Back protectors
henry hoover
PostPosted: 21:09 - 27 Jul 2013    Post subject: Back protectors Reply with quote
Im probably going to pick one of these up tomorrow. I will be using it on the street and on the track.
My jacket has got a slot to put a back protector in. But are the ones that you wear under your jacket better
https://www.hein-gericke.co.uk/clothing/dainese-wave-air-ruckenprotektor-13-air-schwarz.html
Cbr600rr 2010 Sold
Zx6r 636 2006 sold
Gsxr 750 L1 current
-Matt-
PostPosted: 21:26 - 27 Jul 2013    Post subject: Reply with quote
This would be best overall. They sit and secure much snugger and safely - back pocket ones have a tendancy to shuffle about a bit which in an accident isnt what you want. Also they generally are harder to find good fitting/higher spec ones [dainese one being the best at level 2].
Also ones like the one you linked tend to be slightly longer on average which gives a bit of additional protection particulary if you aren't all that tall.
The only downside is the cost really - but then its worth it without doubt if you have the budget.
You can get a decent slot in level 1 protector like this
https://www.ebay.co.uk/itm/like/161072163166?device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=83
For as little as a tenner - but if you can afford it , go for it - especially if you're going to be going on track i'd not even consider a level 1 to be honest.
henry hoover
PostPosted: 21:37 - 27 Jul 2013    Post subject: Reply with quote
It does look pretty secure.
I didn't realise the slot in ones can move about that kinda defeats the object Thumbs Down
Cbr600rr 2010 Sold
Zx6r 636 2006 sold
Gsxr 750 L1 current
-Matt-
PostPosted: 21:42 - 27 Jul 2013    Post subject: Reply with quote
Its not like a guaranteed thing but its a lot more likely - i'm very skinny and for example i have a jacket thats leather not some tight-zipped racing style one just a casual 'old school' kind of look jacket if you can picture what i mean, and my back protector in that if you really bash the side of it can move almost a quarter of the way across my back - so me vs curb = bad Rolling Eyes
Before you go and get that one i'd have a quick look at alpinestars ones they may be a tad cheaper, maybe not but worth a lot both equally good standard.
There are also for a tad more some [alpinestars i know do it at least] chest armour incorperating 'vest' versions of those style back protectors if you want to really go all out for the track - again, if you have the money for the extra bit on top i'd consider it definately.
pits
PostPosted: 21:49 - 27 Jul 2013    Post subject: Reply with quote
not looked at the link, but I've got the Knox one because it isn't a stiff board, it bends with your back and is supposed to cushion etc.
henry hoover
PostPosted: 22:05 - 27 Jul 2013    Post subject: Reply with quote
Yeah I'll check it out I should have looked into it quicker really I've got a track day booked in on Tuesday and I really don't wanna go without one Thumbs Up
Cbr600rr 2010 Sold
Zx6r 636 2006 sold
Gsxr 750 L1 current
-Matt-
PostPosted: 22:13 - 27 Jul 2013    Post subject: Reply with quote
Worst case divert via a bike shop on route to the track and get any old level 1 budget one, better that than nothing temporarily.
Could even be cheeky and return it after the day if they accept 'bad fitting' Rolling Eyes not to condone such horrendous behaviour...
PostPosted: 23:03 - 27 Jul 2013    Post subject: Reply with quote
What are you basing this on?
Is it purely the next part of your paragraph?
Why is the Dianese 'the best' at level 2?
The level 1 / 2 thing is new to me.
I found this. Note the bits I've bolded.
Judging from this quote, it would seem Lvl 1 provides more protection?
European Standard EN 1621-2:2003[2] defines two levels of performance for CE approved back protectors. The test apparatus and procedure is similar to that of EN 1621-1:1997,[1] but with a different impactor and anvil configuration. The impactor is a rounded triangular faced prism, of length 160 mm, base 50 mm, height 30.8 mm and radius 12.5 mm. The anvil is a radiused cylinder, with its axis orientated to the direction of impact, of height 190 mm, diameter 100 mm and rounded end radius 150 mm. When tested to the procedure defined in the standard, the two levels of performance are:
"Level 1 protectors: The average peak force recorded below the anvil in the tests shall be below 18 kN, and no single value shall exceed 24 kN.
Level 2 protectors: The average peak force recorded below the anvil in the tests shall be below 9 kN, and no single value shall exceed 12 kN."[2]
Back protectors are often not included in the standard complement of armor although many jackets allow a back protector to be installed.
Because of the more delicate nature of the spinal column, back protectors require that lower levels of force be transmitted. The introduction to EN 1621-2 states that approximately 13% of motorcyclists injured in road accidents have an injury to this back region. However, only 0,8% of the injured riders suffer a fracture of the spine and less than 0,2% of injured riders have a serious back injury resulting in neurological damage. This is supported by evidence from the MAIDS Report (2004), the most comprehensive in-depth data currently available for Powered Two-Wheelers (PTWs) accidents in Europe. Serious spinal injures are usually caused by axial forces due to blows on the head, or bending and twisting forces on the back caused by blows to the shoulders, hips and other parts of the body. In the Cambridge Standard for Motorcyclists Clothing, Roderick Woods asserts that the majority of spinal injuries are caused by blows to the hip and shoulders. In the rare circumstance that a motorcyclist received a direct blow to the back the damage would be unmitigable by armor. The concept of a "back protector" is therefore not endorsed by Woods. Although back protectors, as defined in the standard, cannot protect against axial forces they are required to protect the scapula and there is now considerable anecdotal evidence that wearing a certified back protector can significantly reduce trauma in a major accident as they reduce the effect of impacts on the ribs and lessen the blows to internal organs too.
There's anecdotal evidence that if you like riding twins, it's because your dick has shrivelled up.
Even I wouldn't use that sort of 'evidence' as a reason not to ride twins!
Also, quite possibly make it more likely that you'll break your neck.
How did you work that out?
Why not?
Joncrete Cungle
PostPosted: 23:10 - 27 Jul 2013    Post subject: Reply with quote
The protectors with aluminum honeycomb structure in them will not imho offer the same level of protection once the back protector has suffered one hefty impact and the aluminum honeycome structure is bent and deformed.
Based on doing a bit of 'surgery' on one after a friend crashed while wearing it.
-Matt-
PostPosted: 23:13 - 27 Jul 2013    Post subject: Reply with quote
You don't seem a fan of my posts lately or maybe its just me Rolling Eyes
I'll do it by quote as i'm on the phone - not trying to be blunt.
1/2/3 - Based initially on what i said yes about the strap securing and as mentioned being skinny i've found many back pocket ones totally inadequate and probably near useless in an accident for my frame.
I didn't claim they would protect against a direct blow to the back if i've correctly understood your point on the big paragraph Confused
4 Longer for me has meant it covers more of the lower back - not at any time the neck, vs some back pocket protectors which as someone whos quite tall barely cover the majority of my back you'd expect to be protected by a back protector - of course this is open to differences between rider but it was a generalisation based on my experience of the size vs height - maybe too generalised Question
5/6 If you have the money - why not get the best, i'm admittedly probably more safety cautious than a lot of people doesn't mean its right to be or i'm right by any means - but if moneys 'not an object' and you want protection - why not get something better suited that adequately protects you vs something ill-fitting or otherwise.
PostPosted: 23:38 - 27 Jul 2013    Post subject: Reply with quote
I'm not a fan of people that offer advice which seems to be more like conjecture or gossip.
If you have good reasoning behind the advice you're offering, do feel free to provide it Smile.
Otherwise, expect to get pulled up if it's just guesswork packaged as knowledge.
I meant to mention - if one in a jacket is moving about, it suggests it's either not right for the jacket (I suspect some velcro would hold it in place) or that the jacket is a poor fit. If the jacket is a poor fit, personally I'd be trying to sort that first.
I suspect that a better fitting jacket will do more in most situations than a back protector.
What exactly do you think a back protector is going to do that you think they are 'near useless in an accident' if you don't think they're going to protect against a direct blow.
From what I can tell, they are tested with a direct blow and that's what the level 1 vs level 2 test is about. You make a big thing of suggesting a level 2 is needed, when the difference between the two is that the level 2 is how it deals with a direct blow.
I haven't seen the results or conclusive evidence, which is why I made a point of using the word 'possibly', but; a back protector, especially a separate one held on with elastic straps can easily ride up in an accident. I'm presuming this is a case where the body is arched outwards.
So your lower body pushes the back protector up, at which point the rigid item can interact with your neck as your arched body bends backwards.
Wouldn't be an issue with in-leathers ones where the leathers are one piece or securely zipped together (note I said securely, rather than, say, zip together systems of Dianese quality!)
Your answer to the last point does not answer my questions.
Ok, it does answer my question if you are of the believe that more money must mean better? Is that the case?
If not, care to answer the questions?
I appreciate Dianese might feel nicer when you wear it - but I'm presuming you're not claiming you'd know the same for the OP.
Finally - I believe you'd said you hadn't done a trackday.
It might be worth doing one before offering advice on them!
Me, if someone had £130 to spend and wanted to be safer on track and the road, I'd suggest they buy a copy of motorcycle roadcraft and book a double-day trackday.
Motorcycle roadcraft they can learn to avoid crashing on the road and having two days on track means they can really focus on progressing slowly, so they don't crash.
Safety concious to my mind means actually knowing what will make you safer; not just throwing money at shiny brand name things and telling yourself it will all be happy-la-la.
Of course, safety cautious is a different concept and one I've not heard before Wink.
-Matt-
PostPosted: 23:52 - 27 Jul 2013    Post subject: Reply with quote
First thing fair enough, no issue with being questioned just has felt everything you've commented on has been to dispute my points but i guess thats justified from how i'm coming across by the sounds of it so no problem Thumbs Up
The jacket fitting thing is a fair point, but the jackets do fit me [as best they can at least] as mentioned i'm very 'lanky' for want of a better word, which makes sizing extremely difficult - maybe its things like this i need to include with what i'm saying to make it more relevant to others Question
The 'near useless in an accident' i believe i mentioned regards it slipping in a bad fitting jacket Question If so it was because the level of slippage at some point of my back would leave it virtually open to impact with whatever surface at some points, again defeating the point of it.
As you rightly say the tests are done on a 'direct blow' basis, but this still impacts the dispersal of none-direct blows - to cover myself i'll go with speculation on this point, but there can't be a magical centre point at which it takes a blow and everything outside that remains unaltered surely Confused
It is possible they can ride up in some cases i'm sure, but no less than a pocket one could so although a risk i don't think its any more risk, the 'strap on' longer ones have never been below my lower spine to a point that they'd hit the contact surface and quicker than a pocket one causing it 'shoot up' towards the neck etc.
And yes i haven't ever done track day, i don't claim to of though to be fair - i'm going by friends advice - okay maybe a few peoples advice doesn't mean somethings correct i'm just sharing knowledge i've come across, it'd be no more accurate from me having done a track day than it would my collective friends who have, its just opinion and speculation ultimately whoever its from.
It would seem i'm being far too unclear in my explanations perhaps, or more speculations and opinions that aren't made clear to be that Razz
That one i will give you, hands down, lapse of mind Wink
Deadringers
PostPosted: 23:57 - 27 Jul 2013    Post subject: Reply with quote
OP i bought this one about 6 months ago:
https://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/63236
fits well and I can wear it under leathers or summer jacket.
thankfully not had to test it out yet but I believe Knox have a good reputation .
2010 R6 - Love it
PostPosted: 00:17 - 28 Jul 2013    Post subject: Reply with quote
If you have trouble getting clothing to fit, I'd suggest you look at getting some altered to fit.
For under £100 for a set of second hand one piece leathers and £100 to have them altered I've had a set of 'made to measure' leathers a lot cheaper than it'd cost to get them actually made to measure.
Maybe we're reading 'direct blows' differently. My reading of it from the bit I put in bold suggests that a back protector won't help stop your back from being injured when you hit something (or something hits you.)
They suggest I believe that it's possible that an impact could help mitigate some damage to other parts of the body. However, I'd suggest if this was your intention, that it would quite possibly be better to look for generally licker jackets - some textile jackets have very wide areas of strengthening across the back.
I don't think they are suggesting that this will help mitigate damge to your back from a blow elsewhere.
One in a pocket with leathers held on is much less likely to ride up than one on a strap, I'd say (having had each type and crashed in each) - as opposed to usually being held on with thin elastic staps, the ones in leathers are held on by thick and relatively inflexible leather.
What TC I believe had mentioned in the past was specifically related to hard ones worn separately.
-Matt-
PostPosted: 00:26 - 28 Jul 2013    Post subject: Reply with quote
If pricing is as mentioned that would definately be of interest, but would you say the alterations weaken the initial structure of the leathers or was that having them re-done as they would be in the factory from scratch anyway Question
Regards the direct blow i've always considered that to be anywhere across the back-protectors 'plate', and subsequently [as per the testing point], the further from the centre the less it disperses any impact.
Maybe thats total bollucks of course Laughing
Back protector wise, i've only ever crashed in the 'strap up' style which in that instance didn't ride up, but thats one instance so can't comment on it really. I would wonder though, surely with both being 'inside' the leather, whatever would cause the strap one to ride up would also naturally cause an inpocket one to ride up, as for it to move up the external leather must be moving also in that direction i would of thought Confused Question
PostPosted: 00:47 - 28 Jul 2013    Post subject: Reply with quote
My trick was to buy one a bit too big, so it had to be altered down.
With that and someone that knows what they're doing, it should be as strong as the original garment - maybe even stronger if they're good and the original isn't - as you're just taking a bit out and redoing the stitching on a fresh piece of leather.
If you need to get stretch panels sewn in, then you may be losing a bit - however they should only put them in places where it won't be an issue.
I was certainly fine crashing multiple times at high speed when racing in mine.
From what you're saying, I'm still not seeing why you think they're such a good idea?
You say, I believe, that you appreciate they're not considered to be worth it for protecting the back.
So do you only think that "its worth it without doubt if you have the budget" for the anecdotal evidence they may protect other parts of the body?
In my experience a strap on back protector can move around a fair bit under the leathers - I've certainly been able to reposition them fine and move it a fair bit with my leathers on. So, it's limited by how much the straps move - and with them generally being elastic, that's a fair bit.
However one in a pocket is limited by how much the leather moves, which is generally a lot less.
-Matt-
PostPosted: 00:54 - 28 Jul 2013    Post subject: Reply with quote
I could 'shuffle' mine but i'm not sure it would nescessarily slide up beyond the neck, it could perhaps skid around over my back i'm sure, but the push to get it to bump up above the neck considering the shape i'd be dubious of - again to be clear, not ruling it out, and if anyones seen otherwise i'll sit back down Razz
Somewhere one of us has lost each other totally on this point, no blame needed Laughing I do think they're worth it for the back - I think they're ONLY really of value to the back, i don't expect them to protect other parts of the body. You can still get severe back damage from side impacts so i dont doubt it doesn't 'protect the back' without question should it stand up to an accident, but yes i think they're a key part in back [spine particularly protection in face on impact]
Maybe you misread/i misexplained the point of it 'dispersing the impact' Question That was refering to an impact on the back protector and how a central-protector hit vs an outer-protector hit would displace more impact force.
Otherwise i'm lost in the sea of text and need quote-guideance i think Laughing
PostPosted: 01:09 - 28 Jul 2013    Post subject: Reply with quote
This is from the introduction to the standards test, which in your initial post you held with some importance:
So, just to clarify.
The standards document for testing this kind of armour states that it isn't useful for the designed purpose.
I'm not sure if you're suggesting it would save you if the impact was away from the spine, but still over the armour.
I suspect if anything it would introduce force to the spine where otherwise there wouldn't have been - ie you may not get your ribs cracked so bad, but may get your back broken instead Smile.
(When I fractured a bit on my shoulder I'm pretty sure it was hard armour that did it - however it did save me from a nasty sharp rock, judging by the gouge out of it - this was riding off road.)
-Matt-
PostPosted: 01:18 - 28 Jul 2013    Post subject: Reply with quote
The level 2 vs level 1 thing i consider just as a simple 'quality' issue really - if something in 'test 2' takes x-force more than something in 'test 1' i'd go for test 2 - it doesn't at all remove risk or chance of injury by any means but if i'm going to spend on safety i'd go for the next level.
I appreciate this attitude has its calling points like when does it stop, airbag suits, helmets in cars etc etc, but if two things almost identical are available for relatively little price difference in terms of how long i intend to use them i'd rather go for the little extra.
In terms of it being 'back protection' i do mean in the most literal sense that really - it protects 'the back' it absorbs impact to an extent across the region of the back, i wouldn't consider it a BARRIER to back damage by any means, particulary side impacts as i mentioned.
I would say though the one accident i have had i went a good 15 foot over the car and landed square on my back mid slide, and i didn't feel a thing. Again i can't call that as evidence against or for it as its a single case, but had i NOT been wearing a back protector in that instance i'm damn sure my back would of been in a dreadful state - but i'm not saying that proves or disproves anything in the larger more technical picture, thats just my only personal experience of them coming into play.
barrkel
PostPosted: 01:31 - 28 Jul 2013    Post subject: Reply with quote
G has a bit of a thing about back protectors, as TC does as well re non-foam. TC blames expensive boots for putting his foot into an amputatable state, leaving him 25% disabled. One of the risks of harder armoured parts is that they transfer the force somewhere else. Ideally, they should simply be spreading the force of impact over time and space, but if they're not fitted correctly, or poorly designed, or you're unlucky with the impact, they might act as a lever, focusing the force.
Some people on here have indirectly reported that it's the initial impact with the road and induced twisting motion that causes most damage. That's consistent with what G quoted too.
However, I also have a bit of time for someone who actually broke their back and ended up paraplegic:
https://www.bikechatforums.com/viewtopic.php?p=2349251#2349251
im not putting down TC's expert knowledge because the bloke's that dealt with me was just that 'experts ' and they was fantasic
but when it came down to why and what had caused me to break my back that was down to the surgeons and the orthopaedic experts and like i said my surgeon told me had i wore one its quite possible i wouldnt be in a chair now [ i dont think anybody can say for sure ]
i dont know what happens in most cases this is just what happend to me
in the last 13 years ive not come across any paraplegic's who have said my back protector is what broke my back and i do meet lots , but in sayin that ive also not met any that say i had one on and still done themself's
most ive met are like me and didnt have one on , but that also doesnt mean there isnt lots out there that are injured because of a protector , just ive not met any
Personally I stick with the stock foam jobbies in my regular jackets, though I do wear a back protector very similar to the OP's link (also Dainese) with my leathers, as they don't have any integrated back protection. I have a different cheaper back protector, but it's not as flexible, nor as breathable, nor as comfortable all-round, so I've never worn it since.
I will say I've also not yet done a track day, nor crashed on one, nor been hit by a bike like G. In any case, I'd be more interested in a small track with more corners and few if any straights - speed has a decreasing interest to me, it just increases wind blast and the consequences if something goes wrong. Also probably part of the reason why I enjoy scooters so much. I'm also afraid it might take away some of the fun I get from riding on the road, much like two visits to Spain has made Essex that bit worse for me Smile
I second G's advice on Roadcraft - primarily increasing your vision down the road using more and more of the clues at your disposal - though I think they overstate some things. When I went on an advanced riding workshop with Nigel Bowers (AdvancedBiker on youtube), one of the best bits of advice I got was from one of the other instructors in the group, about how the safe bit of road narrows the faster you go. That is, the advanced riding style more or less recommends going around the widest bit of every curve to maximize your vision, but when you're going faster, you need to not go quite as wide to give yourself more margin as you no longer have as much time to adjust to close hazards.
PostPosted: 01:45 - 28 Jul 2013    Post subject: Reply with quote
As ever, I generally just question. In this case I'm not really seeing any good justification behind the answers.
To me, it still seems to boil down to a bit of "shut up and take my money".
I do also do my research of course - and I hadn't before realised that they were considered quite so useless. I'm impressed that the very standards used to test them also discredit their use.
When I've got a minute, I'll look up the study - it may be the study it's self wasn't well researched.
While back protectors may absorb impact, it seems that doesn't do much usefully as far as protecting your spine.
As ever with armour, it can not reduce force, it can only dissipate it across space and time.
I've had plenty of crashes where I've landed on my back without a 'serious' back protector and never had an issue from that.
I hear an awful lot of anecdotes of medical people saying "you're lucky you had your gear on". However, this never seems to be in any way substantiated. It seems to be just 'something people say'.
Also, I reckon that more nastier accidents happen on slower corners if anything.
At speed, there's less chance of a highside (but a fast highside can be really, really nasty), less other bikes and less chance of a low side from excess power. Less likely to braking hard and deep in to them.
And the vast majority of tracks have plenty of run off on the faster corners (just not where my brakes failed at Lydden, though that was going in to a slow corner).
However, something like minimoto you're relatively less likely to hurt yourself - as you're already on the floor. I say that, then I remember back to when the minimoto place we go to used to be on a tarmac track. Got a nasty knock to the head when it flicked me off - the current place with polished concrete tends to just see you sliding.
-Matt-
PostPosted: 01:48 - 28 Jul 2013    Post subject: Reply with quote
Interesting points - particularly the thread, quite harrowing Confused
I've always considered the 'increased' levels of protection i.e level 2 vs level 1 to not really be 'harder' as such but more they're ability to disperse the impact be more efficient. The way [the 2 strap on protectors i've had] were made, were to form a sort of concave 'shell' of armour, so any impact would first crack through this layer if strong enough, THEN the force displace over the back - i suppose though this could be the point at which the 'cracked plate' is forced into the back causing more damage Rolling Eyes
I'm sure theres definately cases as you mentioned 'rigid' protection actually causes more injuries, i can imagine something similar with an old pair of Sidi boots i had that were buckled and braced to such an extent although they no doubt protect the ankle and lower foot anything mid-leg impact wise would of near sheered it off.
Its very difficult overall i think even with a few cases behind each side of the arguement to really point-black rule out which side of the arguements right or not. I just see it as a 'shell' personally, that i hope will crack before i do, as with the majority of gear i wear.
If the shell fails, or malfunctions and causes injury then i'm still fucked, maybe even more fucked, but the chances the shell reduces or stops damage to me personally i think outweighs the other options.
-Matt-
PostPosted: 01:53 - 28 Jul 2013    Post subject: Reply with quote
See in hospital i hear this all the time - HOWEVER, to be fair and probably go against my view of things to be honest, it does normally relate to the 'unarmoured' comparisons who are teenagers on scooters.
Now factoring in excess speed, alcohol, stupidity and so forth in a lot of these cases - not to stereotype too much Rolling Eyes - whether its the armour in question that 'saved x-people' is dubious - but i would still stand by the opinion person 1 with no armour vs person 2 with armour is 'statistically' more likely to be hurt severely.
Fifteen15
PostPosted: 06:56 - 28 Jul 2013    Post subject: Reply with quote
This thread and the links have kept me busy for a good hour, really interesting. Shame TC doesn't post anymore, the experience that guy has is phenominal.
What he does't explain though is why he blames his £300 plastic fantastic boots for his broken femur, saying that if he had worn cheaper boots, he would still have his leg. I'm guessing the impact to his boot transferred the force from his foot all the way up his leg?
"Pain is weakness leaving the body, and blood makes the grass grow faster...but I'll wear my gear anyway"
kramdra
PostPosted: 12:26 - 28 Jul 2013    Post subject: Reply with quote
Im looking to buy a back protector, likely one of the foam, jacket pocket types.
The Knox ones look good but I notice they are only level 1.
https://www.ebay.co.uk/itm/Knox-Advance-X-Back-Protector-Insert-CE-Approved-/380576560781/
these are level 2
https://www.ebay.co.uk/itm/Revit-Seesoft-back-protector-insert-KN-/181175204103/
https://www.ebay.co.uk/itm/Forcefield-Back-Protector-Replacement-Insert-Pro2-002-Motorcycle-Armour-/200828124557
Opinions?
Ofcourse it also needs to fit my jacket and I realise my jacket is far too big. Planning to get another Thumbs Up
The last post was made 13 years, 12 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 1.15 - MySQL Queries: 16 - Page Size: 160.97 Kb
