20mph crash bent forks
guile
PostPosted: 15:23 - 14 Feb 2014    Post subject: 20mph crash bent forks Reply with quote
So I hit somebody head on and my forks are bent (20mph estimated impact speed). I don't have the means to take them off and inspect them but I just want to know if it is likely that the fork legs could be bent in addition to fork tubes. Apparently the wheel is slanting diagonally from left to right.
I have read that fork legs rarely get bent as the tubes are the weaker part. Obviously replacing legs will cost a shit ton more than just doing the tubes.
Also would it be worth replacing the steering head bearings?
PostPosted: 15:48 - 14 Feb 2014    Post subject: Reply with quote
Worth either getting the forks and yokes straightened or just a new straight set from ebay shoved on there.
Might as well regrease the head bearings, replace if you know how.
PostPosted: 16:28 - 14 Feb 2014    Post subject: Re: 20mph crash bent forks Reply with quote
Generally only bend one bit - so if the stanchions are bent, the rest are fine.
PostPosted: 20:20 - 14 Feb 2014    Post subject: Reply with quote
What bike?
If you've bent the tubes you should check around the headstock for flaking paint, a sign that the frame is bent.
The last post was made 12 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.82 - MySQL Queries: 16 - Page Size: 45.47 Kb
