shimming carb needles
madmax123
PostPosted: 15:12 - 21 May 2013    Post subject: shimming carb needles Reply with quote
I have done some research and decided to give it a go, I am mechanically minded and know exactly what I'm doing, my question is where would I get the shims, .020 3mm ID apparently for best results (ZZR600e)
I'm assuming ID is internal diameter, so the size of the hole, of I'm wrong please correct me.
Also what are the upsides and downsides of doing this and how will it effect fuel consumption?
if the're is already a thread with answers to these questions then please direct me to it.
Thanks
PostPosted: 16:14 - 21 May 2013    Post subject: Reply with quote
If you are experimenting I would punch them out of gasket paper. Gasket punches are cheap or easy to make, plus one sheet of paper is a lifetime's supply.
0ddball
PostPosted: 16:23 - 21 May 2013    Post subject: Reply with quote
Why are you doing it? Because the bike running lean in the appropriate part of the rev range or just because you're bored and there's nothing on the tv?
ZXR750L
madmax123
PostPosted: 17:11 - 21 May 2013    Post subject: Reply with quote
I'm doing it because my throttle response isn't great and to gain more mid range, I have done eveanything else to stop the throttle lag and this seems to be worth a try
lihp
PostPosted: 17:13 - 21 May 2013    Post subject: Reply with quote
It's difficult to get fuelling right when not in the correct hands. But to try and adjust random carb settings will result in headache and less than ideal results.
Carb tuning requires clear, methodical steps to obtain the best performance out of your set up.
I have a good guide, but will have to wait till I get home to post it
Fizzer Thou
PostPosted: 21:29 - 21 May 2013    Post subject: Reply with quote
Lack of correct throttle response can be due to all sorts of problems.
Air filter
Worn spark plugs
Faulty spark plug caps
Low compression
Worn cam chain
Excess oil in crankcase
Incorrect air screw settings/tiny 'O' ring split/tip broken off
As has been said,making the mixture richer for the duration of the needle will not have any effect on throttle response from tickover up until about 1/3 throttle.
Always have a 'Plan B'
The last post was made 13 years, 52 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.53 - MySQL Queries: 16 - Page Size: 50.36 Kb
