I wonder where this wire goes?
ninja_butler
PostPosted: 13:18 - 30 Nov 2013    Post subject: I wonder where this wire goes? Reply with quote
Attached to the horn there is a a small bar-shaped thing which has something to do with the regulator/rectifier. I know that unless it is connected the headlight bulb will repeatedly blow, but I'm not sure where the damned thing connects to!
Circled are the component and the end of the wire.
https://i1213.photobucket.com/albums/cc469/Ninja_Butler/Honda%20XL%20250/regulatortypethingy.jpg
https://i1213.photobucket.com/albums/cc469/Ninja_Butler/Honda%20XL%20250/IMG_0004.jpg
Can anyone shed some light on it?
PostPosted: 13:20 - 30 Nov 2013    Post subject: Reply with quote
That's the vaguest paint diagram ever.
Looks like the throttle cable. The throttle cable is within that huge circle you've drawn anyway.
jjdugen
PostPosted: 13:24 - 30 Nov 2013    Post subject: Reply with quote
Ballast resistor....?
PostPosted: 14:40 - 30 Nov 2013    Post subject: Reply with quote
Ballast resistor.
It should be connected in pralell with the sidelight. It is already earthed to the frame.
Honda usually use a pink wire for the ballast so if there is a pink wire with nothing connected to it inside your headlamp shell, that's where it goes.
ninja_butler
PostPosted: 15:05 - 30 Nov 2013    Post subject: Reply with quote
Ballast resistor! Yes that's it, well done jjdugen and stinkwheel. Thumbs Up
The wiring is a mess, it works okay but some of the wires are the wrong colour. I do recall seeing a pink wire though. Thank you very much Stinkwheel, I'll take a look inside the headlight tomorrow.
The last post was made 12 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.68 - MySQL Queries: 16 - Page Size: 45.32 Kb
