Reccomend me some Chain cleaning spray and lube?
mrb-solutions
PostPosted: 13:58 - 02 Nov 2013    Post subject: Reccomend me some Chain cleaning spray and lube? Reply with quote
Want to know what works best for people before I buy some?
CaNsA
PostPosted: 14:01 - 02 Nov 2013    Post subject: Re: Reccomend me some Chain cleaning spray and lube? Reply with quote
I recommend you learn to post in the correct section...
The Workshop
Technical discussions and mechanical advice. Need help with your bike?
mrb-solutions
PostPosted: 14:04 - 02 Nov 2013    Post subject: Reply with quote
Alright, no need to be an arse. I thought it would be general bike chat as nothing is mechanically wrong nor do i need help on how to apply, one was merely asking how people would recommend in buying, my mistake.
If you are not helping then jog on?
instigator
PostPosted: 14:05 - 02 Nov 2013    Post subject: Reply with quote
He is our resident arse.
lihp
I don't agree with lubing chains, it's just a bodge.
I just replace the chain when it starts to dry up Thumbs Up
lihp
PostPosted: 14:07 - 02 Nov 2013    Post subject: Reply with quote
General bike chat is like pub bike chat.
So unless you lube your chain down the pub, then it doesn't belong here.
Since you generally lube your chain doing maintenance which tends to happen in a workshop, that's where it belongs.
CaNsA
PostPosted: 14:09 - 02 Nov 2013    Post subject: Reply with quote
I am helping.
By directing you to the correct section of the forum to get the best info available for the subject you need advice about.
mrb-solutions
PostPosted: 14:12 - 02 Nov 2013    Post subject: Reply with quote
I get that, fair enough, as I was just looking for advice. Didn't need someone to have a go just because I am new and didn't post in the correct section.
I don't know about you but my question sounds like general bike chat to me, just asking what people use etc.
Never mind
CaNsA
PostPosted: 14:15 - 02 Nov 2013    Post subject: Reply with quote
I'm not the one who started being abusive....
Being new is no excuse for being unable to read the descriptions of each section.
I wasn't having a go, i was giving you advice.
You didn't like it, you called me an asshole.
mrb-solutions
PostPosted: 14:17 - 02 Nov 2013    Post subject: Reply with quote
Ha I am actually sorry, I also called u an arse Razz No I wanted some bloody advice on what people recommend haha
Screw Loose
PostPosted: 14:43 - 02 Nov 2013    Post subject: Reply with quote
Clean with malt vinegar
And then lube with soft cheese - I prefer primula, however I know some people on this forum swear by Philadelphia Thumbs Up
Job jobbed Thumbs Up
gbrand42
PostPosted: 15:49 - 02 Nov 2013    Post subject: Reply with quote
I've used Muc-Off chain cleaner with good results, but was given that for nothing, can't help thinking there must be a cheaper way of cleaning a chain.
Paraffin and a washing-up brush would probably work as well as anything maybe?
Can't comment on lube spray, my chain has a Scottoiler and I've always found a handful of spit does for anything else that needs a little lubrication Twisted Evil
Rob W
PostPosted: 16:04 - 02 Nov 2013    Post subject: Reply with quote
I use paraffin and a toothbrush to clean the chain, and get all the shit it's flung off from everywhere else. Best lube I've used was the Wurth stuff, didn't seem to get everywhere, unlike the Silkolene one I've been using recently.
_mjs_
PostPosted: 16:09 - 02 Nov 2013    Post subject: Reply with quote
This. Jimmy Savile always swore by soft cheese as sex lube... because 'kids will do anything for the taste of Dairylea' Thumbs Up
clancy
PostPosted: 18:54 - 02 Nov 2013    Post subject: Reply with quote
I dont clean the chain, just use engine oil to grease it Thumbs Up
KLX 300r
Nick 50
PostPosted: 20:34 - 02 Nov 2013    Post subject: Reply with quote
Another Paraffin fan here for cleaning. I use Castrol chain lube and wax, seems to be doing a decent job so far. Thumbs Up
andy_uk
PostPosted: 00:39 - 03 Nov 2013    Post subject: Reply with quote
Also paraffin for cleaning...
During the summer (i.e. during times of minimal rain) I use a 'dry lube' (Wurth etc), and the other 51 weeks of wetness I just use spray grease. (clean when it looks like it needs it, spray grease it every couple of wet rides.)
Islander
PostPosted: 00:48 - 03 Nov 2013    Post subject: Reply with quote
Paraffin or diesel to clean. I use a stiff washing up type brush and an offcut of plywood to prevent the tyre from being splattered.
Oil with EP90 gear oil. Apply it with an old paintbrush, allow it to soak in and wipe the excess off with a rag. It's heavy enough not to fling and it's recommended as a lubricant by bike and chain manufacturers.
Both paraffin/diesel and EP90 are as cheap as chips and work really well. Thumbs Up
andy_uk
PostPosted: 00:58 - 03 Nov 2013    Post subject: Reply with quote
^^^This! and some poly sheet on the floor to catch the drips so you don't wheel the bike over a patch of slippy stuff!
janner_10
PostPosted: 08:23 - 03 Nov 2013    Post subject: Reply with quote
I've never cleaned a chain.
thepuma
PostPosted: 08:46 - 03 Nov 2013    Post subject: Reply with quote
Ive often thought this....ive never cleaned a chain, just lubed it every now and then...mainly cos im too lazy to go to the effort and mess of doing it.
Does a chain really need cleaning?
765 RS
gbrand42
PostPosted: 10:20 - 03 Nov 2013    Post subject: Reply with quote
I think its best to get rid of all the bits of grit that will stick to your chain, cause if you oil over the top of crud you will just make a nice grinding paste. Better to get back to clean chain and go from there IMHO Thumbs Up
thepuma
PostPosted: 10:52 - 03 Nov 2013    Post subject: Reply with quote
I tend to find when I spray the new lube on (castrol racing lube) it tends to wash off most of the crud and leaves a cleanish chain. Im probably spraying too much on, but I tend to feel that too much is better than too little.
765 RS
Islander
PostPosted: 12:59 - 03 Nov 2013    Post subject: Reply with quote
Yes. Over time the chain will have collected all sorts of road dirt which will mix with the lubricant to form an effective grinding paste and accelerate wear. Use of an oiler helps keep things clean but even then it'll need a proper clean once in a while.
Then there's the crud that accumulates under the front sprocket cover...
Renton
PostPosted: 15:35 - 03 Nov 2013    Post subject: Reply with quote
This;
https://www.sportsbikeshop.co.uk/product_images/medium/wurth_twin_pack.jpg
https://www.sportsbikeshop.co.uk/motorcycle_parts/content_prod/22977
This is my motorcycle. There are many others like it, but this one is mine.
Without me, my motorcycle is useless. Without my motorcycle, I am useless.
The last post was made 12 years, 331 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.92 - MySQL Queries: 16 - Page Size: 131.54 Kb
