2002 Hornet 600 Overheating - Update, Thermostat Tested
squishio
PostPosted: 17:05 - 06 Oct 2013    Post subject: 2002 Hornet 600 Overheating - Update, Thermostat Tested Reply with quote
Hi Guys
The wife's hornet has decided to start overheating, but I'm not sure why.
Yesterday she was riding it across London and the temp gauge went well into the red, she stopped, let it cool down and then carried on, and then did the same again shortly after due to the temp rising again.
This morning I changed the oil and also the coolant as it was due anyway, and I've just taken it out for a test ride, I was only out for about 15mins and the temp gauge was just under the red zone.
My ride was slow through town, but moving at all times.
However, the fan did not cut in at any point during (or after) my ride, I have checked the fuses and they're all in tact so it isn't that.
What should be checked next?
I would have expected that even without the fan kicking in, the bike should be able to keep itself reasonably cool in this 19* weather.
The radiator has the usual bent fins from stones kicking up, but nothing excessive, certainly plenty of airflow still going through.
I guess I'll need to put 12v straight to the fan to see if it works at all, it definitely was last week when I rode it as it tends to kick in when the temp gauge passes half way.
Other than that, could there be another more serious issue like a failed waterpump or something?
Cheers!
Rich
(I don't think it matters much, but but just in case it does, the engine is actually from a cbr600f, at least I believe it is judging by the engine number)
Current - Hornet 600, Transalp 650, X140 Pit, GPZ400R
Past - SY125, GT250, GT650, CX400, CBF600, Bandit 600, SL1000, GT250
RhynoCZ
PostPosted: 17:15 - 06 Oct 2013    Post subject: Reply with quote
Stucked thermostat, the gauge itself, air in the system, faulty temp sensor, faulty fan, lean mixture.
Was the bike really hot?
squishio
PostPosted: 17:31 - 06 Oct 2013    Post subject: Reply with quote
hotter than it usually is I think Confused
Wife says it was cooking her legs, so certainly not its usual running temperature.
instigator
PostPosted: 17:36 - 06 Oct 2013    Post subject: Reply with quote
RhynoCZ wrote:
Stucked thermostat
This. Common issue found on the hornets. Test it.
RhynoCZ
PostPosted: 18:07 - 06 Oct 2013    Post subject: Reply with quote
Thermostat it is.Thumbs Up
MattEMulsion
PostPosted: 19:15 - 06 Oct 2013    Post subject: Reply with quote
You need to get that fan working too don't forget!
Yamaha YZF-R6
squishio
PostPosted: 20:38 - 06 Oct 2013    Post subject: Reply with quote
righto, so basically thermostat stays closed, so no coolant flows, correct?
Repair or replace?
One of these...
https://www.davidsilverspares.co.uk/CB600F2-HORNET-2002/part_71447/
moonzoomer
PostPosted: 20:59 - 06 Oct 2013    Post subject: Reply with quote
To test remove stat, put in pot of cold water and place on stove, once the water has just started to boil the stat should open, if it stays closed it is knackered. Use the same test for the electrical fan stat and check for closed circuit once the stat has reached temp using an ohm meter.
squishio
PostPosted: 23:02 - 07 Oct 2013    Post subject: Reply with quote
I think the thermostat is fine...
I removed it, and stuck it in a pot and heated it up, it opened at around 85*C and closed at around that temp when cooling down...
Boiling...
https://i.imgur.com/5WRCni8.jpg
Open...
https://i.imgur.com/WlhElbN.jpg
Open...
https://i.imgur.com/U0bMDfK.jpg
Closing...
https://i.imgur.com/ZlkVePY.jpg
I've only just done this, so have not yet fitted it back onto the bike/gone for test ride, but I assume the thermostat is fine as it did exactly what it was supposed to do at (as far as I know) almost exactly the temperatures it's supposed to do it at.
I know it wouldn't be ideal as the engine will take longer to warm up, but could I leave the thermostat out, test ride and see if the temp rises as before?
It looks like the cover for the thermostat goes back on regardless of it being in place or not.
prawny1
PostPosted: 23:22 - 07 Oct 2013    Post subject: Reply with quote
Honda usually wire the fan via the parking light part of the ignition switch with it's own fuse so that if you park up with the fan on and put the ignition in park the fan stays running until the bike cools even with the key out.
Test the stat switch by shorting it to ground to see if the fan comes on if it doesn't Check if the park light works, that will tell you if the ignition is powering the circuit.
If you have no park light either you probably have a blown fuse if the park light does work it's bad wiring somewhere along the line or a dead fan.
hellkat wrote:
squishio
PostPosted: 23:31 - 07 Oct 2013    Post subject: Reply with quote
I shall do that tomorrow Smile
However, regardless of the fan working or not, I don't think the bike should have gotten as hot as it did, considering it wasn't a particularly hot day and I wasn't stuck in traffic / sitting still...
RhynoCZ
PostPosted: 23:55 - 07 Oct 2013    Post subject: Reply with quote
Well, that depends, my NC27 used to run hot all the time, never got up to the red zone, but the heat coming out of it was very significant, the fan kicked in even when I was doing about 35-40mph at 6th, in summer of course. In colder weather the fan started to blow at every 3rd red light. I pushed that little Honda to the limit all the time, so I'm not surprised. Lots of mates and owners told me it was alright, that these bikes just get hot. The engine ran smooth and strong like a brand new. Thumbs Up
instigator
PostPosted: 07:53 - 08 Oct 2013    Post subject: Reply with quote
I just seen this quote - have had 3 Hornets before as well as my current one and they do usually run quite hot, particularly in London with all the stop / start traffic. Since I moved out of London now, my hornet runs very cool indeed and I have no issues whatsoever but it is recognized that they do heat up pretty darn quickly.
At least you've now determined the thermostat is working properly.
FYI for OP, the fuse for the fan is the 10A one in position A in the fuse box. As you've checked that though, I suspect it's now the fan motor switch or wiring at fault now. As above, start testing. I suspect you have a workshop manual to see the wiring diagram?
squishio
PostPosted: 16:15 - 08 Oct 2013    Post subject: Reply with quote
Will check out the fan tonight and update accordingly, thanks guys.
The last post was made 13 years, 2 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.7 - MySQL Queries: 16 - Page Size: 88.8 Kb
