A question about life, the universe and everything.
c_dug
PostPosted: 15:39 - 28 Apr 2014    Post subject: A question about life, the universe and everything. Reply with quote
This is something I ponder occasionally, it might be a bunch of bollocks but I figure somebody more sciencey than me might be able to answer.
My impression of physics and chemistry is that if you know all of the parameters of something then you can work out with 100% accuracy the result. There is no element of random to it. So for instance two chemicals combined under exactly the same conditions will give the same result time after time after time.
Assuming I am not wrong with that, does that mean that everything that ever happened and will ever happen is a forgone conclusion?
So for instance if you had an impossibly smart computer and you input every single atom or particle of the big bang, and all of the parameters, you could map everything that happened after and everything that will happen?
Snorty
PostPosted: 15:58 - 28 Apr 2014    Post subject: Reply with quote
Ha, I once thought about this and came to the same conclusion as you.
https://en.wikipedia.org/wiki/Determinism
Have a read Thumbs Up
PostPosted: 16:27 - 28 Apr 2014    Post subject: Reply with quote
Dunno guv.
Read this?
https://upload.wikimedia.org/wikipedia/en/e/ed/Bill_bryson_a_short_history.jpg
syl
PostPosted: 16:36 - 28 Apr 2014    Post subject: Reply with quote
But you can never have all of the parameters. Measuring them causes them to change.
Current bike: Kawasaki Z750S
The Artist
PostPosted: 16:41 - 28 Apr 2014    Post subject: Reply with quote
This.
Also the theory that a "dimension" exists for every possible outcome of every decision ever made.
PostPosted: 16:50 - 28 Apr 2014    Post subject: Re: A question about life, the universe and everything. Reply with quote
No. Because when you get down to a quantum level, you can't know all of the parameters, you can only work on probabilities that a particle will be in a certain location. Scientists have pretty much proved that some particles can actually be in more than one location similtaneously.
Heavy shit. But essentially no, even with a hypothetically infinately powerful computer (which would have to be larger than the universe it is computing and since the universe encompasses infinity...) you can't predict with exactitude the behaviour (or potentially, the continuing existence) of a sub atomic particle.
CaNsA
PostPosted: 17:56 - 28 Apr 2014    Post subject: Reply with quote
Just watching can cause the parameters to change.
https://www.unmuseum.org/quantum1.htm
Ariel Badger
PostPosted: 20:47 - 28 Apr 2014    Post subject: Reply with quote
Quantum Physics is so weird that it makes God look a more viable explanation for the universe.
Lord Percy
PostPosted: 21:47 - 28 Apr 2014    Post subject: Reply with quote
Yeah you can't control 'everything' at the moment because of the uncertainty in measurement of the properties of subatomic particles (or are they waves? Wink ).
A brief explanation because I have an exam on this in a couple of weeks:
Heisenberg's uncertainty principle (which has been verified many times) states:
https://upload.wikimedia.org/math/0/a/1/0a1c02498125a255a2f5b0e58908a8ae.png
Where ħ is a fixed value called Planck's constant. Essentially it's just a big number with a letter assigned to it.
Δx ("Delta x") is the uncertainty in the measurement of an object's position. eg if you use a ruler to measure a bouncy ball, you'll have an uncertainty of Δx = 0.5mm because the ruler only goes in 1mm intervals, so you need to account for the fact that the measurement might be at some point in between.
Δp is the uncertainty in measurement of an object's momentum (or velocity, kind of).
So ΔxΔp is always greater than this fixed value ħ/2 .
ΔxΔp>ħ/2
This immediately limits the accuracy with which we can know anything about an object. To illustrate this, imagine you were able to measure the momentum of something with such accuracy that the uncertainty was absolutely tiny. Then imagine measuring it even more accurately, and more accurately, and more and more and more until it's so accurate that Δp is so vanishingly small that you could almost say Δp=0 . But for this to be the case, it would mean Δx is absolutely huge, or infinite! Because the product ΔxΔp must always amount to ħ/2 .
So, the more accurately you know about an object's momentum, the less you know about its position, and vice versa. This is why you can't ever make absolute predictions about subatomic particles.
However for large objects it's different because the uncertainty in measuring them is negligible compared to their actual sizes. eg when launching a spaceship the uncertainty in its launch position will be so tiny when compared with the scale of the whole thing, and so the uncertainty can be ignored. So for dealings with large objects - eg sending probes to deep space to orbit Saturn - we certainly do have the ability to plan, predict, control and foresee what will happen.
Big Bang stuff isn't possible though because of the uncertainty in position, momentum and energy of each 'thing'.
String theory's trying to fix it though.
Physicists like to think they can predict absolutely everything, so here's a joke about them: "It only works in the case of spherical cows in a vacuum."
Suntan Sid
PostPosted: 23:41 - 28 Apr 2014    Post subject: Reply with quote
42!
CaNsA
PostPosted: 23:50 - 28 Apr 2014    Post subject: Reply with quote
Suntan Sid wrote:
42!
Still waiting on the question though.
Llama-Farmer
PostPosted: 00:11 - 29 Apr 2014    Post subject: Reply with quote
Heisenberg's Uncertainty Principle and the Observer's Effect.
Not all parameters can be known or measured because if they are they are affected and thus render the principle invalid.
I do love all the paradoxes and thought experiments. I used to "waste" hours of physics lessons by drawing the physics teacher into discussions about quantum and theoretical physics amongst other things, that were more interesting that the stuff we were supposed to be learning.
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
dydey90
PostPosted: 09:28 - 29 Apr 2014    Post subject: Reply with quote
Physics and calculations aside, as soon as living creatures evolve, all predictability goes out of the window. How can you predict which blade of grass a rabbit will eat? Where it will take a dump and fertilise the soil?
c_dug
PostPosted: 09:58 - 29 Apr 2014    Post subject: Reply with quote
Because in the end an animal, be it a rabbit or a human is all just a bunch of elements interacting in a specific way?
GhostRider
PostPosted: 11:33 - 29 Apr 2014    Post subject: Reply with quote
Thats a bit misleading. "Watching" implies the particle is conscious of being observed, and thus change it's behavior accordingly. When what they really mean is "Measured" as in, using some form of analytic equipment to measure the particle interferes/interacts with it, and disrupts its behavior, effecting the experiment.
GhostRider
The Artist
PostPosted: 11:45 - 29 Apr 2014    Post subject: Reply with quote
GhostRider
The word watching also implies this.
GhostRider
PostPosted: 11:59 - 29 Apr 2014    Post subject: Reply with quote
I don't believe I have ever heard/read the term "watching" used for the measurement of anything in a scientific setting, be that in the lab itself or in any science papers/journals.
You might say "we determined the concentration of the protein via measurement of optical density at 280nm with the relevant extinction coefficient".
You wouldn't say "we watched the protein to determine its concentration". Hell you wouldn't even say "we watched the A280nm measurement" Unless you wanted to be regarded as a retarded cunt of course.
The trouble is semantics is important in this instance, since so many people get it very wrong and start drawing all sorts of bizarre conclusions about the nature of the universe and how it works as they believe that watching things, as in looking at them directly, alters their behaviour as a direct result of them having been looked at (thus being aware of their observation).
GhostRider
The Artist
PostPosted: 12:20 - 29 Apr 2014    Post subject: Reply with quote
Fair enough but explaining fairly complex experiments to non scientists, I think most people will get the whole watching = measuring thing.
c_dug
PostPosted: 12:29 - 29 Apr 2014    Post subject: Reply with quote
As a non scientist I prefer the way GR explained it, to me watching involves no interaction so if watching something makes it do something else it creates far more questions than it answers.
None of this really explains much though, there must be a rule of some kind that particles follow, even if we don't know it yet, so for instance if you measure a particle in a particular way it reacts in a predictable manner?
GhostRider
PostPosted: 12:30 - 29 Apr 2014    Post subject: Reply with quote
Ohhhh if only. Go read the youtube comments.
Take this video for example - they use an eyeball as the "measuring device". And then go on to say at 4:25 "as if it was aware it was being watched".
https://www.youtube.com/watch?v=DfPeprQ7oGc
Naturally you can;t blame people for thinking that way, when that's exactly how its being expressed, but because this is a more mysterious and esoteric spin on the phenomenon, you can guarantee that it'll be the version told the most.
GhostRider
GhostRider
PostPosted: 12:38 - 29 Apr 2014    Post subject: Reply with quote
Wave-particle duality, apparently.
https://en.wikipedia.org/wiki/Wave%E2%80%93particle_duality
Not that I can understand a fackin word of that mind.
GhostRider
DrSnoosnoo
PostPosted: 12:42 - 29 Apr 2014    Post subject: Reply with quote
It's just one of those things, we can't know everything at the same time but as our understanding develops our predictive models can evolve to become more predictive.
I've done a design of experiments which was once used to predict the ability to remove grease from textiles. I had 6 variables, 3 concentrations each and carried each experiment out. The model which was developed still wasn't very accurate when I tested some optimised systems.
PostPosted: 13:10 - 29 Apr 2014    Post subject: Reply with quote
Leave aside Heisenberg and pretend that you could know position and velocity at the same time. You'd need to do that to make a Star Trek transporter, which as we know are factual, because we saw them in the Documentary Series.
But...
...to predict the behaviour of that "bunch of elements" you have to model it and run that model.
To model it, you'd have to know its entire state and you'd have to take a snapshot of all of that at a specific instant of time. Let's pretend you could do that.
However, to know what it will do in the future, you have to snapshot the whole system which which it can interact. In other words, you'd have to make a model not just of your bunny in a field, but of the entire observable universe.
But since your Predicatron is in the real universe and can interact with your subject, you'll have to make a model of your Predicatron inside your model in the Predictatron.
How far down the infinite recursive turtles go in that scenario is left to the imagination of the reader.
PostPosted: 14:18 - 29 Apr 2014    Post subject: Reply with quote
GhostRider
No. I meant "watched".
It's my understanding that a photon can exist in more than one place at once until you observe it which collapses the waveform and it decides to be a particle in one place. In a very real way, it WAS in both locations and in a very real way it is now in one location.
My understanding it not very complete though.
Back to the OPs interocitor theory.
You also get non-Netwonian states of matter which confuse the hell out of everything. I struggle to get my head round a plasma but that's nothing. It looks like a Bose-Einstein condensate in one place can respond to what is happening to a different one in a seperate location (so poke one pot with a stick, you get a ripple in the other one). They are predictably unpredictable but their nature means you are dealing with greater or lesser degrees of uncertainty rather than absolutes.
Llama-Farmer
PostPosted: 15:05 - 29 Apr 2014    Post subject: Reply with quote
stinkwheel wrote:
GhostRider
Somewhere to the middle-left of a Simple-Complicated spectrum, that is correct.
How To Teach Quantum Physics To Your Dog by Chaz Orzel is a brilliant book, makes some incredibly complex principles rather understandable... an interesting read that isn't particularly hard work on the head.
The last post was made 12 years, 203 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.75 - MySQL Queries: 16 - Page Size: 146.55 Kb
