Electric garage door
Symon27
PostPosted: 18:37 - 14 Oct 2013    Post subject: Electric garage door Reply with quote
Just moved into a new house and it has a double garage with an electric door, first few days it was working fine now it keeps playing up.
It will travel around 10 inches down then stop, if I press the button to go down again it will go another 10 then stop ect. Going up is fine.
I called some guy and he wants £50 just to come out and look at it, I've read online about some safety eye what sends an infa red beam across and if it gets broken it will stop.
This garage don't have that, it's got two magnets on one side, one and the top and one at the bottom.
The control unit flashes red if the when the door is open and stay red if the door is shut.
Dose anyway have an idea what could cause this?[/list]
Honda Nsr 125 - Sold
Zxr 400 - Sold
Bandit 600 - Current (Y)
J.M.
PostPosted: 18:49 - 14 Oct 2013    Post subject: Reply with quote
Can't you find the device which triggers the door to stop closing and bypass it to see what happens? If you can manually have full control then rig up some replacement trigger.
2004 R1 & 2018 XSR900
Minty
PostPosted: 19:21 - 14 Oct 2013    Post subject: Reply with quote
Can you switch it to manual? Mine has a connector to the main shaft/chain drive that you pull to disengage the door from the mechanism.
It would give you a chance to close it by hand and see if it is sticking in any way. It could be that the motor uses more grunt to 'push' the door shut than it needs to 'pull' it open. It may be sensing the overload at trying to close it and is tripping in some way.
Grease all the runs etc too as a matter or basic maintenance.
My fingers smell of your mum.
ScaredyCat
PostPosted: 22:12 - 14 Oct 2013    Post subject: Reply with quote
Can you find a manual for it?
The one we had used to 'forget' the max/min open/shut positions if the power failed. You needed to go through a reset/teach phase before it would open fully again.
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
PostPosted: 23:26 - 14 Oct 2013    Post subject: Reply with quote
I recently smashed my up and over garage door off then in half with a sledgehammer and replaced it with a pair of wooden doors that close into the middle on conventional hinges.
I have been a calmer and more balanced person since.
It is soon to be followed by my uPVC front door.
The thought of an electronically activated up and over garage door brings me out in a cold sweat. NOBODY needs an electically opening garage door.
Except Batman or the Thunderbirds obviously.
Tarmacsurfer
PostPosted: 09:44 - 15 Oct 2013    Post subject: Reply with quote
I disagree with you, for once Laughing
Back when my spine was fuxx0red it was incredibly useful. Mines not up and over though, it's a roller setup. Hate up and over with a passion, also starting to view UPVC doors in the same way Confused
I'm immortal. Well, so far.
331X2
PostPosted: 15:24 - 15 Oct 2013    Post subject: Reply with quote
After putting two sets of wire on my overhead spring assisted door I'm inclined to do exactly the same as you, nearly caved my fucking head in twice... Now on the hunt for some old style, square windows in the top quarter doors for that 1920's/1930's local garage look Cool
map
Mr Calendar
PostPosted: 16:08 - 15 Oct 2013    Post subject: Reply with quote
My manual up and over is currently FUBARed by my step-son.
So I can empathise about the lack of a working garage door.
The damn thing is a pain without the wires and the spring.
You really don't want to know the hassle in trying to replace the wires and checking the spring. I'll give you a hint, I'm waiting for a second lot of parts.
PostPosted: 16:31 - 15 Oct 2013    Post subject: Reply with quote
I do know that if I had one, the open/close remote would be wired up to my high beam. Pull up, flash, door opens, ride in, flash, door closes Thumbs Up
ZebraDriver
PostPosted: 18:41 - 15 Oct 2013    Post subject: Reply with quote
What you need is one of these:
https://www.youtube.com/watch?v=1C-Bxifv2Pk
PostPosted: 20:46 - 16 Oct 2013    Post subject: Reply with quote
https://www.jonkrastes.com/lessons/images/hong%20kong%20phooey.jpg
Racist.
Symon27
PostPosted: 22:06 - 16 Oct 2013    Post subject: Reply with quote
Can't seem to find a manual anywhere, all I no is its a sws door and they want £50 just to come have a look.
I've taken the cover off the power box and there's a few wires and some dip switches.
Pain in the ass when you have to stand out in the rain pressing the button 20 times for it to completely shut.
Zxr 400 - Sold
fredsredhat
PostPosted: 17:39 - 17 Oct 2013    Post subject: Reply with quote
if its an sws it'll have a grey box to 1 side on the bottom of the curtain. on the channel there'll be 2 grey magnets. 1 at top and 1 at bottom. sounds to me like a magnet has come off. the sensor doesn't know where it is so goes into a type of deadman mode. (im assuming its a somfy/pdt remote unit. grey box with light on top. grey remote fobs with 2 green buttons. 1 red and 1 grey?
EDIT re-read your post. when the grey sensor passes the top magnet how many flashes does the led give off?
Symon27
PostPosted: 18:23 - 17 Oct 2013    Post subject: Reply with quote
That's what it has, the box on the wall light is orange then flashes red 3 times. But going up it will stay green, and occasionally the grey box will flash red but most of the time the little led dose not do anything.
Zxr 400 - Sold
lihp
PostPosted: 18:30 - 17 Oct 2013    Post subject: Reply with quote
Is there a strip along the bottom?
Many of these are used to stop the door if something hits it. Check that this is not faulty or damaged. As it will not prevent operation going up, but may cause it to continually stop while trying to bring it down.
mjn51
PostPosted: 19:25 - 17 Oct 2013    Post subject: Reply with quote
Automatic doors have a safety control built in to stop in shutting to hard on an obstruction.
If it is to stiff shutting it could trigger it, try lubricating the runners, and any wheels etc.
HTH Mike
PostPosted: 20:26 - 17 Oct 2013    Post subject: Reply with quote
HTH Mike
Oldie
PostPosted: 06:27 - 18 Oct 2013    Post subject: Reply with quote
Sounds like the metal frames that the rollers run along are out of alignment. Check where they are joined as even being slightly out will cause the problem you describe. Grease the rails whilst you are at it.
fredsredhat
PostPosted: 09:38 - 18 Oct 2013    Post subject: Reply with quote
If the led on the curtain sensor isnt flashing when it passes a magnet either the magnet is too far away or the batteries have died. Open the cover (on curtain mounted sensor) and they are 2 cell type batteries.
Symon27
PostPosted: 14:38 - 18 Oct 2013    Post subject: Reply with quote
Ive replaced the batteries and still the same, ive uploaded some videos.
https://www.youtube.com/watch?v=LMLJkiJasYE
https://www.youtube.com/watch?v=uHWG4rGxjJg
Zxr 400 - Sold
fredsredhat
PostPosted: 17:50 - 18 Oct 2013    Post subject: Reply with quote
Straight away can see the sensor is too far away from the magnets. The magnets act as a guide to the safety edge so it knows where the door position is in relation to the limits. (Where it stops top and bottom) send the door down but not so it touches the floor and bar tge curtain toward the magnets. Yoy shouldn't be able to see the fabric strip. After that send it up and unplug the wall unit. Leave a few minutes and hopefully that should be fixed
Symon27
PostPosted: 19:15 - 18 Oct 2013    Post subject: Reply with quote
I understand most of that but do what to the curtain? And i can't unplug the wall unit but can turn it off though the mains?
Zxr 400 - Sold
fredsredhat
PostPosted: 08:23 - 19 Oct 2013    Post subject: Reply with quote
The entire curtain needs to be moved 20mm toward the magnets. (Crow) bar it over but be aware its only foam filled aluminium so gentle but firm
The last post was made 13 years, 32 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.66 - MySQL Queries: 16 - Page Size: 126.46 Kb
