| Biker1977 |
 Biker1977 Renault 5 Driver
| P. |
 P. Red Rocket
| nowhere.elysium |
 nowhere.elysium The Pork Lord
| DrDonnyBrago |
 DrDonnyBrago World Chat Champion
| Biker1977 |
 Posted: 07:18 - 16 May 2013 Post subject: HONDA CBR 2000 won`t Start |
Thank you so much guys for your reply ,,you wright I meant bump start it ..silly me ..
if you let me.. just a last damp question, I looked under seat and I can`t work out how to get the battery out ...how easy it is ? and if there is a video out there specific to this model ( I can t find it so far ) to point out for me that would be great!! ..
Thanks again ____________________ Honda CBR1100 |
| DrDonnyBrago |
 Posted: 09:02 - 16 May 2013 Post subject: Re: HONDA CBR 2000 won`t Start |
Undo the two clips on the battery cover, lift the cover, undo the neg (black wire) terminal first, then the pos (red wire) terminal, lift the battery out.... |
| Biker1977 |
| map |
 map Mr Calendar
| Biker1977 |
 Posted: 12:18 - 19 May 2013 Post subject: Re: HONDA CBR 2000 won`t Start |
Thanks for the extensive Answer, I ended up ordering Roxter Motorcycle Battery Trickle Charger Motorbike Scooter Optimiser from
Amazon, and I also managed to get the battery out like a big boy
Thanks all for the useful advises. ____________________ Honda CBR1100 |
| FireStorm-X |
 FireStorm-X Nitrous Nuisance
 Posted: 14:14 - 19 May 2013 Post subject: |
Bike charger is a must, not a car charger cooked a new bike battery that way already silly me  ____________________ Lexmoto Street 125 (sold) - Kawasaki ZR7S |
| Biker1977 |
| Ripp3rCrust |
 Ripp3rCrust Nitrous Nuisance
| mudcow007 |
 mudcow007 World Chat Champion
| Biker1977 |
| Aff |
 Aff World Chat Champion
| mudcow007 |
| Pete. |
 Pete. Super Spammer
 Posted: 13:22 - 24 May 2013 Post subject: |
To be healthy a battery needs to have sufficient voltage and capacity reserve. A battery charger can report a healthy battery by measuring the feedback voltage but a heavily sulphated battery can have this voltage but no capacity or 'store of energy' to do any work.
If you have used that conventional charger on your battery, then even if it WAS healthy it probably now isn't. It depends on the type of battery.
Yours displays all the signs of the battery being knackered. The tests outlined above can give you a good indication, but if you think your battery is ok you can check the charging system by putting a meter over the terminals and running the engine. You should get somewhere between 14 and 15 volts at the battery at 5000rpm. If you're seeing this, the battery is knackered for sure. If you're not it could be the charging system. 90% chance it's the battery. ____________________ a.k.a 'Geri'
| Biker1977 |
| Aff |
| whitedevil |
 whitedevil World Chat Champion
 Posted: 16:39 - 24 May 2013 Post subject: |
Test the rec/rec and stator before wiring up a new battery or you may end up killing it. Reg/recs are a common thing to go on Most older Hondas. I had to replace mine on my cbr600 2002
https://www.electrexworld.co.uk/pdfs/Troubleshooting-3P-PMG-&-RR.pdf ____________________ GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R |
| DrDonnyBrago |
| Vincent |
 Vincent Banned
The last post was made 12 years, 208 days ago. Instead of replying here, would creating a new thread be more useful? |
