Bike won't start after sitting in the sun?
california_rookie
PostPosted: 19:32 - 28 Dec 2004    Post subject: Bike won't start after sitting in the sun? Reply with quote
Here's an odd question. Well, at least I think so. Is there any plausible explanation for why my bike takes forever to start after it sits in the sun for a bit? Even after just half an hour of sun-bathing it can take at least 10-15 sec's of turning over before it'll cough and sputter to life. I find this odd because it starts after only one or two revolutions under normal circumstances and fires up immediately even in the frosty morning hours.
My theory is there's a build-up of hot air in the intakes and air box which I seem to remember hearing is harder to combust than cold air. Or maybe it's a chemical thing? Hell, I dunno. Maybe that's why I'm asking. Any help would be greatly appreciated.
https://www.bikepics.com/members/californiarookie/04gsxr600/
https://www.myspace.com/spapadillion
https://steamcommunity.com/id/spapadillion
Claud 14.7 to 1
PostPosted: 19:54 - 28 Dec 2004    Post subject: Reply with quote
When I start my bike from cold I only need a bit of gas to get it started. (Or choke and a tiny bit of gas, on a cold UK/Winter day)
When the engine is hot the bike needs more throttle when turning over to get it started.
Do you mean starting the bike from cold, when it has been in the sun or when, for example, you have ridden it, left it in the sun for a few minutes and then gone to start it???
Try more throttle when turning over.
Engines stay hot/warm for a long time, especially sports bikes. 1/2 an hour, the engine will still be warm.
Minky_monkey
PostPosted: 20:08 - 28 Dec 2004    Post subject: Reply with quote
What about fuel evaporation?
I've experienced it with cars before, all I've done is undo the filler cap.
Not sure whether it would be a similar problem, but hey, it's worth a try!
dodsi
Dirty Carny
PostPosted: 20:41 - 28 Dec 2004    Post subject: Reply with quote
Your just gloating because you have sun, Over here in good o'l Britan we have no sun or warmth!
PostPosted: 22:46 - 28 Dec 2004    Post subject: Reply with quote
Ok, here's my story to explain it. I made it up myself so I don't know if it is correct.
Bike has a vaccuum fuel tap. When you start the bike, it starts up on the fuel lurking in the float bowl from when you last ran it. In the sunshine, the fuel in the float bowl evaporates and exits via the vent. Therefore when you then come to start it, there is no fuel and the engine will not start immediatley.
The fuel can only run into the float bowl when the engine is turning over (and applying vaccuum to the tap), it takes a few revolutions for enough fuel to run in to start the engine. Hence the delay.
If your fuel tap has a 'prime' position, try setting the bike to this for a few seconds before attempting to start it, this circumvents the need for vaccuum to make fuel run in.
Robin
PostPosted: 15:38 - 02 Jan 2005    Post subject: Reply with quote
Same sort of thing as I was thinking Stinky. I've had a similar problem when the bike has been left standing for a while. A couple of seconds with the tap on 'prime' worked.
BlackSheep
PostPosted: 20:33 - 02 Jan 2005    Post subject: Reply with quote
Its called vapour lock , certain makes of car also suffer from it
i used to have a BMW 316 that would occaisionally do it if left in the hot sunshine , as someone said above just put your fuel tap onto prime for a couple of seconds before you start your bike
GSXR 1100 StreetFighter
PostPosted: 20:40 - 02 Jan 2005    Post subject: Reply with quote
Is it fuel injected? If so the vapour lock is not that likely (a 40~50psi pump should overcome it).
Also worth a check is any evaporation from the tank, which probably goes into a carbon canister, and is then drawn from there when the engine is started. This might be getting the mixture very rich when first started.
The last post was made 21 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.85 - MySQL Queries: 16 - Page Size: 60.09 Kb
