Baffles and cans
Grimeric
PostPosted: 20:12 - 03 Apr 2014    Post subject: Baffles and cans Reply with quote
I am wondering if anyone can help me out with some advice. I have just taken delivery of my first big bike bandit 600.
The chap who had it before me has fitted a stubby can. There is no baffle in this thing and it is loud. Very loud. Loud enough to make the neighbours poke heads out of the door.
I have not taken measurements as yet I will do that first thing in the morning.
I am wondering if you guys have experience of these baffles you can buy on eBay etc. how likely are they to dramatically reduce the noise? Can you guys recommend any decent makes or have any ideas?
There is a hole drilled into the side of the can near the tip that appears to be a screw hole for a baffle. I can not see any makers name or branding on he can, there are some numbers and letters stamped around the back end but that's all I can see.
Here is a picture for reference.
Thanks
Grim
https://i1339.photobucket.com/albums/o712/Grimerick/imagejpg1_zps473c082f.jpg
Az
PostPosted: 20:48 - 03 Apr 2014    Post subject: Reply with quote
Your exhaust looks like a Delkevic stubby. It may be worth calling up Delkevic and asking if they sell the baffle for your exhaust separately.
Grimeric
PostPosted: 21:23 - 03 Apr 2014    Post subject: Reply with quote
Thanks. I will try and locate any numbers and give them a call.
Does anyone have experience with eBay baffles? Would I need an angled one due to the shape of the pipe?
Az
PostPosted: 21:31 - 03 Apr 2014    Post subject: Reply with quote
For £25 I believe you can get the original baffle off the Delkevic site, although I'd call up Delkevic on 01782 338727 and confirm that the baffle on their website will fit your exhaust.
gavbriggs
PostPosted: 22:21 - 03 Apr 2014    Post subject: Reply with quote
Have a look for a dbkiller on eBay, about 25 quid I think. My viper has one and it reduces the noise considerable. I leave it out tho because I like the noise and my neighbours are old and deaf.
Grimeric
PostPosted: 06:30 - 04 Apr 2014    Post subject: Reply with quote
I will give them a call today and see if they can identify it as one of theirs.
If I have to buy an aftermarket baffle will I require one set at an angle due to the angle of the exhaust tip?
PostPosted: 07:13 - 04 Apr 2014    Post subject: Reply with quote
Just put earplugs in.
Don't worry about the neighbours, someone probably has louder. I know my can was shorter and empty. Laughing
Grimeric
PostPosted: 13:40 - 04 Apr 2014    Post subject: Reply with quote
No luck with delkevic. Photos and sizes sent but its not a delkevic can. Any other ideas for getting a decent baffle sorted?
The can is 23cm long 28 including tip. 35cm in diameter.
The outside diameter of the tip is around 18cm and the inside diameter of the tip is 5.5 cm measured as best I can.
I can add more photos later if required.
Grim
c_dug
PostPosted: 14:00 - 04 Apr 2014    Post subject: Reply with quote
Looks a hell of a lot like a delkavic can to me too.
gavcarter
PostPosted: 14:03 - 04 Apr 2014    Post subject: Reply with quote
https://images.dailystar-uk.co.uk/dynamic/1/photos/934000/620x/24934.jpg
bung a couple in Laughing
gavcarter
PostPosted: 14:07 - 04 Apr 2014    Post subject: Reply with quote
yes it would need to be angled or you will have to cut the tube down so the baffle fits in.
Alternatively get a big penny washer and tack weld to it to a short length of 6mm stud ( or bolt with head cut off) and wiggle it into the hole.
You can then angle it to get the sound to suit.
Snorty
PostPosted: 14:09 - 04 Apr 2014    Post subject: Reply with quote
My can is well over the legal limit but nobody has said anything in two years. I don't tend to go out past 11pm though. I am considerate where I will free-wheel it down the street when leaving and hit the kill switch and clutch it up the hill when I'm about 100yds away.
You can more or less bolt any baffle in. I managed to reduce mine from 105dB to 99dB with a random baffle I got off somebody.
Matt B
PostPosted: 17:11 - 04 Apr 2014    Post subject: Reply with quote
I though it looked like a Scorpion at first glance?
Grimeric
PostPosted: 18:44 - 04 Apr 2014    Post subject: Reply with quote
Thanks for all the help guys. I've managed to get hold of the previous owner. As far as he is aware it's a Beowulf can that has been cut down. They have done a good job on it as you cant tell. Is anyone aware if they sell replacement baffles? I can't see them listed on the website. I will call them tomorrow to see if they do, if not I've got my eye on a possible suitable baffle on eBay.
janner_10
PostPosted: 20:28 - 04 Apr 2014    Post subject: Reply with quote
Yes they do:
I was going to post it looked like a Beowulf I had - thats a nice cut job too.
https://www.beowulfuk.com/
Had to buy one for the Fazer for the MOT. I also got a link pipe for the CBR on its own - really helpful company - just send them an e-mail.
Grimeric
PostPosted: 20:32 - 04 Apr 2014    Post subject: Reply with quote
Thanks for the help everyone . I will give them a call in the morning and get one ordered if they are open. Failing that Monday.
FretGrinder
PostPosted: 13:15 - 05 Apr 2014    Post subject: Reply with quote
Just to throw another one into the mix, that appears to be an "Sp Engineeing" end can.
Doing a google search produced this -
https://www.spengineering.co.uk/uploads/product/original/stainlessovalbigboreexhaust03lg.jpg
Which looks suspiciously like the end can you have there.
Here is a link to the webpage so you can decide for yourself -
https://www.spengineering.co.uk/product-1-bandit-stainless-oval-big-bore-xls-exhaust.html
berzerker
PostPosted: 13:21 - 05 Apr 2014    Post subject: Reply with quote
Ring the bloke you bought it from and ask him what brand of can it is. He might even remember he has the baffle for it somewhere.
janner_10
PostPosted: 13:30 - 05 Apr 2014    Post subject: Reply with quote
If you look at his post he has rang the guy and its a Beowulf.
Grimeric
PostPosted: 13:36 - 05 Apr 2014    Post subject: Reply with quote
As above, it's a Beowulf can that's been shortened by an engineering firm. Beowulf are closed today so I've taken the plunge and ordered from a firm selling on eBay that have one they say will fit.
I will still ring Beowulf on Monday and see if I can blag another.
evilbond
PostPosted: 18:45 - 05 Apr 2014    Post subject: Reply with quote
I put one of these in mine recently as it was noisy as hell and didnt want to wake the street when using it for work early.
Baffle
https://www.ebay.co.uk/itm/270704566246?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Onto exhaust(looks similer to yours but longer.)
https://www.ebay.co.uk/itm/BANDIT-GSF-600-00-06-2000-2006-TITANIUM-OVAL-BIG-BORE-SL-ROAD-EXHAUST-/280721860763?pt=UK_Motorcycle_Parts_13&hash=item415c53a89b
Worked a treat, much quieter.
Bike: K2 Bandit 600S
Car: Astra GTC
The last post was made 12 years, 241 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.11 Sec - Server Load: 0.22 - MySQL Queries: 16 - Page Size: 115.42 Kb
