CG125 charging problems
Laura1985
PostPosted: 23:50 - 03 Dec 2013    Post subject: CG125 charging problems Reply with quote
I have a 2004 honda cg125-es4 and it's been great until recently.
Sorry I'm new to this so here's the history...
New battery fitted then all summer it was used daily for long and short journeys with no problems at all. I went on holiday for a week and came back expecting it may not start, put my trickle charger on overnight, went out to it and still nothing until someone smacked the starter motor and it fired into life. Then started to have issues with it just clicking on the starter so stripped down the starter and changed the brushes...again no further issues.
Now with it getting much colder in Scotland its doing more short journeys and it's being very temperamental, some mornings it'll start no problem, others I have to push start it (no useful kick start on this model!). If I charge it it'll be fine for a couple of days..then if I don't use it for a day it won't start the next. Push start it, go to work and it'll bring me home no problems hours later...so it is obviously charging. Generally the trickle charger shows the battery to be around 11.5 volts on the days it won't start and it boosts it to full no problem. But when the starter is pushed it always drops by at least a volt hence when it's only at 11.5V it doesn't have the power to turn the engine.
I know the cold and short journeys aren't helping, and I've stopped using my heated grips over a month ago unless it's a long journey..totally negates the point of having them when it's cold but wanted to rule out them taking the extra power the battery might be needing.
So new battery, new brushes, new spark plug and I'm out of ideas...is it possible to upgrade the regulator so it's getting more of a charge on the short journeys? Any help would be greatly appreciated...also sorry for rambling Very Happy
heapy
PostPosted: 03:42 - 04 Dec 2013    Post subject: Reply with quote
sounds like a power drain from possibly your starter motor if youv got a new battery, dont have this problem due to my cg having kickstart only.
I have heard that startermotors take more out of your battery in cold weather. Sorry i cant be of more help, never had electric start. Someone on here is sure to be more helpfull tho.
if it has 2 wheels and an engine its a bike
davebike
PostPosted: 09:16 - 04 Dec 2013    Post subject: Reply with quote
CG125 charging system is not really up to running heated grips if you just doing short journeys Unless you charge the battery regularly as well
There is not really anything you can do as I don't think there is any uprated windings made
Dave
Dave
NC750Xdct + others at work !
[email protected]
Fizzer Thou
PostPosted: 11:14 - 04 Dec 2013    Post subject: Reply with quote
If you have your multimeter to hand check from the negative post of the battery to various chassis points.It should read about zero ohms resistance if all of the earth strap connections are good.
Check also to see what comes out of the alternator.On Hondas it is usually the yellow wire(s).If you disconnect the multi-block from the alternator housing with the engine running,measure the AC volts across any 2 yellow wires.There may well be about 17VAC across any two yellows.
With the engine running,measure the DC volts across the battery terminals>If you rev the engine,does the reading increase or stay at about 12V?A good charging system should be about 13.5VDC to keep the battery topped up.The regulator is normally a set output,but if any earth connections are corroded,this will upset things.
Always have a 'Plan B'
The last post was made 12 years, 218 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.47 - MySQL Queries: 16 - Page Size: 43.29 Kb
