| c_dug |
 c_dug Super Spammer
| Matt B |
 Matt B World Chat Champion
| c_dug |
 c_dug Super Spammer
| Vincent |
 Vincent Banned
 Posted: 12:49 - 04 Apr 2014 Post subject: |
Have you looked on the Divvy forum for any recommended upgrades? Before buying and swapping parts over, it's always cheaper to let someone else do the research
When was the oil last changed? Maybe you could try a heavier type? ____________________ Space Is Deep |
| c_dug |
 c_dug Super Spammer
| Hugh Farking Cant |
 Hugh Farking Cant Scooby Slapper
 Posted: 14:08 - 04 Apr 2014 Post subject: |
Not a lot you can do with progressives except increase the preload with a longer/additional spacer; Hagon kits come with the recommended one.
Thicker oil only slows up the damping; it helps but really it masks the problem.
What dia forks ?
There are some very economical cartridge emulator kits out there, primarily designed for other makes that have been fitted and work very well on the Yamaha sports bike range of the same era (late 90,s)
Have you found out how much travel you have left in the forks after severe braking from high speed ?
Check this out;
This may give some indication if it is wise to add further preload'
https://www.fzrarchives.com/ipb/index.php?showtopic=54771&hl=
https://www.sportrider.com/ask-geek-set-your-static-sag
Oil levels,I forgot oil levels. |
The last post was made 12 years, 166 days ago. Instead of replying here, would creating a new thread be more useful? |
