3 bikes into what van?
Slacker24seve...
PostPosted: 12:31 - 01 May 2014    Post subject: 3 bikes into what van? Reply with quote
Hi folks,
Quick question. What's the smallest/cheapest to rent van I can fit a CBR600, Daytona 675 and a Gixxer thou into? I'm guessing a SWB transit would be too small... I know my mates Fiat Scudo will definitely only take 2 road bikes.
Banger rallies are ace
stevo as b4
PostPosted: 12:36 - 01 May 2014    Post subject: Reply with quote
Not much help to you, but when I picked up my KMX, I asked for a SWB transit, and got a LWB Sprinter as that's all they had left. I think even 3bikes would feel lost in there, but if your hiring a van and get it at the same price as a smaller van then who cares! Laughing
Scotsman37
PostPosted: 12:40 - 01 May 2014    Post subject: Reply with quote
Simple take the width of the bikes And add some room to be able to manoeuvre between them to tie them down, and make sure there is tie down points along the insides of the van because when you go around a corner that's where the fun begins also when braking hard or pulling away fast, if not secured down properly with a ratchet type version, as they will eventually slide around in the back disturbing the balance of the van.
It will help if you tie wrap the brake levers back to prevent the possibility the bike rolling backwards/forwards to prevent undue strain on the tie downs too. Also, put a wedge or something to stop them sliding on the smooth wooden surface interior of the van.
PostPosted: 12:58 - 01 May 2014    Post subject: Re: 3 bikes into what van? Reply with quote
Into a SWB (lotop) Transit I've got a race SV650 (full fairings), GSXR750K1 and Triumph 675. A bit of a squeeze. It only had single rear wheels, double would have made it worse.
Had a load of other stuff in there too, so it was pretty packed.
Slacker24seve...
PostPosted: 13:23 - 01 May 2014    Post subject: Reply with quote
Thanks. We can dismantle them further if required, might be a case of putting the CBR and Gixxer in normally against the sides and wedging the trumpet in backwards between them.
PostPosted: 13:25 - 01 May 2014    Post subject: Reply with quote
I think one was backwards in the above scenario.
PostPosted: 13:27 - 01 May 2014    Post subject: Reply with quote
[Hopefully not stating the obvious!] Smallest doesn't mean cheapest, at least not with the vans and cars I've rented.
PostPosted: 16:36 - 01 May 2014    Post subject: Reply with quote
I was about to suggest you'd probably JUST get them in a SWB transit if you don't mind them leaning on one another a bit.
Those VW transporter ones are pretty huge. Or a sprinter because you can definately get two in a vito.
map
Mr Calendar
PostPosted: 16:43 - 01 May 2014    Post subject: Reply with quote
Just make sure you have a good ramp and your driver doesn't floor it before you get inside with your booty...
..as in this example Wink Very Happy
Slacker24seve...
PostPosted: 16:58 - 01 May 2014    Post subject: Reply with quote
Actually, I've had a Transporter before and thought it was a bit smaller inside than a Transit. Bloody nice to drive though, just like a big Golf.
I think we'll just go SWB Transit (or anything similarly priced and sized) and if we absolutely can't get my Daytona in the back we'll take turns riding it as it's the only road legal (ish) one. It's only Worcester to Anglesey anyway!!
PostPosted: 17:02 - 01 May 2014    Post subject: Reply with quote
Transporter is the same size as a vito - can comfortably get two bikes in. I've had 3 thinner bikes in ok.
VW's sprinter-sized van is the LT35 etc (large transporter, I believe). Could get 3 bikes in this across ok.
After these, a luton/box width will make it a good bit easier.
STONEY!
PostPosted: 17:06 - 01 May 2014    Post subject: Reply with quote
Citreon relay, Peugeot boxer, fiat ducato. All basically the same, I got 5 yes 5 complete bikes in my mwb semi high. 3 zx6r's an sr125 and a cg125.
They are made of ticky tacky shite but my 2.5 diesel cost £400 did 35mpg and 60,000 miles with nothing more than basic servicing and a wheel bearing. Just check gearbox for crunches and sills, rear cross member and front arches for rust.
I have used sprinters, transporters and transits and non beat the frenchies for practicality and economy.
PostPosted: 17:27 - 01 May 2014    Post subject: Reply with quote
My old Vauxhaull midi was like the bloody tardis.
Absolutely horrible to drive though.
The last post was made 12 years, 140 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.96 - MySQL Queries: 16 - Page Size: 80.93 Kb
