Engine Oil: Vacuum or Pressure
Ilyin
PostPosted: 19:13 - 22 May 2013    Post subject: Engine Oil: Vacuum or Pressure Reply with quote
Changed the oil today but my torque wrench didn't seem to do it's job, the plug got as tight as I "felt" it needed to be.
So when the engine's running, will the oil be held in under vacuum or will it be forced out under pressure if my hands are wrong and it wasn't tight enough?
Islander
PostPosted: 20:45 - 22 May 2013    Post subject: Reply with quote
Ask Andym what happens when you don't tighten a sump plug. Laughing
ETA:
In fact...
https://www.bikechatforums.com/viewtopic.php?t=269618&start=0&postdays=0&postorder=asc&highlight=sump+plug
Ilyin
PostPosted: 20:52 - 22 May 2013    Post subject: Reply with quote
I'll get the fitters in work have a look at the torque wrench tomorow, to see whether it's finctioning properly.
I thought it felt tight, I certainly could have give it a bit more, but 25nM isn't much at all, so I'm convinced it's tight enough.
I'll check it when I get to work after it's been ridden too.
Ilyin
PostPosted: 15:19 - 23 May 2013    Post subject: Reply with quote
Torque wrench works fine, it needed half a turn more.
Still, best to be safe than sorry before knackering the thread.
Thanks all.
The last post was made 13 years, 75 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.55 - MySQL Queries: 16 - Page Size: 50.04 Kb
