XJ600 pre-diversion oil light
daveD
PostPosted: 09:42 - 05 Oct 2013    Post subject: XJ600 pre-diversion oil light Reply with quote
Hi guys, my son's xj600 pre-divvy oil light comes on every now and again. If he's cruising on the motorway at high speeds it is fine but comes on at time up or down hill or when hard accelerating.
I know that the diversion is an oil level switch rather than a pressure switch but is the pre-divvy the same?
Anyone got any idea?
Thanks
Dave
Dave '62 Enfield Crusader Sports, early GS500E
Son with an XJ600
Help I need a bigger garage!!
yen_powell
PostPosted: 09:48 - 05 Oct 2013    Post subject: Reply with quote
Both my Yamaha FJ1200's oil light would come on up very steep hills.
XT1200Z and a DR350 in bits
Robby
Dirty Old Man
PostPosted: 11:31 - 05 Oct 2013    Post subject: Reply with quote
My XJ650 (pre-pre-divvy) also has an oil level light rather than a pressure light, so I would say your son's bike has an oil level light. Top the oil up.
daveD
PostPosted: 11:37 - 05 Oct 2013    Post subject: Reply with quote
Thanks guys, level looks ok on the sight glass but will double check and put a drop in if needed.
Son with an XJ600
Nemo
PostPosted: 16:05 - 05 Oct 2013    Post subject: Reply with quote
If the oil level is okay then it's just physics doing its tang imo.
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
J.M.
PostPosted: 16:13 - 05 Oct 2013    Post subject: Reply with quote
My oil light used to do slightly strange things if the oil level was around 1/4 full. When it's 1/4 full, it's entirely too easy to make it look 1/2 or 3/4 full by slightly tipping the bike too far whilst checking the oil level.
2004 R1 & 2018 XSR900
c_dug
PostPosted: 16:20 - 05 Oct 2013    Post subject: Reply with quote
I've recently had the same thing on my xj900 divvy, topping it up solved the issue.
I think it's to do with the placement of the sight glass or something, it is very easy to look like a good level because the bike is a couple of degrees from upright when in fact it is barely above the minimum.
weasley
PostPosted: 22:22 - 05 Oct 2013    Post subject: Reply with quote
My pre-Divvy XJ600 did this when it was cold. It had over 55,000 miles on it and was running sweet as a nut when I sold it. As said, it is a level light, but since you have a sight glass anyway then you can verify oil level by eye.
Ariel Badger
PostPosted: 22:33 - 05 Oct 2013    Post subject: Reply with quote
Thrust SSC did this under breaking, all the oil gets flung to the front of the sump and the switch is activated.
daveD
PostPosted: 08:26 - 06 Oct 2013    Post subject: Reply with quote
Interesting fact!
Thanks guys.
Son with an XJ600
The last post was made 12 years, 112 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.34 - MySQL Queries: 16 - Page Size: 66.64 Kb
