| -Matt- |
 -Matt- World Chat Champion
 Posted: 18:41 - 31 Mar 2014 Post subject: Spark plug |
Trying to work out whats going on with my bike at the moment as its not running too well in low revs, particularly first gear - valves booked in next week for now.
I just found this picture of my previous spark plugs - does the lack of oil on one of the threads and the burned patch on the side of that plug indicate anything, or is it only really the gapped areas condition that can show problems usually the odd one out is from the 1st cylinder [1234 left-to-right] if that could explain where the problem is causing the low end power loss?
https://i61.tinypic.com/2196zad.jpg |
| mentalboy |
 mentalboy World Chat Champion
| -Matt- |
 Posted: 18:51 - 31 Mar 2014 Post subject: |
Ah right even less clear about what could be the cause then in that case Thanks |
| mentalboy |
| -Matt- |
 Posted: 19:04 - 31 Mar 2014 Post subject: |
Its hard to tell at the moment whats going on sound wise as the CCT has been noisy and hasn't adjusted itself yet.
Never had valves done [due 26k miles],and its at 23k now. Its fuel injection - is there anything similar to carb balancing i'd be needing to think about
Think I took those plugs out about 15k IIRC, might think about pulling the current plugs out this week and having a look at what condition they're in now. |
| mentalboy |
 Posted: 19:08 - 31 Mar 2014 Post subject: |
Probably best not to ask for a carb balance in the shop then
If they're doing the valves then they can attend to the rocker gasket at the same time. I'm not sure what planet I'm on tonight - typos everywhere! NOT head gasket!!! ____________________ Make mine a Corona. |
The last post was made 12 years, 183 days ago. Instead of replying here, would creating a new thread be more useful? |
