Rear wheel removal help?
bird079
PostPosted: 18:42 - 07 Oct 2013    Post subject: Rear wheel removal help? Reply with quote
i need to remove my rear wheel to put a new wheel on the bike is skyjet 125-26 i already have the parts just cant get the axle bolt off!
Please help me
doggone
PostPosted: 18:57 - 07 Oct 2013    Post subject: Reply with quote
Can you post a picture?
Is the main problem the nut seems too tight?
If so you generally need more leverage like a length of metal pipe on a good ring spanner (probably not the supplied one if any)
stirlinggaz
PostPosted: 18:58 - 07 Oct 2013    Post subject: Reply with quote
hi,
its just a standard nut isnt it?
use a breaker bar or impact gun. wouldnt harm it to use a bit of penetrating fluid (not wd40) before hand.
cheers,
GAZ
bird079
PostPosted: 19:00 - 07 Oct 2013    Post subject: Reply with quote
yeah its just a normal bolt one on each side the one on the left of the bike is a larger nut. but i cant get it spinning with a wrench on both sides but using one side it just keeps spinning
Commuter_Tim
PostPosted: 19:08 - 07 Oct 2013    Post subject: Reply with quote
https://www.amazon.co.uk/Sealey-600mm-2-inch-Breaker-Drive/dp/B000O619PA/ref=sr_1_1?ie=UTF8&qid=1381169163&sr=8-1&keywords=breaker+bar
Failing all else, that will do the trick, you would also need the appropriate sized 1/2" socket also tho.
If you're just trying to loosen from one side, sit on the bike and put your foot on the rear brake, then try again? should hold the spindle in place.
I ride a Bandit 600... badly.
bird079
PostPosted: 19:09 - 07 Oct 2013    Post subject: Reply with quote
cant get a pic up phones to rubbbish lol but yeah when i out a spanner on each end its just too tight to get any movement going lol
is there a specific side i should be undoing? ive been undoing the right hand side (side which the exhaust is on)
Commuter_Tim
PostPosted: 19:12 - 07 Oct 2013    Post subject: Reply with quote
If you're just doing one side, then the one with the nut, as opposed to the bolt, which on mine is the exhaust side yes.
bird079
PostPosted: 19:35 - 07 Oct 2013    Post subject: Reply with quote
have got myother half to take a couple of pics
Commuter_Tim
PostPosted: 19:57 - 07 Oct 2013    Post subject: Reply with quote
Mine was rusted worse than that, in the end the only thing that worked was blowtorching the crap out of the nut, then breaker bar/socket shifted it.
Heres hoping yours doesn't need that, as it was a bastard to do.
bird079
PostPosted: 20:06 - 07 Oct 2013    Post subject: Reply with quote
am i undoing the one on the first picture whilst holding the one in the second picture secure?
Commuter_Tim
PostPosted: 20:25 - 07 Oct 2013    Post subject: Reply with quote
Yes, the first picture is the axle nut.
Second is the Spindle/axle bolt.
I think some people just use the rear brake, whilst undoing the axle nut, others put a wrench on both sides, cant hurt to do both if you can balance Smile
I find sitting on the bike backwards helps steady it while doing it, but my piddly 125 would go flying if I didn't.
Point of slight concern though, and maybe someone more knowledgeable than myself can answer this...
...but it seems quite troubling that his axle nut has no split pin or self locking threads? Do the Chinese not deem this important? :S
bird079
PostPosted: 20:43 - 07 Oct 2013    Post subject: Reply with quote
thats another thing that confused me i spent ages looking for some kindof cotter pin but couldnt find one :/ but tomorrow i shall get the socket and wrench and have at it put some penetrating oil on for the evening. but it should come off with pressure on both sides right?
Commuter_Tim
PostPosted: 20:48 - 07 Oct 2013    Post subject: Reply with quote
If there was a cotter/split pin, you would see it, also if it was missing, there should be a small hole through the axle itself in front of the nut, yours only appears to have 1-2mm sticking out in front of the nut, so not possible.
If it was a self locking nut it should look like this...
https://www.turnbolt.co.za/assets/images/Self_Locking.jpg
see those blades? again they would be visible even when fully tightened if yours had them.
In theory if correctly torqued/tightened It shouldn't come loose (in theory) but I guess safety wasn't the top priority on the Chinese Engineers list.
I would take everything I say with a pinch of salt as I'm still relatively new to all this Wrench Monkey business, but when you do get it loose, I would make sure its done up nice n tight...
bird079
PostPosted: 20:51 - 07 Oct 2013    Post subject: Reply with quote
i dunno then i got the bike second hand so maybe they were replaced by some mong :/
Raffles
PostPosted: 22:21 - 07 Oct 2013    Post subject: Reply with quote
So would I.
Commuter_Tim
PostPosted: 22:39 - 07 Oct 2013    Post subject: Reply with quote
Raffles wrote:
So would I.
Real helpful to the OP there, go you Rolling Eyes
Nb
PostPosted: 22:53 - 07 Oct 2013    Post subject: Reply with quote
The nut looks rounded off now, if you had access to a little heat/gas to get the nut hot that would fall off. What did you use to try and undo the nut/bolt?
Do you have a replacement nut/bolt already?
If the bikes still able to be ridden i would take the bike to a local bike place and get them to undo it, shouldnt take them 5 minutes.
And where in bucks are you roughly?
el_oso
PostPosted: 23:06 - 07 Oct 2013    Post subject: Reply with quote
my bike (yzf600r) doesn't have a castle nut and split pin. The recommended torque is 120Nm. Which if my A-level maths/physics is correct is approximately equal to hanging 40kg on the end of a standard 12" break bar. That's about half my weight. So they are done up pretty tight.
My recommendation would be go down the gym and build up some strength and/or get a longer bar on there. Don't be too afraid of destroying the nut. Just make sure you have a good grip with the socket and it should undo with quite a bit of force
Duke 390
Car: Jeep Wrangler 4.0L
truslack
PostPosted: 11:27 - 08 Oct 2013    Post subject: Reply with quote
Please stop giving ridiculous advice.
Ask yourself some questions:
1) Why would holding the brake on do anything to a spindle that sits inside bearings?
2) Why would it matter which side of a Spindle/Nut combination that you hold still, and which one you turn
3) Look at more bikes than just your own, then ask yourself "is a split pin / R clip fitted to every jap bike's wheel spindles?"
To the OP, hold one side still, you can do this by wedging the spanner/ratchet/breaker bar against something so it cant move, then put a long bar on the other side, then man up and undo it.
Islander
PostPosted: 12:04 - 08 Oct 2013    Post subject: Reply with quote
Erm, that'll have no effect whatsoever on the spindle. The brake will hold the wheel which sits on bearings with the spindle inside the bearings.
Some bikes have castellated wheel nuts and split pins or R clips but this is by no means the majority of bikes. I've never seen a self locking nut used but then I haven't seen every bike on the market. They're usually just tightened to a fairly high torque setting - elaborate locking mechanisms aren't really necessary.
Sorry but you seem to lack basic mechanical knowledge - it's a good idea to post in the workshop only when you've got some idea of what you're about.
What the OP needs to do is to get someone strong to hold one side of the spindle with a good quality ring spanner or socket while he uses a breaker bar and socket on the other. No need to hold the bike down as you'll be applying equal and opposite forces. Thumbs Up
bird079
PostPosted: 12:07 - 08 Oct 2013    Post subject: Reply with quote
ill get my other halfs brother to help me Smile clearly i need a mans muscle here...guess theres somethings a woman cant do on her own Razz
anthony_r6
PostPosted: 14:24 - 08 Oct 2013    Post subject: Reply with quote
Correct me if I'm wrong, but what Tim is refering to is actually trying to untighten the nut by putting force on it, and the bike rolling backwards as you try and yank it. Putting the brake on just stops you being able to pull it back.
Also as for holding a spanner on both sides, this had to be done on my old bike as when I tightened or released the nut, it span the entire axle until I applied counter-force.
I don't see why his advice is mocked???
Commuter_Tim
PostPosted: 19:36 - 08 Oct 2013    Post subject: Reply with quote
It doesn't really matter what I did or didn't mean at this point, some people just like to act the big man, would love for them to find the particular forum rule I broke by posting here too...
Me posting here did no harm (disclaimer included).
Regardless, trolls will be trolls, I won't be replying to them however as bringing an argument into the OP's thread does *her*(EDIT, Sorry) no good.
Raffles
PostPosted: 22:05 - 08 Oct 2013    Post subject: Reply with quote
In the picture showing the nut that Tim seems to think isn't a self-locking nut, it looks as though the chain's split link is installed incorrectly.
https://www.bikechatforums.com/download.php?id=90649
The picture isn't too clear, but the link appears to have been fitted the wrong way around.
The last post was made 12 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.4 - MySQL Queries: 16 - Page Size: 131.82 Kb
