs.
Cheers
Retro ____________________ https://domharnessphotography.webs.com |
Back to top |
Kickstart |
Posted: 22:53 - 26 Nov 2004 Post subject: |
It is possible to build the engine reversed. Think the MV Agusta engine was originally designed to be like that, and then there were the reverse cylinder TZR250s.
The problem is partly the length of the exhaust, partly packaging (where the hell do you put all the bits that normally live in that area and which want to be rather cooler than the exhaust) and partly problems with having enough space for the carbs and a nice large air box.
Back to top |
Retro-Man |
Posted: 22:56 - 26 Nov 2004 Post subject: |
so far I think we all have made valid reasons, I would hazard a guess that there is no single reason why, but that all the answers so far are correct.
It simply makes more sense to have the pipes coming out the front due to all the above posts and there are probably even more reasons. ____________________ https://domharnessphotography.webs.com |
Back to top |
Guest |
Guest Brolly Dolly
Posted: 23:34 - 26 Nov 2004 Post subject: |
The hottest part of an engine is round the exhaust valves and header pipes - might as well use all that free cool air for something |
Back to top |
stinkwheel |
Back to top |
cagiva gezzer |
Back to top |
mchaggis |
mchaggis World Chat Champion
Posted: 00:13 - 27 Nov 2004 Post subject: |
On a V-twin there isn't any other way to do it, unless you have a stupidly wide V angle or can put the engine in horizontally. You always want to package the inlet and exhaust as far away from each other as possible to ensure that the exhaust doesn't heat the inlet up too. This means that you tend to end up with the inlet manifold on one side and the exhaust on the other.
In front of the engine there is unfortunately bugger all space really in which to package very much, as the tank and radiator take pretty much all of the available space. Another issue is that normally, you want the exhaust gasses out of the vehicle as fast as you can get them, whilst staying within the environmental controls. This means you end up with them going down and straight out the back.
The obvious answer from my point of view is that packaging 4 hot exhausts through the centre of the bike really doesn't make a lot of sense. There is a lot of convenient space which can have things like electrics, batteries, carburettors, shocks etc etc in the middle of the bike. Most of these things require shielding from the environment, whereas the exhausts don't.
So, in essence, the way the exhausts are just now is the best way to have them as they can be routed away from heat sensitive things, and the space in the centre of the bike can be used better for other more condition critical components. ____________________ I must not be a troll...
Mmmm, Guinness
Discovering the delights of Hammerite and a 3/4" brush. |
Back to top |
stryker |
stryker Brolly Dolly
Back to top |
Kickstart |
Back to top |
Rory |
Rory Traffic Copper
Posted: 16:16 - 27 Nov 2004 Post subject: |
It's been touched on already, but I think that by routing the pipes as they are on most bikes, the path of the exahaust gasses is free-er, i.e. fewer twists and turns to slow the gas down. ____________________ My Old CBR400RR | Bike Oil FAQ | Petrol FAQ |
Back to top |
binge |
binge Emo Kiddy
Posted: 18:36 - 27 Nov 2004 Post subject: |
Well ive just been adjusting the clutch on my mams Suzuki cappacino and I noticed that the exhaustsdo not exit from the front on that. By the looks of it (I didnt have a great look because its so compact) but by the looks of it, the carbs are on the left, and the exhaust exits from the right.
Ben... ____________________ - Honda XL125S - CBR400 NC29 - VFR400 NC30 - CBR400 NC29 - TL1000R - TeeZeR Pit! - Bandit 12 - YZF450 - LuckyMX125 Pit! - Demon X XLR 140 Pit!
- Stomp KZ 160 Pit! - Demon X D-link 140 Pit! - CRF50F Mini-Pit - MonsterMoto 155cc MiniSM - Honda Chaly 150cc - Yamaha 98' R1
- Honda Chaly 140cc - Thumpstar 190cc 4v MiniSM - Aprilia RS125 Pit-Bike - |
Back to top |
mchaggis |
Back to top |
binge |
binge Emo Kiddy
Back to top |
mchaggis |
Posted: 20:02 - 27 Nov 2004 Post subject: |
If you can excuse my shoddy Paint drawing and excessively large picture , I presume you mean it's positioned as in the top drawing, whereas in the bottom one, it's positioned as it would be in the bike.
Just out of interest, are there any bikes which have their engine positioned longitudinally? Ah, just thought of ones which will, the shaft driven ones will.
https://www.2tausend1.de/motors/normal/Honda-CX500-1981.jpg
https://home.planet.nl/~motors-20th-century/page_Honda.htm ____________________ I must not be a troll...
Mmmm, Guinness
Back to top |
Smoto Bob |
Smoto Bob World Chat Champion
Back to top |
Guest |
Guest Brolly Dolly
Posted: 21:14 - 27 Nov 2004 Post subject: |
Ah, now we're into GP technology on the road |
Back to top |
loply |
loply World Chat Champion
Posted: 22:29 - 27 Nov 2004 Post subject: |
The new Foggy Petronas FP1 has a "reverse engine" but they had an awful lot of difficulty keeping the exhaust cool (and the things around it cool) according to MCN.
So I guess the number one reason is heat... ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
Back to top |
Fortuna |
Fortuna World Chat Champion
Back to top |
iCraig |
iCraig World Chat Champion
Back to top |
binge |
binge Emo Kiddy
Back to top |
The last post was made 19 years, 154 days ago. Instead of replying here, would creating a new thread be more useful? |
