| martyn107 |
 martyn107 Scooby Slapper
| Islander |
 Islander World Chat Champion
 Posted: 17:54 - 18 Jan 2014 Post subject: |
Nope. I use any old fuel with no additives whatsoever. Bikes have never missed a beat. Redex and the like are a waste of money.  |
| RhynoCZ |
 RhynoCZ Super Spammer
 Posted: 18:17 - 18 Jan 2014 Post subject: |
I used some STP product in GPz550, worked like charm, I'm gonna try it in the ZXR before I take the carbs out.  ____________________ '87 Honda XBR 500, '96 Kawasaki ZX7R P1, '90 Honda CB-1, '88 Kawasaki GPz550, MZ 150 ETZ
'95 Mercedes-Benz w202 C200 CGI, '98 Mercedes-Benz w210 E200 Kompressor |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 18:23 - 18 Jan 2014 Post subject: |
nope nothing, cheapest stuff i can find, to match the cheapest oil thats in the bike, only concession my bike gets is diesel oil, but thats only ok if you have a dry clutch
supposedly you can get better mpg from higher octane fuel, but really you'd have to have a f.i. bike to compensate for it, since i dont, i dont bother, ____________________ the humans are dead
I kick arse for the lord
Wiring Diagrams BIDNIP it bitches |
| Copycat73 |
 Copycat73 World Chat Champion
| simonjb |
 simonjb Nova Slayer
 Posted: 21:35 - 18 Jan 2014 Post subject: |
I use Shell Nitro+ or BP Ultimate usually, as they have some engine friendly additives. Main difference is it runs a little more smoothly, and extracts another 5-10 MPG out of my F.I. YBR. As MPG is so high, the price difference is not a problem.
It does also FEEL slightly more powerful (even though it's still only a 125), but I won't trust that as it could just be placebo. ____________________ Current Bike: 2008 Yamaha YBR 125 |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| Wafer_Thin_Ham |
| P.addy |
 P.addy Red Rocket
 Posted: 22:20 - 18 Jan 2014 Post subject: |
I have never used any additive. Petrol is expensive enough as it is.
The bikes will happily run on the cheapest stale petrol as long as it still goes boom boom when exposed to spark spark.
I've ran my old pit bike ongine on 6 month old green looking fuel with some diesel and 2 stroke in there... likely to be brake fluid also.  |
| simonjb |
 simonjb Nova Slayer
| Wafer_Thin_Ham |
| Kickstart |
 Kickstart The Oracle
 Posted: 22:44 - 18 Jan 2014 Post subject: |
Some bike do require 95 RON min, but quite a lot of Japanese bikes only require 91 RON.
Never noticed any difference in performance using higher octane fuels on any of the bikes, nor on most of the cars (the exception being the Maserati which has noticeably more power on higher octane fuel, but then it does have a knock sensor and a couple of turbos). Never bothered to use any additives, although one to prevent the fuel gumming up jets might be tempting on rarely used bikes.
| P.addy |
 P.addy Red Rocket
| Wafer_Thin_Ham |
| Tungtvann |
 Tungtvann World Chat Champion
| Copycat73 |
| Copycat73 |
| Islander |
| stevo as b4 |
 Posted: 13:38 - 19 Jan 2014 Post subject: |
I've used pour in injector cleaner on various old EFI car's, and also changed the fuel filter first. I'd like to believe that injector cleaner works, but have no evidence of this.
I think with additives it depends on what you want them to do really, as no additive will magically do everything from giving more mpg, more bhp, less engine wear, free up sticky valves etc.
I've used pour in octane booster on 2stroke engines, when I have increased the compression ratio, but 98-99RON fuel would be just as good. However if your after high octane fuel I've been told that adding a decent octane booster to 98RON UL, can achieve 102-103RON fuel, which is useful for race engines, very high compression engines, and Japanese import cars that were tuned for more power and designed for 100RON home market fuel.
In my Rover I use 97-98RON SUL, as it does have a knock sensor, and my engine is tuned running higher boost and a bigger turbo than std, so it might be closer to det at high boost, seeing as I run a std factory ECU with no additional fueling.
If I wanted to clean an engines combustion chamber's, and try to clean carboned up valves and rings, I would just spray water into the engine whilst running, as I think water cleans things as well as any chemical can! |
| Kickstart |
| Copycat73 |
| mentalboy |
 mentalboy World Chat Champion
 Posted: 15:23 - 19 Jan 2014 Post subject: |
They put enough shit into fuel without having to spend more money countering it.
Slightly off topic but the ethanol they now add is playing havoc with the rubber hoses on my fuel system. I've just had to get a length of something ethanol resistant to replace them, I'd expect cracked hoses in a twenty year old bike but they've turned into a slimy mess. Not happy  ____________________ Make mine a Corona. |
| Copycat73 |
| martyn107 |
| bladerunner |
 bladerunner World Chat Champion
The last post was made 12 years, 277 days ago. Instead of replying here, would creating a new thread be more useful? |
