| pooley_99 |
 pooley_99 Nitrous Nuisance
 Posted: 11:41 - 08 Oct 2013 Post subject: car thread - fiesta engine idle problem |
Yea yea this is a bike forum, but all the ford forums are a bit pants for proper advice and I know there's a couple of decent mechanics knocking around these pages.. so..
Ive changed the head gasket, water pump, timing belt and thermostat on my mrs 2004 fiesta 1.25 The water pump failed and it boiled its cock off so thats why i did the work. It runs up to the correct temp now and cools properly but there is now an idle problem, once the engine is warm and i guess no choke needed, it idles around 500 to 750 up and down and then dies. Ive put new plugs in coil seems ok its defo sparking and ive doubled checked all the wiring and breathers... Running out of ides now  ____________________ CBR 900RR Fireblade |
| cb1rocket |
 cb1rocket World Chat Champion
| pooley_99 |
 Posted: 13:03 - 08 Oct 2013 Post subject: |
done that, no codes... i'm now thinking its something to do with the evap system because when i unplug the vacuum hose from the evap valve to the inlet manifold it seems to run better  ____________________ CBR 900RR Fireblade |
| misscrabstick |
 misscrabstick Crazy Courier
| misscrabstick |
| misscrabstick |
| Triumph1300 |
 Triumph1300 Nova Slayer
 Posted: 13:13 - 08 Oct 2013 Post subject: |
Check the breather hoses under the inlet manifold, we've had a similar problem, the one on the left hand side had split ____________________ BWJ
Back on a BMW R80RT
Punctuation - the difference between knowing your shit, and knowing you're shit  |
| pooley_99 |
 Posted: 14:07 - 08 Oct 2013 Post subject: |
ok thanks for all these suggestions. I've now got the valve cover off and checking the valve clearances, I totally should of done this while the cams where out but i didnt.. and.... the gaps seem out! I'm not sure if this is because the engine is still warm. Thinking about it i might of got a couple of the shims mixed up when i had the head and cams off What sort of tolerances do these gaps have? ____________________ CBR 900RR Fireblade |
| pooley_99 |
 Posted: 17:49 - 26 Oct 2013 Post subject: |
finally got round to this, ended up swapping two shimms around that i worked out from the valve clearances that I must have got mixed up the first time.. Cams out shims swapped back and running sweet!  ____________________ CBR 900RR Fireblade |
The last post was made 12 years, 67 days ago. Instead of replying here, would creating a new thread be more useful? |
