| conpants |
 conpants Spanner Monkey
| divuk83 |
 divuk83 World Chat Champion
| conpants |
| Frost |
 Frost World Chat Champion
| Kickstart |
 Kickstart The Oracle
 Posted: 17:53 - 08 Dec 2004 Post subject: |
That is only 20mpg at best, so yes I would expect it to be doing rather better than that.
First guess would be that the choke is partially on, but if it is the same carb as the RS50 then I think this would also massively reduce performance.
As the air filter is missing then maybe someone has fitted a silly size main jet to try and compensate. Think the RS uses a 63 main jet, with a 68 when derestricted.
The air filter is probably the same as the RS50, and as such is just a 6" x 6" piece of foam. Send Craig_ a PM as he might well be able to supply one (best off taking a piccy of the airbox and sending that to him as well).
Doubt you will easily find an aftermarket exhaust these days. A RS one might fit but you would need to check the shape carefully (think the basic frame is the same, but whether they moved the exhaust mounts I do not know, or if the engine is the same one).
| pipnet11 |
 pipnet11 Brolly Dolly
| mr.z |
 mr.z World Chat Champion
 Posted: 22:03 - 08 Dec 2004 Post subject: |
No air filter can cause MASSIVE problems, small bit of dirt in pistons = fecked engine. quite amazeing your got away with it for so long...
My guess somebody clever decided to take it off and then told all his mates that it goes 120mph. as a horrible temporary fix try putting some tights over the space where the filter should be, idealy dont go anywhere till you get a new filter! (even a filter from the breakes would do for now)
Scooters are for keeping till you can get something else imo, spending any more than will keep them screeching along is a waste (unless you realy want to keep it at 17+)
Good luck  ____________________ >RidingSkills<->Tech Tips<->MyBikes< |
| conpants |
 Posted: 22:55 - 11 Dec 2004 Post subject: |
i have spent alot on this bike, and im 17 next month, i just really love it, my little sports rep  |
| clemsta |
 clemsta Scooby Slapper
 Posted: 15:06 - 12 Dec 2004 Post subject: |
There is a company on ebay called Top Banana Racing which do chrome cone filters like a K&N, all you need to do is give them the diameter of the carb inlet and they will get you one to fit. I think they only cost about £9 delivered.
https://stores.ebay.co.uk/Top-Banana-Racing
Hope this helps
Adam ____________________ SOMEONE CALL THE DOCTOR! I've got 2 stroke fever!!!
OGRI - Stuff everything, i've always got my bike!
DAS Passed - 7/6/06 |
The last post was made 21 years, 271 days ago. Instead of replying here, would creating a new thread be more useful? |
