Honda cb400n bad cylinder ?
Evolution6972
PostPosted: 02:55 - 15 May 2013    Post subject: Honda cb400n bad cylinder ? Reply with quote
I think it's a cb400n. I bought a gokart from someone got it running and a friend helped me adjust the valves. I still need to get the valves correct. It runs better since the valves where floating. My main concern is the left cylinder runs great the right one doesn't . It was blowing white smoke bad before the valve adjustment. The right side the engine doesn't get as hot as the left side and the exhaust doesn't come out as strong. The left side exhaust comes with a nice lil hard hit the right side is almost like its just blowing the air out. I adjusted the throttle valve on the right carb. Makes the engine run faster so I know the right side is doing something.
And yes I broke down the carbs all the way cleaned them everything's getting fuel. Starts great just wanna get the cylinders running right
Ps where the hell is the cereal number on the motor all I see is c c c
bikenut
PostPosted: 15:36 - 15 May 2013    Post subject: Reply with quote
cb400n superdream engine.........ccc refers to main bearing ext codes..........you know of cmsnl??
how is compression on cyls and valve clearance 4thouin 5thouex........cold
how is cam chain and do you know mileage??
you know of float heights and carb balancing sprung loaded adjuster etc............no air leaks and good air filter??
how where power/economy diaphragms??
small vw type fuel filter is a good idea..........( and balance chain, look for dot on balance shaft......if below horizontal that's bad, note adjustable adjusting quadrant )........much crapin filter housing floor.......over
bikenut
PostPosted: 15:38 - 15 May 2013    Post subject: Reply with quote
engine number by neutral sw on upper crank case......
Evolution6972
PostPosted: 03:21 - 16 May 2013    Post subject: Reply with quote
I forget the I want to say the good cylinder was 120 psi and the bad 115 psi. Cam chain looked like a pretty chain never seen one like it before. I never worked on these kinda engines. I have no idea of mileage. Everything in the carbs was in great condition and clean.
trevor saxe-coburg-gotha
PostPosted: 04:38 - 16 May 2013    Post subject: Reply with quote
Confused
Confused
Confused
bikenut
PostPosted: 09:16 - 16 May 2013    Post subject: Reply with quote
8o) cool........so did youy find the engine number and see the exploded views in cmsnl??????
has some compression and fairly close readfings, yopu have set the valve clearances..............may need bigger jets as you have cone filters......you found the balance adjust mech tween carbs..........and the idle speed adjust......as well as idle mixture screws.............hope the o rings where installed in that part correctly??
goto cmnsl............
Evolution6972
PostPosted: 01:01 - 17 May 2013    Post subject: Update Reply with quote
Found the serial number under the carbs NC03E 2000087. Also found out I had a bad plug wooooo now I just need to get valves adjusted. What is this cmnsl? And I know I have a bad ring on cylinder 2 opened the oil screw a little and good bit of pressure was blowing out. I looked up the number for the motor here and there can't find any kinda info. Probly just looking in the wrong places. And yes I did carbs myself everything is in the right spot. No harder than a Yamaha outboard.
Moo.
PostPosted: 08:36 - 17 May 2013    Post subject: Reply with quote
The CC is written on the cylinder block on the left hand side if the carbs are facing you.
These were pretty decent engines, the only problem was the cam shaft didnt run in any bearings so it wore out quickly. Its the same engine as the CB250N which is just sleeved down.
Could always try to find a chea haynes for a CB400N
It might possibly be the 250 engine which are very cheap but look exactly the same, the 400n engine is alot rarer to find, but theres plenty of the 250's about
A2 Passed 18/6/10
bikenut
PostPosted: 11:15 - 17 May 2013    Post subject: Reply with quote
google cmsnl and follow your nose.......... :D
bikenut
PostPosted: 11:19 - 17 May 2013    Post subject: Reply with quote
could you put up some better pics.......of engine........different views .........plan,l/h/s and r/h side.............also tween cylinders...............you been to cmnsl yet??????
Evolution6972
PostPosted: 01:14 - 19 May 2013    Post subject: Reply with quote
Here is pics
Evolution6972
PostPosted: 03:21 - 19 May 2013    Post subject: Reply with quote
I think I found it I think it's a cb400t
bikenut
PostPosted: 13:10 - 20 May 2013    Post subject: cb400t Reply with quote
:D some progress then......its a t or superdream engine all right and i love the fuel tap :D ......also nice to see a filter in the fuel line.........
google superdream forum and follow your nose..........did you visit and print off cmsnl info??
so, whats the state of play at the moment??
Evolution6972
PostPosted: 01:37 - 27 May 2013    Post subject: Cables Reply with quote
I know it's off topic but does anyone know a good place to gt really long cables since I need a shifter cable like arun 5-6 feet
Shaft
PostPosted: 09:41 - 27 May 2013    Post subject: Re: Cables Reply with quote
Google 'bowden cable'; you can get kits to DIY, or have them made any length you want.
kartl
PostPosted: 01:06 - 28 May 2013    Post subject: Reply with quote
If its not the compression it could be the valve seals that is why is producing white smoke. Also check the oil it may also be a busted head gasket.
The last post was made 12 years, 205 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.65 - MySQL Queries: 13 - Page Size: 86.45 Kb
