problems starting and running my 1999 zx6
beefcake26
PostPosted: 16:21 - 03 Mar 2014    Post subject: problems starting and running my 1999 zx6 Reply with quote
i have resynched my carbs, have good fuel, fuel delivery to carbs is good, carbs are clean, new coils and wires, new plugs and new battery. still cant get it to start properly. any suggestions for me. i need to start riding again.
bodger
PostPosted: 17:55 - 03 Mar 2014    Post subject: Reply with quote
Shot in the dark.
Hole in carb diaphragm/s
beefcake26
PostPosted: 22:57 - 03 Mar 2014    Post subject: Reply with quote
Diaphragms are completely intacted. The bike will fire on ether and then continue running gas until a few days ago. Now it doesn't want to fire.
davebike
PostPosted: 08:57 - 04 Mar 2014    Post subject: Reply with quote
Is your fuel pump working ??
Something about the Diversion 6 I seen several with fuel pump problems
Take the lead to the pump off drain the carbs and connect the pump's lead across the battery it should pump and you can feel the pulse as it refills the carbs
If it doesn't pump it probably the points with in the pump there about £20 but very fiddly to fit I had customers break a new set Sad
Dave
Dave
NC750Xdct + others at work !
[email protected]
The last post was made 12 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.68 - MySQL Queries: 16 - Page Size: 39.42 Kb
