help- problems starting my bike
Gaz92
PostPosted: 13:05 - 01 Jun 2014    Post subject: help- problems starting my bike Reply with quote
okay so my bike (yamaha sr125 ) has been sat for 6 months. i got it back out and it wouldnt start. so i put new oil and fuel in it, which got it starting, but wouldnt tick over if i wasnt reving it .
so i posted on here for help and some guy told me to rev it full for 2mins and then rev it half for 2mins.
as i was reving it full for 2 mins the bike cut out with a load bang, and since then i cant get it started at all
ive put a new spark plug on the bike, cleaned the air filter, cleaned the carb and still not making any appemt to start.
if i try jumping start it, then you can hear the motor starting to tick over and it backfires, but no power at all
any suggestions, or shall i just take it to a garage
CaNsA
PostPosted: 13:07 - 01 Jun 2014    Post subject: Reply with quote
Cleaned the spark plug?
Fresh battery?
Gaz92
PostPosted: 14:05 - 01 Jun 2014    Post subject: Reply with quote
New spark plug and I charged the battery
bladerunner
PostPosted: 14:23 - 01 Jun 2014    Post subject: Reply with quote
Erm......when you say rev it full for 2 minutes......just what exactly did you do?
Gaz92
PostPosted: 14:27 - 01 Jun 2014    Post subject: Reply with quote
Umm started the bike . Reved it a little, then full throttled for almost 2 mins. Then made a load bang and cut out
SQL
PostPosted: 14:29 - 01 Jun 2014    Post subject: Reply with quote
https://img3.wikia.nocookie.net/__cb20121205194057/simpsons/images/e/e9/Nelson_Ha-Ha.jpg
I'd be doing a compression test
TheSmiler
PostPosted: 14:33 - 01 Jun 2014    Post subject: Reply with quote
Yeah that happened to me when I was a full on novice, personally I'd take your rocker cover off right now. Then check what it's like.
https://i.imgur.com/RW4zo2nl.jpg
Ok it might not be this but if it was being revved at full for 2 minutes it most probably is.
Gaz92
PostPosted: 14:37 - 01 Jun 2014    Post subject: Reply with quote
Lol some tool on here told me to full rev it. Is that what it's meant to look like in the picture
Gaz92
PostPosted: 14:40 - 01 Jun 2014    Post subject: Reply with quote
Don't I need to be able to start the bike to be enable to do a compression test
TheSmiler
PostPosted: 14:44 - 01 Jun 2014    Post subject: Reply with quote
I really hope you are a troll via that comment; however I will abide and answer. No it is not meant to have a large crack in it.
Gaz92
PostPosted: 14:46 - 01 Jun 2014    Post subject: Reply with quote
Lol didn't look that close at the picture. So if mines fucked it will have a crack in it ? Sorry this is my first bike and don't really know much
SQL
PostPosted: 15:12 - 01 Jun 2014    Post subject: Reply with quote
Nope put compression tested in the sparkplug hole and try to start it until the needle stops
bladerunner
PostPosted: 15:16 - 01 Jun 2014    Post subject: Reply with quote
Oh be jeezus I hope this is a wind up! Or I'd be tempted to hit whoever gave you that advice in the head with a base ball bat repeatedly for 2 minutes,then beat yourself in the head with it for the next 2 at half strength for actually doing it!
Failing that...give the bike to someone who knows what they are doing to fix!
caferacer
PostPosted: 15:42 - 01 Jun 2014    Post subject: Reply with quote
Just how loud was the bang?
They can misfire when they cant draw enough fuel into the engine...
If you're lucky it could still be a fuelling problem.
Revving it high is very different to on the limiter for 2 minutes...
caferacer
PostPosted: 15:45 - 01 Jun 2014    Post subject: Reply with quote
Also, a good reminder that you can't trust every word of advice on forums...
Gaz92
PostPosted: 16:37 - 01 Jun 2014    Post subject: Reply with quote
It was really load bang.
Now when I try to push start it, you can hear the engine almost starting and a few little bangs ( more like pops)
edb
PostPosted: 16:48 - 01 Jun 2014    Post subject: Reply with quote
Would it be the advice CaNsA gave you that you've misunderstood?
Gaz92
PostPosted: 17:22 - 01 Jun 2014    Post subject: Reply with quote
No. I posted a thread like a month ago when my bike was working but wouldn't tick over
iooi
PostPosted: 17:38 - 01 Jun 2014    Post subject: Reply with quote
And just how do you plan to do a compression test with the spark plug in the hole.... Shocked Embarassed Rolling Eyes
lihp
PostPosted: 18:16 - 01 Jun 2014    Post subject: Reply with quote
Yes we have that thread, nobody told you to hold it at high revs for 2 minutes.
Gaz92
PostPosted: 18:47 - 01 Jun 2014    Post subject: Reply with quote
Ooo my bad I did miss read that at the time. Sorry my bad.
Well anyway I did full throttle for 2 mins instead of full Choke lol
caferacer
PostPosted: 18:51 - 01 Jun 2014    Post subject: Reply with quote
Guys, give the chap a break.
What's happened has happened, let's help him fix it.
lihp
PostPosted: 18:53 - 01 Jun 2014    Post subject: Reply with quote
Did it sound like a mechanical bang, a noise of stuff hitting each other.
Or did it sound more like an explosion bang?
Gaz92
PostPosted: 19:16 - 01 Jun 2014    Post subject: Reply with quote
Explosion bang
gavcarter
PostPosted: 19:38 - 01 Jun 2014    Post subject: Reply with quote
grab a cheap compression tester, take spark plug out and put compression tester in. FULL THROTTLE - NO CHOKE and try and start bike for about 5 seconds.
The compression tester will now have a reading, which you should be hoping is good Thumbs Up
The last post was made 11 years, 218 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.25 - MySQL Queries: 16 - Page Size: 127.19 Kb
