Shock spring issue
tatters
Exxon Valdez
PostPosted: 17:59 - 11 May 2013    Post subject: Shock spring issue Reply with quote
I just received a replacement spring for my hyperpro shock but it shorter in length and is a thinner gauge than the current spring. The current spring is a 1216 and after contacting hyperpro with rider and luggage weight l was told l needed a stiffer spring a 1220 which the replacement spring is marked with.
Am l right to believe that a replacement stiffer spring would be the same length but just a thicker gauge wire?
https://cdn.bikechatforums.com/files/20130511_170209.jpg
Aff
PostPosted: 18:36 - 11 May 2013    Post subject: Re: Shock spring issue Reply with quote
Shortening a spring makes it stiffer.
Think of it like a torsion bar (which is effectively what a spring is), much easier to bend a 4m bar than a 1m bar.
:edit: Just saw you said it was a different gauge, this would only be comparable if you could guarantee it was made from the exact same material. It all depends on the Shear Modulus of the metal used.
Electric Bike Project
tatters
Exxon Valdez
PostPosted: 19:24 - 11 May 2013    Post subject: Reply with quote
I understand about preloading/shorting the spring would make it stiffer but it also reduces the length of travel. Ohlins springs l had for my R100GSPD and XR650R were always the same length just a thicker gauge wire.
PostPosted: 20:40 - 11 May 2013    Post subject: Reply with quote
After talking to an engineer friend, nobody really fully understands what's going on with springs.
He did say that most of what's going on is on the surface of the spring, the middle of it is just to hold the surface of the metal away from itself but doesn't contribute much to the springiness.
So. Surface area probably has more to do with it than thickness or length of spring.
A thinner guage spring will have a higher surface area to volume ratio. It's entirely possible it's a stronger spring. The only real way to find out would be to see how much it compresses when you apply foprce to it, external dimensions aren't necessarily going to tell you a lot.
The last post was made 13 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.72 - MySQL Queries: 16 - Page Size: 43.2 Kb
