Fuel pump question
rande
PostPosted: 21:43 - 08 Dec 2004    Post subject: Fuel pump question Reply with quote
It seems the fuel pump on my 01 R1 is faulty,I think caused by myself getting the wires round the wrong way while giving it a live feed.
I seem to have shorted it out,is there anyway of getting this fixed or is it for the bin??
Retro-Man
PostPosted: 00:04 - 09 Dec 2004    Post subject: Reply with quote
check fuses 1st
then apply direct feed to the pump (the right way round this time though) Wink
if pump runs then suspect blown relay etc.
if pump does not run new pump required
Retro
https://domharnessphotography.webs.com
BLOFLY 636
PostPosted: 08:38 - 09 Dec 2004    Post subject: Reply with quote
yes! exactly as retro man says hopefully it is just the fuse or relay and not the pump Thumbs Up
Those bloody footpegs......they ought to do away with em!
rande
PostPosted: 15:19 - 09 Dec 2004    Post subject: Reply with quote
'tis not the relay or any fuses
Can the pump be repaired??
BLOFLY 636
PostPosted: 15:41 - 09 Dec 2004    Post subject: Reply with quote
check what the reistance is across the fuel pump electrical windings or if it has not open circuited between connections Idea
Fortuna
PostPosted: 20:09 - 09 Dec 2004    Post subject: Reply with quote
DOH!
You may be lucky. As the others said check it with a direct feed.
Fortuna
PostPosted: 20:14 - 09 Dec 2004    Post subject: Reply with quote
Want me to get you the ohmage readings of what it should be?
All the advice in the world can never account for human error. Laughing
Ah well at least you have the diagram so you know where everything goes.
If it is broke ring a few breakers yards as you can get them quite cheap from them. They are not a part that has changed over the models so you should be ok Thumbs Up
The last post was made 21 years, 244 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.11 - MySQL Queries: 16 - Page Size: 52.67 Kb
