nsr carb on cg
mattyjohn93
PostPosted: 11:16 - 20 Apr 2014    Post subject: nsr carb on cg Reply with quote
Hi all, new to bikes although am an old hand (even at 20) to cars so mechanics are 2nd nature. Any way, I bought myself a little 125 project for £100. Non runner with no gears, sat for 5 years in a garage. She's all running and I just have a new sprocket set ordered to mot. Once it's mot'd am looking to fit a bigger carb as am let to believe the cg125 engine is naturally shit and not restricted lol.
Any way, the bike is chineese (cringe) vulcan custom 125 with a cg125 engine and 1500km (yes that low for a 54!!). Plan is to fit the nsr125 carb or something similar that will work. Only issue I can forsee is the nsr being 2 stroke
Any one fitted a larger carb to a cg or done any tweeks to up the omph?
Thanks all, Matthew
PostPosted: 11:33 - 20 Apr 2014    Post subject: Reply with quote
I think that it would make it a lot worse. The CG has small valves and won't pull enough air through the nsr carb for it to work.
mattyjohn93
PostPosted: 11:40 - 20 Apr 2014    Post subject: Reply with quote
Coul you recommend a carb? Failing that I may just buy a nsr as well lol
PostPosted: 11:56 - 20 Apr 2014    Post subject: Reply with quote
Not really. A CG isn't restricted from a design it's restricted by design. To make it produce more power you have to address several aspects of the design such as valve size, cam lift and timing, cylinder capacity and compression, combustion chamber shape, exhaust and carburettor design.
Or fit a turbo.
Bunny Lingus
PostPosted: 13:34 - 20 Apr 2014    Post subject: Reply with quote
Stick a XL 185 lump & carb in it or an early 15hp CB125s engine & carb. A 200cc Chinese engine will also fit. Use higher octane fuel (the expensive stuff) & iridium plug. Swap the front cog for a smaller one. Fit a small screen. Lose weight off it.
The bog standard 11hp CG lump is pushrod, which limits 'tuning' options. The OHC engines are better (quicker), but not as reliable. I wouldn't fit a bigger carb or change the air box 'cos you will prob lose power for the reasons already mentioned.
Bunny Lingus & The Flipside Faggots
mattyjohn93
PostPosted: 14:37 - 20 Apr 2014    Post subject: Reply with quote
Where would I be able to pick a decent engine? Ie online companies not just eBay specials. Plan to chop the bike any way so a new lump would go nicely with it. Prefer a 250 or something. Single piston though to pass as a 125 Wink
PostPosted: 14:38 - 20 Apr 2014    Post subject: Reply with quote
Errr, just stick with the 125 or pass your test?
Might as well go the full distance, GSXR600 and put your plate on there. Just as illegal Wink
mattyjohn93
PostPosted: 14:41 - 20 Apr 2014    Post subject: Reply with quote
Plan to do my test any way but still like the bike so want to build it up a wee bit then get a sportier toy for weekends and my car or van for work
mattyjohn93
PostPosted: 22:05 - 21 Apr 2014    Post subject: Reply with quote
Bump, any one upted power? Even simple cheap things
69chris
PostPosted: 22:10 - 21 Apr 2014    Post subject: Reply with quote
iv put a 26mm pit bike carb on the mrs chinky cg copy and it runs great, i doubt it has upped power at all but it needed a new carb and at 25 quid new it seemed the way forward
not much help an i Laughing Laughing
PostPosted: 22:18 - 21 Apr 2014    Post subject: Reply with quote
By far the simplest and cheapest option for 'where to pick a decent engine' would be in a better bike Wink.
Get a 125 2 stroke, which convienently will come with everything you need AND better suspension and so on, selling the CG.
You'll be quids in, have more than twice the power (if a 90s+ model) and pretty much everything else better (bar the economy).
Bunny Lingus
PostPosted: 15:24 - 22 Apr 2014    Post subject: Reply with quote
_Iain_ wrote:
Might have to attach one of these to a C90 for a giggle.
That rocks! I wanna attach one to mine! Got a link for that turbo Iain?
S'ok, I found 'em...
stevo as b4
PostPosted: 17:03 - 22 Apr 2014    Post subject: Reply with quote
More cc either a 150cc Chinq or otherwise big bore kit, or the 200cc OHV/OHC Honda motor used in other market bikes. The XL200R motor is an example of one motor that should fit using the same mounts, and it's 18bhp. XL185 motor if you ever found and then spent £££'s re-building one would work, but it's never going to happen as cheap XL's don't exist.
There's nothing worth doing to a 125cc CG that would make enough difference without more capacity.
Nitrous is a nice side step, but is never going to work, as you will on an 11bhp motor, want the gas on a lot of the time, and that's not what Nitrous was meant for.
CG125 forks and brakes are just about ok for 11bhp, but I wouldn't want even 2bhp more without firmer/bigger forks and some sort of front disc brake.
If I could only do one mod to a CG125 it would be to rape a very late damaged one for it's front end and disc brake set up.
stevo as b4
PostPosted: 17:04 - 22 Apr 2014    Post subject: Reply with quote
The last post was made 12 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.53 - MySQL Queries: 16 - Page Size: 89.34 Kb
