Fitting Daytona heated grips
Jonathan A
PostPosted: 16:52 - 16 Nov 2013    Post subject: Fitting Daytona heated grips Reply with quote
I have bout Daytona heated grips, and I'm going to set about installing them. I'm determined not to wire them direct to the battery, as I'm sure to leave them on and drain the battery.
I am planning on connecting the live to the wire marked R on this diagram:
https://s574.photobucket.com/download-albums/ss182/hmmmnz1/Hyosung/gt650comet.jpg
Is this a wise choice?
Cheers Very Happy
J.M.
PostPosted: 17:12 - 16 Nov 2013    Post subject: Reply with quote
There are multiple live wires marked R on that diagram, which do you mean?
A common (and my) choice is to use the positive feed for the tail light as the switched live for the relay. Then run all your accessories from the relay.
2004 R1 & 2018 XSR900
J.M.
PostPosted: 17:21 - 16 Nov 2013    Post subject: Reply with quote
You ride around Spain for a day wondering why your phone is refusing to charge Embarassed
Jonathan A
PostPosted: 17:56 - 16 Nov 2013    Post subject: Reply with quote
Actually using R seems a stupid Idea. I will probably do it with a relay instead, like J.M. Said. If I used the rear light as a feed, where would I connect the earth to?
Btw I have no clue what I'm doing Mr. Green
J.M.
PostPosted: 18:01 - 16 Nov 2013    Post subject: Reply with quote
A relay is simple:
https://www.banzai-racing.com/how_to/std_relay_connections_diagram.jpg
Pin 86: the switched brake light +12v
Pin 30: battery +12v (with fuse)
Pin 85: to battery negative
Pin 87: supplies +12v to the accessory
Jonathan A
PostPosted: 20:12 - 16 Nov 2013    Post subject: Reply with quote
So for pin 86 on the relay, could I connect it to yw on my diagram (rear light), and cut into the wire near the headlamp relay?
J.M.
PostPosted: 20:49 - 16 Nov 2013    Post subject: Reply with quote
I think YW should do it. I usually choose the rear light as it's closest to where I physically install the relay. Also it's arguably one of the least important lights (although you have a registration plate light... it would be 'such' a shame if that went off XD), although it has the risk of not being incredibly noticeable if the light breaks other than your pre-ride checks.
Jonathan A
PostPosted: 22:16 - 19 Nov 2013    Post subject: Reply with quote
All sorted Smile I powered the relay from the numberplate light circuit, which seems ok, as the lights cannot be turned off on my bike. The only bad thing is the mass of wiring under the seat now Confused
FriendlyEllis
PostPosted: 22:56 - 19 Nov 2013    Post subject: Reply with quote
https://www.canyonchasers.net/shop/generic/relay.php
Honda CB600F Hornet 2013 -> Kawasaki Z1000SX ABS Tourer 2015
The last post was made 12 years, 233 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.76 - MySQL Queries: 16 - Page Size: 71.83 Kb
