Balancing carbs
The Disapproving Brit
PostPosted: 22:51 - 22 Jul 2013    Post subject: Balancing carbs Reply with quote
My engine is 'not quite right' - it's running rich, idling too low, and taking too long for revs to die off, which from what I gather, calls for a carb clean and balance as a starting point. I've had a read up and think I know the gist of how to go about doing this. Just one question - for a 4 valve carb, do I need the 4 set of vacuum gauges, or can I just use the one and move it from carb to carb? For the sake of the £30 difference, does it make more sense just to get the 4 set anyway?
Current Bikes: 1983 Honda VF400FD / 2003 Honda VT750 Shadow
Bike Test Passed 18/03/09, Car Test Passed 14/05/13
Ichy
PostPosted: 22:58 - 22 Jul 2013    Post subject: Reply with quote
You need a minimum of two to allow you to balance as pairs. Two left, two right, middle two. You really should check the air filter and check and adjust the valves first.
I think you need to read a bit more before you attempt it Wink
andym
PostPosted: 23:08 - 22 Jul 2013    Post subject: Reply with quote
All you need is a few meters of 5mm plastic tubing and some fork oil (or other thick liquid), probably cost a couple of quid for the tubing
PostPosted: 23:19 - 22 Jul 2013    Post subject: Reply with quote
Oil filter and air filter are both being replaced as part of the same job. 2 gauges takes the difference to about a tenner, so I might as well plump for the 4 set. Bike is off the road for a while until all the issues are sorted, so I've got a bit of time to iron out any gaps in my knowledge.
PostPosted: 23:20 - 22 Jul 2013    Post subject: Reply with quote
This sounds very unscientific....I'm intrigued.
whitedevil
PostPosted: 23:37 - 22 Jul 2013    Post subject: Reply with quote
Google manometer
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
Ariel Badger
PostPosted: 23:38 - 22 Jul 2013    Post subject: Reply with quote
They are called " manometers" and are far more accurate than a man made pressure gauge ( especially if the man that made them lives in China) as they work on the principle of pure physics not man's mistakes.
Google "manometers".
Edit..... Beat me to it!
johnsmith222
PostPosted: 23:41 - 22 Jul 2013    Post subject: Reply with quote
personally, I appreciate the ability of seeing all 4 levels at the same time and for me it is worth the extra money for a tool I should have for life.
I'd recommend the morgan carbtune.
Fizzer Thou
PostPosted: 00:03 - 23 Jul 2013    Post subject: Reply with quote
I have owned a set of four gauges for many years and need little or no maintenance apart from taking care not to knock or drop them.No fiddling around with Mercury.
If the gauges look like this
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture561.jpg
Then the carbs need balancing to something like this
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture566.jpg
While performing this operation I use an external fuel supply
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Workshop/Picture564.jpg
Works a treat Thumbs Up
Always have a 'Plan B'
johnsmith222
PostPosted: 00:20 - 23 Jul 2013    Post subject: Reply with quote
This method is SO much better than trying to balance your fuel tank on your seat backwards and all the similar related pissing about that goes on. I really need to make or buy one of those fuel tanks at some point. Thumbs Up
lihp
PostPosted: 01:25 - 23 Jul 2013    Post subject: Re: Balancing carbs Reply with quote
Are you sure?
Revs that hang high before dropping is usually a sign of lean running rich mixtures tend to bog down below idle when the throttle is closed.
PostPosted: 09:17 - 23 Jul 2013    Post subject: Re: Balancing carbs Reply with quote
PhilDawson8270 wrote:
Are you sure?
I thought lean - it's very quick to stall if there's no choke even after a long ride. But there's a strong smell from the exhaust which I'm told means it's running rich.
Whichever it is, cleaning and balancing the carbs, then resetting the idle from scratch, should be the answer, right?
lihp
PostPosted: 10:13 - 23 Jul 2013    Post subject: Reply with quote
I'd also be inclined to set the idle mixture screws back to factory if it's an idle issue/easy to stall
PostPosted: 20:45 - 23 Jul 2013    Post subject: Reply with quote
That's the plan. I learned that it was sat in a yard for a few years before I bought it, so it probably had just enough work done to get it to run well enough to sell. That being the case, it's due a bit of TLC to restore a bit of its former glory.
gavbriggs
PostPosted: 20:51 - 23 Jul 2013    Post subject: Reply with quote
Rather than balance the tank somewhere on the bike, would it not be common sense to just buy a length of fuel line and an inline filter. Then the tank can go somewhere more secure?
Tubes need to be longer (or use less fluid) - I had some problems with the fluid going over the top loops when it was too imbalanced.
https://www.bikechatforums.com/download.php?id=80586
Fizzer Thou
PostPosted: 23:07 - 23 Jul 2013    Post subject: Reply with quote
This ebay product is very similar to what I utilise
https://www.ebay.co.uk/itm/NEW-AUXILIARY-SPARE-FUEL-TANK-ENGINE-TUNING-GASGAS-MOTOCROSS-ENDURO-TRIALS-/190812332608
The last post was made 13 years, 92 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.02 - MySQL Queries: 16 - Page Size: 100.26 Kb
