| charrington96 |
 charrington96 Borekit Bruiser
| Nobby the Bastard |
| charrington96 |
| stirlinggaz |
 stirlinggaz World Chat Champion
| charrington96 |
| map |
 map Mr Calendar
 Posted: 21:49 - 29 Nov 2013 Post subject: |
Could it be carbon build up in exhaust? ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Shaft |
 Shaft World Chat Champion
| Walloper |
 Walloper Super Spammer
| charrington96 |
| mysterious_rider |
 mysterious_rider World Chat Champion
| charrington96 |
| c_dug |
 c_dug Super Spammer
 Posted: 11:29 - 30 Nov 2013 Post subject: |
If it turns out it needs it rebuilding a 2 stroke is a doddle, if you have the right temperament that is, 17 year old me didn't and made a right mess of refurbishing a TDR250 because of it  ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| bikenut |
 bikenut World Chat Champion
| charrington96 |
| bikenut |
| charrington96 |
| Walloper |
| charrington96 |
| c_dug |
 c_dug Super Spammer
| Nobby the Bastard |
| charrington96 |
| Ichy |
 Ichy World Chat Champion
 Posted: 16:41 - 30 Nov 2013 Post subject: |
I think you need to check a few bits first before considering a rebuild.
Is the spark plug fitted correctly?
If you block the end of the exhaust does the 'ped keep running or cut out?
Is the air filter clean and fitted correctly? ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| stirlinggaz |
 Posted: 16:57 - 30 Nov 2013 Post subject: |
hi,
after compression test, it would be ideal time to de-coke exhaust.
remove whole exhaust off bike & then remove muffler & block up one end of the expansion chamber. (a potato is ideal beleive or not).
then get some caustic soda from b&q,wickes, local hard-ware shop etc.
read the instructions, then read them again
use proper ppe, caustic soda is nasty stuff, good for melting hands etc
once you have the desired amount of mixture, pour it into the spanny, right up to the top. (i should have mentioned this earlier : it works better if one end is blocked & this is at bottom. then just leave it sitting against a wall. overnight preferably.
i then empty out all the crap (& there will be loads of it) & repeat the process.
i know it sounds a bit excessive, but i find the 1st solution loosens off a lot of the gunk & the 2nd solution cleans it out throughly.
i've done it on umpteen 2t exhausts with good results. just dont let it come into contact with alloys,aluminium, skin etc
CAUTION : I take no responibility if op or anyone else for that matter, blinds themselves, burns all the skin from his hands etc
cheers,
GAZ
| Walloper |
| stirlinggaz |
The last post was made 12 years, 201 days ago. Instead of replying here, would creating a new thread be more useful? |
