03 SV650s Wont crank
peligro28
PostPosted: 03:12 - 27 Apr 2014    Post subject: 03 SV650s Wont crank Reply with quote
Hello everyone!! I have a like new 03 SV650S. Ive had it for a year with no issues besides my own. Killed the battery a few times leaving the ignition on. Blonde moments....I know. I just ran into an issue though. I haven't ridden it in a month and went out to ride and it wont even crank. Lights, fuel pump, dash all light up. Maybe I have never noticed it before, but I noticed the red light near the N light was on, along with the oil indication light. I've checked the ignition fuse, corrosion on the pressure sensor, and oil level. All check good. Maybe I'm not getting good power from the battery to crank....thoughts???? Last time I rode everything was fine. No issues,
merquis00
PostPosted: 03:35 - 27 Apr 2014    Post subject: Re: 03 SV650s Wont crank Reply with quote
Few things to try:
1: charge the battery/or try a boost pack
2: check the kill switch
3: put it in in neutral and make sure the side stand is up/sensor is activating (if it has one)
The lights should go out when the bike is started if there is no problem.
(you have probably tried all of that^ but my knowledge only goes that far Sad )
Current: 2010 WR125X, Carrera crossfire-E.
Project's: '88 GL1500 Trike, Chinese 170cc Monkey
Previous: X9-500, XT125, DNA125, CBF125, YZF-R125, '98 K1200RS, '99 St1100, fantic245
peligro28
PostPosted: 03:59 - 27 Apr 2014    Post subject: Reply with quote
Ill try charging the battery. Haven't tried that, thanks. I figured since all the lights came on, horn is loud that the battery should be ok.
Blue_SV650S
PostPosted: 18:04 - 27 Apr 2014    Post subject: Reply with quote
Could be the clutch leaver safety switch playing up (I assume you are pulling the clutch in!)
Pigeon
PostPosted: 20:12 - 27 Apr 2014    Post subject: Reply with quote
I've got a cheap battery in my SV and it wasn't charging (due to a problem with reg/rec) correctly.
My cheap battery is only rated for 120CCA, so it didn't take much for it to go low enough for the starter to not work. Lights and horn yes, starter no.
If you are taking the seat(s) off to get at the battery to charge, it's worth checking a few things (based on my very limited recent experience).
Get a multimeter and once the battery is fully charged:
1. Check the voltage of the battery (engine off)
2. Check for current leak
3. Check charging output
I won't go into detail now. But can if it's of use later on. Basically the above takes 5mins, is really straightforward, and might avoid random dead battery moments Smile
Fair play, the bike wasn't used for a month, so it could be that simple. But if you've got access to the battery because you have to, might as well do the other too.
peligro28
PostPosted: 04:02 - 28 Apr 2014    Post subject: Reply with quote
Sounds like its a battery issue then. Ill have to buy a fluke meter then and a charger. Thanks!! Ill keep you all posted
cb1rocket
PostPosted: 16:31 - 28 Apr 2014    Post subject: Reply with quote
You really do not need a fluke meter to test charging system, a multi meter can be got for a fiver
The last post was made 12 years, 205 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.34 - MySQL Queries: 16 - Page Size: 54.09 Kb
