Oil Sump Ball Valve
smegballs
PostPosted: 15:05 - 05 May 2014    Post subject: Oil Sump Ball Valve Reply with quote
Just stumbled upon these....
https://www.quickvalve.co.uk/f111n.jpg
https://www.youtube.com/watch?v=LDun0fTcT4w
Apparently they have been extensively tested not to seize up or otherwise fail. I like the idea of being able to attach a hose and drain straight into say a 2L coke bottle, nice and discreet.
Also for people who plan on doing 1/2k oil change it saves wear on the sump threads themselves. 20 quid for one of these is pretty cheap compared to the cost of helicoiling or otherwise unfucking stripped sump threads.
PostPosted: 15:13 - 05 May 2014    Post subject: Reply with quote
Or do what all modern garages do and buy a vacuum pump and suck the oil out of the sump via the filler or dipstick hole?
smegballs
PostPosted: 15:30 - 05 May 2014    Post subject: Reply with quote
I was thinking mainly for touring purposes, it makes dropping the oil quick and easy to do by the roadside. Of course I could just take a big syringe and length of tubing but not quick as slick.
DrSnoosnoo
PostPosted: 16:22 - 05 May 2014    Post subject: Reply with quote
I'd be interested. How large are these though? And do they just work like a tap?
MaybeGuy
PostPosted: 16:29 - 05 May 2014    Post subject: Reply with quote
lolwut? Try that on any jap il4
The Artist
PostPosted: 16:31 - 05 May 2014    Post subject: Reply with quote
That seems like a good way to not remove all the oil and a lot of engines, not easy to get to the base of the sump at all.
Bubblin77
PostPosted: 16:48 - 05 May 2014    Post subject: Reply with quote
Seems like a good way to open these on peoples bikes when parked up, looks like a key could open it quite easy.
Kawasaki Z800 (SOLD)
smegballs
PostPosted: 16:51 - 05 May 2014    Post subject: Reply with quote
https://www.youtube.com/watch?v=yMMxh02zNFk
Here's a much better vid of it in use.
Seems to have a pretty positive lock, and you can get a specific clip for extra safety for off road vehicles.
smegballs
PostPosted: 16:53 - 05 May 2014    Post subject: Reply with quote
If you are that sort of knob, an adjustable spanner is easy to carry around.
Obviously it is possible for vandals to rinse with, but how many scummers go around checking bikes drain plugs, just on the off-chance than one will have one of these valves fitted? If you are out to cause havoc, you'd take a spanner surely?
daemonoid
PostPosted: 16:56 - 05 May 2014    Post subject: Reply with quote
Still... it's the way it's done. In fact I was speaking to someone with a new car a few weeks ago (can't remember which one as I didn't see it) and it didn't even have a sump plug... Syringe only!
current: ducati monster 750
PostPosted: 17:05 - 05 May 2014    Post subject: Reply with quote
Fair play to them, that is an interesting idea.
lukamon
PostPosted: 17:08 - 05 May 2014    Post subject: Reply with quote
smart IIRC; also, 5 sided bolts for brake callipers Neutral
killa wrote: Im an ass man myself
PostPosted: 17:20 - 05 May 2014    Post subject: Reply with quote
It's what they do apparently. They don't like helicoiling sumps apparently. I'd guess that if it was done properly you're actually less likely to leave old oil and swarf lying around in the sump to be honest.
Al
PostPosted: 17:33 - 05 May 2014    Post subject: Reply with quote
I think i'll stick to changing my own oil the old fashioned way! I've never had a bike thats had a direct route down into the sump via the dipstick or filler cap and surely if you can't suck from the base of the sump all the crap you're trying to get rid of would still be sitting in the bottom of the sump Confused
Yamaha FZR400RR 3tj
My Instagram Thingy
The Artist
PostPosted: 17:44 - 05 May 2014    Post subject: Reply with quote
I don't see how that would be possible tbh.
If a new car has a specially designed sump with a route for a nozzle to go to the lowest point then maybe they are just cost saving.
evoboy
PostPosted: 18:45 - 05 May 2014    Post subject: Reply with quote
There are some cars that have no sump plug. ( Smart 3 cyl dont off the top of my head )
I have never used one of those syringes to pump oil from the sump of a bike. I dont like the idea as all the debris that the filter doesnt catch will sit in the sump in the small amount of old oil left in there.
If the sump plug strips the threads upon taking it apart, then they were damaged by the last person to do it up too tight.
I like the idea of the ball valve.....but I dont see the need for it.
APT Motorcycles
PostPosted: 18:47 - 05 May 2014    Post subject: Reply with quote
I'm not arguing with you, I'm telling you what most car garages do these days.
smegballs
PostPosted: 18:50 - 05 May 2014    Post subject: Reply with quote
I know scientifically they alloy threads shouldn't be weakened as long as they are never taken above their yield point, but it still feels like the thread will suffer some kind of failing if it cycled often. That said even if you changed the oil every 1000 miles, but 40k that is only 40 loading cycles, which I guess isn't that much by any stretch really.
Northern Monkey
PostPosted: 20:00 - 05 May 2014    Post subject: Reply with quote
It's probably also incorrect to think that the garage gives a toss about how much oil or swarf is left at the bottom, rather than doing it the quickest and easiest way.
sidewinder
PostPosted: 20:37 - 05 May 2014    Post subject: Reply with quote
Looks like it would easily knock of as well
1cyl
PostPosted: 22:05 - 05 May 2014    Post subject: Reply with quote
Interesting idea but it can't trump my magnetic bolt, which comes out with a nice little pile of filings attached. Plus i think using the full aperture of the drain hole maximises flow rate which in turn is faster and aiding the removal of swarf (like swilling a bucket).
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
janner_10
PostPosted: 23:32 - 05 May 2014    Post subject: Reply with quote
Never had an issue with using a 17mm spanner yet.
TUG
PostPosted: 00:55 - 06 May 2014    Post subject: Reply with quote
Huh? Can you show us this method? As it seems like a bit retarded given gravity and a bolt takes like a minute tops. Laughing
Haz ER-5, innit!
iooi
PostPosted: 09:38 - 06 May 2014    Post subject: Reply with quote
Google is your friend....
U-Tube
Until they come across a car that has had the sump borked in the past and they end up footing the bill to fix something that was not their fault.
How many of us have realised that the sump plug is not as it should be and taken it to a garage for a oil change...... Razz
hmmmnz
PostPosted: 10:15 - 06 May 2014    Post subject: Reply with quote
being as the sump is the lowest point on any engine,
smashing the fucker off is going to pretty high,
ive smashed a sump on Edinburghs cobbled streets, and i didnt even have a little thing on it to make it easier to do so,
thats up there with the best of them for things added to a bike that would end in regret
the humans are dead
I kick arse for the lord
The last post was made 12 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.78 - MySQL Queries: 16 - Page Size: 138.33 Kb
