Er6f maintainance ??
Bozzie08
PostPosted: 16:54 - 01 Jan 2014    Post subject: Er6f maintainance ?? Reply with quote
So I've got a 2011 er6f had it about 2 months.
Serviced before I got It and had 3500 miles on the clock.
The next service is due at 7500, is this right?
Also what maintainance should I be doing myself? I'm putting the muc off chain lube on every couple of weeks and have been giving it a spray of gt85 every week or so.
Is there anything else I should/could be doing? When should I change the oil etc do I wait for the service or do it before hand?
Cheers
Copycat73
PostPosted: 19:12 - 01 Jan 2014    Post subject: Reply with quote
quick search on google and up comes a pdf. manual for your bike
page 25 has a servicing schedule
caveat emptor
iMark
PostPosted: 19:57 - 01 Jan 2014    Post subject: Reply with quote
That says ER-5 not ER-6 ? Razz
K8 GSXR 1000
Frog
PostPosted: 22:13 - 01 Jan 2014    Post subject: Re: Er6f maintainance ?? Reply with quote
Cheers
Might be stating the obvious, but do you have a manual?
I have a 2009 (same model as yours), so I can probably scan the relevant pages if you need, but you'll be better with an original manual if you've got one.
CBT 23/09/10 - Theory 19/03/11 - Mod1 19/04/11 - Mod2 06/05/11
Bikes: CBF125 (sold 30/10/10-25/09/12) - CB400 24/06/11 (broken) Sad - ER6-f 25/09/2012 Very Happy
Bozzie08
PostPosted: 06:57 - 02 Jan 2014    Post subject: Re: Er6f maintainance ?? Reply with quote
Cheers
I've got the manual yeah just didn't known of there was any standard things I should be doing.
I will check the manual see what it says.
Cheers
davebike
PostPosted: 09:09 - 02 Jan 2014    Post subject: Reply with quote
A weekly check would be a good start
Tyre pressures tread depth check and all around check for damage and For nails screws etc
Check oil level and coolant levels
Lubricate chain and check tension
Check ALL light work correctly
this is very basic
Dave
Dave
NC750Xdct + others at work !
davebike1@gmail.com
PostPosted: 09:18 - 02 Jan 2014    Post subject: Reply with quote
I change the oil on my 125s every 1000 miles, bigger bikes would probably get 2000>3000 before a change.
List as above really, check tyres, tyre pressures, brake pads, fork seals, chain tension.
mjn51
PostPosted: 14:18 - 02 Jan 2014    Post subject: Reply with quote
The er6f should have an oil service every 7.5k miles the 3.5k service is more or less a visual check for leaks etc. according to my er6f service manual
mjn51
PostPosted: 14:19 - 02 Jan 2014    Post subject: Reply with quote
Bozzie08
PostPosted: 17:27 - 02 Jan 2014    Post subject: Reply with quote
That's when it's next due in so that figures.
I've been doing all what's listed above really just didn't know if there was anything else.
Looks like I just need to keep doing what I'm doing.
Just out if interest what's the cost if the 7.5 k service. I know it will obvious differ but whats the ball park figure?
The last post was made 12 years, 145 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.65 - MySQL Queries: 16 - Page Size: 67.83 Kb
