Honda NSR 125 not starting
Skafander
PostPosted: 11:30 - 22 Aug 2013    Post subject: Honda NSR 125 not starting Reply with quote
Okay, been having this problem since spring and haven't been able to ride at all, basically what happened is i decided to modify the bike to look like a streetfighter-ish thing, removed fairings, new handlebar, new digital clock, headlight and lots of other bits.
At first i didn't realise anything bad could come of me connecting the new headlight which had 2 55W bulbs in it (the NSR is supposed to have 35W bulbs at max), but after connecting, turning the light on and letting it run for 1-2 minutes the bike died and hasn't started since, i'm thinking the headlight could have caused this but i don't know what it actually did, or what part it damaged, it just doesn't spark anymore.. so if anyone can give me any ideas, i'd be very thankful.
Skafander
PostPosted: 11:21 - 06 Sep 2013    Post subject: Reply with quote
No one has any ideas?
PostPosted: 11:29 - 06 Sep 2013    Post subject: Reply with quote
Yeah, its broken and you need to fix it.
Skafander
PostPosted: 11:53 - 06 Sep 2013    Post subject: Reply with quote
Wow, thanks alot!
PostPosted: 11:55 - 06 Sep 2013    Post subject: Reply with quote
Most welcome Thumbs Up
Seriously though, remove the lights, check the fuses.
Skafander
PostPosted: 12:04 - 06 Sep 2013    Post subject: Reply with quote
i've already had all the connections in the wiring checked and i've disconnected the headlight.
Is there more than 1 fuse?
PostPosted: 12:08 - 06 Sep 2013    Post subject: Reply with quote
More than likely... unsure on this specific bike but ones I've owned have lights, ignition and you also have a main fuse on the starter solenoid. Unsure on your bike as I said..
alains
PostPosted: 14:34 - 06 Sep 2013    Post subject: Reply with quote
if you havnt sparks , several possibilities :
- fit a new plug (BR9EIX because BR9ECS is bull shit)
- check ignition coil (mesurement values are in my file NSRtips.doc) and obviously with and without the cap
- check stator and impulse coil (values are also in my doc)
you can check your stator with a voltmeter set on 200VAC between ground (green wire or the frame) and the black/red (unplug the connector and test on this wire and ground) . take off the sparkplug then push start button for 5 to seconds while watching your meter . you should read at least 75 VAC . if not your stator is probably worn
PostPosted: 14:38 - 06 Sep 2013    Post subject: Reply with quote
Thought Iridiums are useless on 2 strokes due to the fouling and lack of being able to clean...
alains
PostPosted: 18:01 - 06 Sep 2013    Post subject: Reply with quote
you are wrong , even on my lawnmower i use them and since 1993 i use them on my NSR's (i had 3) and never had problem
i change it once a year
Skafander
PostPosted: 21:51 - 03 Nov 2013    Post subject: Reply with quote
i have checked the ignition coil, impulse coil and alternator just as you have written in your NSRtips document, all the measurements were within the limits, but to check like you have written here, i have to have the alternator on the bike but not connected? Do i have to connect the impulse coil?
Nobby the Bastard
Harley Gaydar
PostPosted: 22:02 - 03 Nov 2013    Post subject: Reply with quote
According to this wiring diagram https://binatani.com/wp-content/uploads/2011/10/honda-nsr125r-motorcycle-chassis-system-wiring-diagram.jpg an NSR125 has only one fuse (this could be the wrong year though).
Triumph Sprint ST 1050
Skafander
PostPosted: 08:34 - 04 Nov 2013    Post subject: Reply with quote
That's right, the nsr does only have 1 fuse
Skafander
PostPosted: 15:19 - 04 Nov 2013    Post subject: Reply with quote
i tested with 200 V AC on the meter between the green and black/red, got only 10-12.5 volts.. i guess i'm gonna get a new stator then.
alains
PostPosted: 19:19 - 07 Nov 2013    Post subject: Reply with quote
you're right , should read around 70-80 VAC
plenty of those on eBay at reasonnable price
this one look the best
https://www.ebay.co.uk/itm/STATOR-GENERATOR-HONDA-NSR125-1999-FOXEYE-/111208729403?pt=UK_Motorcycle_Parts_13&hash=item19e48e8b3b
Skafander
PostPosted: 09:41 - 08 Nov 2013    Post subject: Reply with quote
Thanks Alains, i checked at the dealer and they want 260€ for a new stator, no way i'm paying that :S
stirlinggaz
PostPosted: 10:19 - 08 Nov 2013    Post subject: Reply with quote
hi,
i agree paddy, they are very fickle, & once fouled they are f*cked.
might be ok on the nsr, after all some power is sacrificed for reliabilty. (probably the most reliable of the 2t "race replicas") but useless on the likes of rs,mito etc due to being reliant on a perfectly set up carb mixture at ALL times & being the UK & especially up here the weather makes a fair difference to a 2t,
better off buying 3 copper plugs, same price as 1 iridium imho,
cheers,
GAZ
skatefreak
PostPosted: 10:50 - 08 Nov 2013    Post subject: Reply with quote
Had an iridium in my NSR for a fair while.
Seemed to 'fair' as well as the other plugs for life expectancy but didn't make the world of difference running wise from what I can remember...
-Jvr
Skafander
PostPosted: 17:10 - 15 Jan 2014    Post subject: Reply with quote
i finally put my new stator on, nothing changed, still same old story, i get a yellow spark and its not consistent, shows up rarely.
I'm bummed, feel like it's just easier to go and get a new one cause i'm not missing out on another summer, i've had the bike checked by 2 mechanics and i'm dissapointed and feel like shit... hooray Very Happy
EDIT
I got 12.5 volts AC with the last stator, now with the one i got from ebay i measure 50 flat but still no spark.
SQL
PostPosted: 20:33 - 15 Jan 2014    Post subject: Reply with quote
coil? plug cap dicking around ?
Skafander
PostPosted: 08:49 - 16 Jan 2014    Post subject: Reply with quote
idk, i've measured the coil and cap with the multimeter as alains has written in his guide, everything is ok..
dydey90
PostPosted: 09:21 - 16 Jan 2014    Post subject: Reply with quote
What you should do at this point is sell it at me for a reasonable* price and then all your problems are gone Smile
*By which I mean next to nothing
Skafander
PostPosted: 09:38 - 16 Jan 2014    Post subject: Reply with quote
I wish that was possible Very Happy
I'm in eastern Europe, if i would sell it to you, what would you do with it? Very Happy
dydey90
PostPosted: 11:21 - 16 Jan 2014    Post subject: Reply with quote
I'd fix it up and use it for winter/bad weather, since it's got no fairings. I have enough time to spend dicking about in the garage with it to find out what's wrong.
Skafander
PostPosted: 18:11 - 16 Jan 2014    Post subject: Reply with quote
I was hoping you'd know whats up Very Happy
Think i'm gonna sell it as parts, don't have a lot of NSR owners around here though, gonna be a slow process...
I've got 2 sets of unrestricted cdis 2 ci626 and 2 TV-78 for the servo anyone? Very Happy
The last post was made 12 years, 309 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.85 - MySQL Queries: 16 - Page Size: 130.57 Kb
