Honda CD200 Benly Project
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3
Aff
PostPosted: 19:15 - 26 May 2013    Post subject: Reply with quote
Final engine mount painted:
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0103_zps03617b84.jpg
Tried to get Halfrauds to mix me some paint for the fork covers, etc. But apparently it wasn't on their system so they couldn't mix it. I will have to try and find it online.
In case anyone is interested it's Honda Paint Code: PB-7C, Candy Sword Blue.
So far I've only managed to find it online at $60 a can, and I don't want to pay that.
Hopefully tomorrow I will be able to find all the lost fasteners and get the bike to look like a bike again.
Electric Bike Project
Aff
PostPosted: 19:25 - 05 Aug 2013    Post subject: Reply with quote
Progress!
Finally managed to source the engine bolts that I had misplaced.
So stuck the engine back in the frame.
https://i1135.photobucket.com/albums/m637/Biles/20130805_154336_zps49eff47b.jpg
Forks on for some stability:
https://i1135.photobucket.com/albums/m637/Biles/20130805_154342_zpse6559c7e.jpg
Carb back on:
https://i1135.photobucket.com/albums/m637/Biles/20130805_154347_zpsd8885b74.jpg
Defiantly more bikeish now, wish I'd taken more pictures, its been a year since I stripped it down now and having trouble remembering where everything goes. There is also very little documentation about this bike out there.
https://i1135.photobucket.com/albums/m637/Biles/20130805_172344_zpsc2fdbc07.jpg
Stuck the whole ignition system loosely on the bike, so hopefully tomorrow I can start it up and see if the rebuilt engine runs, it does turn nice an smoothly though.
https://i1135.photobucket.com/albums/m637/Biles/20130805_183011_zps6d066e01.jpg
Shaft
PostPosted: 16:14 - 06 Aug 2013    Post subject: Reply with quote
https://www.rsbikepaint.com/en-gb/shop-paints.php?colourscheme=4462&6728=on
Aff
PostPosted: 17:12 - 06 Aug 2013    Post subject: Reply with quote
Cheers Shaft, I found that company a while ago, but the tank isn't in as good condition as I remember, so I may just repaint the whole thing. Colour suggestions are welcome. Smile
Anyway I attempted to start it today, starter motor turns it over very well, very good spark, getting fuel... but no start. Crying or Very sad
I'm assuming it has no compression, but my tester doesn't have an adapter small enough so will have to see if the shop has one or wait for one to be delivered before I can do anything.
I can't think of any other reason for the no start, it doesn't even try to catch, just spins on the starter. Plugs come out wet and bogs down if you open the throttle.
Aff
PostPosted: 20:13 - 09 Aug 2013    Post subject: Reply with quote
Awww. Crying or Very sad
https://i1135.photobucket.com/albums/m637/Biles/b0aaeee1-3ccf-421a-84c9-f198f3acdf02_zpsff3a746b.jpg
https://i1135.photobucket.com/albums/m637/Biles/20130809_152550_zpsa9cccd97.jpg
https://i1135.photobucket.com/albums/m637/Biles/20130809_152229_zpsc8f2de9e.jpg
https://i1135.photobucket.com/albums/m637/Biles/20130809_152723_zps8444a04a.jpg
So probably explains the no start, I think what I may have done was accidentally put the donor engines pistons and rings in the old engine (valve clearances and timing spot on BTW).
Anyway onwards and upwards, lets do it all again Laughing (sorry for the blurriness, think I got oil on the lens):
Rockers out:
https://i1135.photobucket.com/albums/m637/Biles/20130809_162551_zps9f4c5db8.jpg
Camshaft out:
https://i1135.photobucket.com/albums/m637/Biles/20130809_163732_zps346a8a3f.jpg
Thought I would be able to get the studs out and not have to drop the engine, but they weren't budging, so engine out:
https://i1135.photobucket.com/albums/m637/Biles/20130809_165250_zps05fd2618.jpg
Head off:
https://i1135.photobucket.com/albums/m637/Biles/20130809_175627_zps21c1f829.jpg
Pistons out:
https://i1135.photobucket.com/albums/m637/Biles/20130809_180456_zps98b80185.jpg
Now seeing as the pistons look fine and the original engine was running fine I was just going to get new rings, but I cant find anything anywhere also all the piston kits have just got 2 compression rings where as the OEM pistons have 2 compression rings and an oil scraper, see below:
https://i1135.photobucket.com/albums/m637/Biles/20130809_180449_zps3d1ebf92.jpg
If anyone can link me to where I can buy replacements I will be grateful, Wemoto only have the copy 2 ring pistons and DS has nothing.
Cheers. Karma
Aff
PostPosted: 18:59 - 10 Aug 2013    Post subject: Reply with quote
Have decided it's probably a good idea to use the old head, as I know that was running relatively well, also there are a couple of broken fins on the new head that I didn't notice before.
My ghetto home-made valve spring compressor. Laughing
https://i1135.photobucket.com/albums/m637/Biles/20130810_163808_zps397ee105.jpg
Valves out, waiting for new valve seals to arrive and I will lap and reinstall them.
https://i1135.photobucket.com/albums/m637/Biles/20130810_163816_zpsddce7c2f.jpg
Aff
PostPosted: 20:39 - 10 Aug 2013    Post subject: Reply with quote
OK, I've found the P/N for the rings:
13011-418-003
Superseded by:
13011-KB4-305
But everything I find is ridiculously priced (about £35 a set). Crying or Very sad
Aff
PostPosted: 19:56 - 16 Aug 2013    Post subject: Reply with quote
Tomorrow there shall be progress. Very Happy
https://i1135.photobucket.com/albums/m637/Biles/20130816_194923_zps657493b6.jpg
Aff
PostPosted: 23:23 - 17 Aug 2013    Post subject: Reply with quote
So turns out Mr Muscle oven cleaner is very good at getting carbon off.
Head and pistons cleaned up:
https://i1135.photobucket.com/albums/m637/Biles/20130817_113724_zpsac5a4074.jpg
Rings on:
https://i1135.photobucket.com/albums/m637/Biles/20130817_115727_zps5ae2bf77.jpg
Valves lapped:
https://i1135.photobucket.com/albums/m637/Biles/20130817_123005_zpsb37eb544.jpg
Seals in:
https://i1135.photobucket.com/albums/m637/Biles/20130817_123655_zps18ee41ea.jpg
Aff
PostPosted: 17:55 - 18 Aug 2013    Post subject: Reply with quote
More progress. Very Happy
Valve springs back in:
https://i1135.photobucket.com/albums/m637/Biles/20130818_111309_zps1d3c4177.jpg
Cylinders honed, the camera doesn't really show it very well, but it came out nice, a good 45° cross hatch.
https://i1135.photobucket.com/albums/m637/Biles/20130818_114303_zps189e8ed9.jpg
https://i1135.photobucket.com/albums/m637/Biles/20130818_114307_zpsc90da247.jpg
Pistons etc back in, huge pain in the ass without a second set of hands.
https://i1135.photobucket.com/albums/m637/Biles/20130818_130226_zps8d373c9a.jpg
Head on and cams in. Having the chain run down the middle makes it very awkward setting the timing.
https://i1135.photobucket.com/albums/m637/Biles/20130818_141333_zps1ff3dbf5.jpg
Rockers on and valve clearances set:
https://i1135.photobucket.com/albums/m637/Biles/20130818_142444_zps8e883c98.jpg
Engine back in the frame, also a huge pain in the ass without a second set of hands:
https://i1135.photobucket.com/albums/m637/Biles/20130818_152556_zpsa007a0c5.jpg
And then it came to start it....and nothing. Crying or Very sad
Spent a few batteries worth of electricity trying to diagnose, it would start for a few seconds on carb cleaner, so I stripped the carbs down.
Turned out to be a stuck float, so sorted that and stuck the carb back on the bike.
Bodged on the Fireblades battery using cable ties and had another go.
Very Happy Very Happy
https://s1135.photobucket.com/user/Biles/media/20130818_171523_zps337d303f.mp4.html
Still need to play about with the carb a bit, but at least it runs now.
Aff
PostPosted: 17:53 - 01 Dec 2013    Post subject: Reply with quote
OK had some time, so a bit of progress:
Decided to tackle the wiring, was a bit of a state, consisting of about 10% actual wiring and 90% Scotch Locks and electrical tape.
Electrical tape is a pet hate, it just turns to dust and leaves the wires a sticky mess:
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0365_zpsd3a0a4a7.jpg
The rest of the wiring just looked like this:
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0367_zps47698954.jpg
All stripped down and tidied up with self amalgamating tape:
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0366_zps7977a022.jpg
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0368_zpsd52404de.jpg
Also replaced the old glass type fuse.
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0362_zps9ced7989.jpg
With a newer blade type:
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0363_zps7f61d84e.jpg
Also managed to get these cheap on eBay:
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0361_zpsc72501e3.jpg
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0371_zps7f2e51bc.jpg
Look the part and should work better than the old ones, seeing as they had no oil in them.
New sprockets too:
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0370_zps80c24c7c.jpg
Decided I would attack the wheel, not been looking forward to these, still haven't found a good way of removing all the rust and paint from spoked wheels. Best I've found so far is a dremel with a few hundred 1/4" sanding drums.
Got one of the wheels prepped and primed though.
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0374_zps2b6fc256.jpg
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0375_zpsb6ef615d.jpg
beardface
PostPosted: 14:24 - 03 Dec 2013    Post subject: Reply with quote
Nice, can't wait to see it all re-assembled! Below is a picture if my old 1970 CD175, the most reliable and smooth bike I have ever owned.
https://i257.photobucket.com/albums/hh215/rokone_2008/front-4.jpg
www.soundcloud.com/bodren
There is a gap of 193 days between these two posts...
Aff
PostPosted: 19:01 - 14 Jun 2014    Post subject: Reply with quote
OK, so it's been 6 months, I think the primer should be dry now.
Got both the wheels painted:
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0639_zps6831d0e6.jpg
The drums looked pretty tatty but cleaned up OK so wont be bothering to paint them.
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/20140614_101910_zpsa6wzo5je.jpg
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/20140614_103733_zpsm2tjdley.jpg
Aff
PostPosted: 18:49 - 15 Jun 2014    Post subject: Reply with quote
Stuck some Metzeler ME22's on the wheels:
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/20140615_112159_zps0jcggogc.jpg
pepperami
PostPosted: 11:43 - 16 Jun 2014    Post subject: Reply with quote
MOAR NOW! Thumbs Up
_Troy_
PostPosted: 17:10 - 16 Jun 2014    Post subject: Reply with quote
Haven't looked through this thread before, and saw the date of the first post and was hoping to read a project from start to finish.
But then I realised I have been in your garage recently, and there are many bits in many boxes Laughing
Current bike: ZX6R J1
Previous bikes: CLR 125 | GS500 | ZX6R G2 | SV650
Aff
PostPosted: 19:37 - 16 Jun 2014    Post subject: Reply with quote
Yea, I have been slacking a bit.
Aff
PostPosted: 18:22 - 22 Jun 2014    Post subject: Reply with quote
Bit more progress.
New rear sprocket:
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0659_zps62f24d86.jpg
A chassis that rolls:
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0662_zps56cef2b0.jpg
Looks like a may have pinched the tube putting the front tyre on.
Stuck the battery and tank on:
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0663_zpsba01f794.jpg
Was having fuelling issues again when I tried to start it. The float was gummed up again, took it off and blasted it out and all is good.
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0664_zps4d1df082.jpg
It now starts and runs quite nicely:
https://www.youtube.com/watch?v=msAjEyOZkps&feature=youtu.be Very Happy
Also riveted the VIN plate back on.
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0665_zps6fd3f6f4.jpg
There is a gap of 192 days between these two posts...
Aff
PostPosted: 16:38 - 01 Jan 2015    Post subject: Reply with quote
Had a spare hour. Got some little jobs done, not much in the way of pictures.
Got the centre stand, rear brake and front brake all connected:
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0207_zpsa346760c.jpg
Also stuck a chain on it:
https://i1135.photobucket.com/albums/m637/Biles/CD200%20Project/IMG_0209_zpscd947889.jpg
Will update with more in 6-8 months. Very Happy
pepperami
PostPosted: 22:42 - 02 Jan 2015    Post subject: Reply with quote
MOAR NOW!
Don`t make me wait Twisted Evil
-Monty-
PostPosted: 23:24 - 02 Jan 2015    Post subject: Reply with quote
It's like one of those Online/iPhone building games where you do one thing then have to wait a day to do something else. Only, this is six months rather than a day.
Still good to see more work being done.
Present: [Kawasaki ZX7r][Suzuki DRZ 400s]
Past: [Honda PCX 125] [Yamaha RXS 100] [Honda CB 500] [Triumph Speed Four] [Honda ST1100 Pan European - Po-Po Edition]
Shreeve
PostPosted: 18:10 - 04 Jan 2015    Post subject: Reply with quote
Give in to the peer pressure and update more regularly!
Current: Suzuki GSX650F (2010), Suzuki GSXR1000 K7, Suzuki GS250T (1980) currently restoring: Clicky.
Previous: Honda CBF 125 (2011), Suzuki GSXR750 K4
Moo.
PostPosted: 19:43 - 15 Feb 2015    Post subject: Reply with quote
MOAR!
A2 Passed 18/6/10
Bubbs
PostPosted: 14:26 - 16 Feb 2015    Post subject: Reply with quote
Glad I didn't see this thread when it first started - I'd be disappoint.
Looking good though.. only 3-4 more years and she'll be ready Laughing
There is a gap of 322 days between these two posts...
Robzki
PostPosted: 00:24 - 05 Jan 2016    Post subject: Reply with quote
Enjoyed the read, thank you 👍
The last post was made 8 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Page 3 of 3
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.21 - MySQL Queries: 16 - Page Size: 154.01 Kb
