What happened here then?
Jonathan A
PostPosted: 22:37 - 08 Jun 2013    Post subject: What happened here then? Reply with quote
I was going along a duel carriageway earlier this evening at a normal speed in the left hand lane. I saw a little blue car going very slowly, waiting to pull out of a slip road. I assessed the situation; couldn't change lanes, and the car behind was too close to make it safe to slow down to a slow enough speed, so I kept going. As I got close the car, it began to pull out Shocked at this point the only safe thing to do was accelerate and swerve round it. As I went round it, the driver beeped at me Confused
For the next two miles or so the car was behind me flashing at me. To try and get away I turned off at the next village...the car kept following me, still flashing it's headlights. When I turned onto a housing estate, it drove past whilst beeping the horn.
The only thing I can think of is that the driver was drunk, had no grasp of the highway code, or was just in a bit of a state Confused I'm still trying to think what I might have done wrong (I checked my headlight was working).
I am aware that the forum is flooded with posts like this, But I am genuinely confused Embarassed
PostPosted: 22:39 - 08 Jun 2013    Post subject: Reply with quote
You encountered a nob.Clapping
Ignore and carry on.
Jonathan A
PostPosted: 22:53 - 08 Jun 2013    Post subject: Reply with quote
I have encountered many a nob in my year on the road, but never such nobbery as this! I really am convinced that I did something wrong
J.M.
PostPosted: 22:56 - 08 Jun 2013    Post subject: Reply with quote
You were obviously travelling at 9000mph and almost crashed in to the side of his car, you disgraceful person you.
What you did wrong was not stopping and force feeding his horn to him and shoving his headlight bulbs up his arse. Very Happy
2004 R1 & 2018 XSR900
Jonathan A
PostPosted: 22:59 - 08 Jun 2013    Post subject: Reply with quote
Two nobs don't make a well...right. I dont think Confused It was my right of way however one would look at it I suppose
Huambo81a
PostPosted: 23:30 - 08 Jun 2013    Post subject: Reply with quote
What size bike do you ride?
Present: 2017 KTM Super Adventure S
Past: 97 Bandit 600 / 05 Bandit 1200 / 03 ZX6-R / 2006 Tuono R / 2001 VFR 800 / 2010 Street Triple R / 2013 Speed Triple S / 2017 S1000XR
Jonathan A
PostPosted: 23:40 - 08 Jun 2013    Post subject: Reply with quote
It's a 650 v twin, with a stupidly loud exhaust, which could have been an aggravating factor
Huambo81a
PostPosted: 23:45 - 08 Jun 2013    Post subject: Reply with quote
Ah ok. My response WAS going to be that this probably happens to us all, but when you are on a larger bike you don't notice because you're fast as fuck. But you are on a large bike.
Just a knob I guess. Did you cut back in front of him at all? Not that this would justify his wankerness.
trevor saxe-coburg-gotha
PostPosted: 23:49 - 08 Jun 2013    Post subject: Reply with quote
Maybe he took umbrage at your tweed blazer?? I personally consider it a quite elegant piece of attire - though a little on the drab side, if I may be so bold. Mr. Green
But if you really want to know what happened here then I do actually think I can tell you. What happened was that you came across an actual dyed in the wool tosser that required a good, solid throat punching and a swift right hook to the ball bag with an armoured biking glove.
Jonathan A
PostPosted: 23:50 - 08 Jun 2013    Post subject: Reply with quote
I didn't cut back in I dont think, I passed along side the car, which came to a stop after I avoided it
Pretty much this.
Couple of points:
I can't think of any time that I checked my mirrors and thought it was not safe to slow down. Onus is on the guy behind etc and generally, they will slow if you do, especially since they will also have seen the car on the slip road.
Be more pre-emptive. Where did you think that car was going except into your lane? If you couldn't slow down as you say, you could have speeded up to get past the car before it needed to join.
Oh, if you're getting buzzed by a nutter - stay on the busy road where there's witnesses. Don't go turning off and get stuffed into a hedge when there's no-one around.
Huambo81a
PostPosted: 00:08 - 09 Jun 2013    Post subject: Reply with quote
Pretty much this.
Couple of points:
Have to agree.
It's a cliche, but ride like you're invisible. In every situation have an escape route, and if in doubt knock off some speed and be prepared to GTFO of there.
I have succumbed to the red mist before, where I was made so angry I lost my judgement and calm. This resulted in a tank slapper which I managed to save with luck (although somehow scraped the INSIDE of my knee) I stopped and gave myself a massive telling off. I was a dick.
So yeah, there really are some pricks out there.
Jonathan A
PostPosted: 00:33 - 09 Jun 2013    Post subject: Reply with quote
It is a stylish number Wink doesn't suit by bike though Sad I'm thinking of lining on with kevlar and adding armor Razz
Very helpful advice btw even though it was 'my right of way' there is always room for rider improvement Thumbs Up
suburban myth
PostPosted: 06:30 - 09 Jun 2013    Post subject: Reply with quote
Shoot him. Move on.
bodger
PostPosted: 08:52 - 09 Jun 2013    Post subject: Reply with quote
Too many car drivers try to join dual carriage ways and motorways much too slowly without trying too match the speed of the flow. The onus is on the vehicle on the sliproad to slot in without causing other vehicles problems. The offending blue car in this case made a bollocks and put you in a potentially dangerous situation.
If there was no other way to avoid a collision you were probably right to overtake. Difficult I know somtimes with cars overtaking you on the outside lane.
Having come across the same situation myself over the years follow above advice and ignore the tosser and watch out for the dreaded red mist. Can be fatal.
The last post was made 13 years, 116 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.96 - MySQL Queries: 16 - Page Size: 90.71 Kb
