BBQist's Lighting a Charcoal BBQ help.
Bike Chat Forums Index -> Dear Auntie BCF... Goto page 1, 2, 3  Next
PostPosted: 16:41 - 03 Jun 2014    Post subject: BBQist's Lighting a Charcoal BBQ help. Reply with quote
Hi all,
I love BBQing and have always taken great pride in doing it properly with homemade sauces and Marinades etc. However I've always used gas. I know many don't think this is proper, I say try my Ribs and tell me otherwise. Laughing
Anyway, my missus had been on about getting a BBQ and not wanting to spend the earth we decided to get her a cheap charcoal one. I figure it'll give me a go at trying to cook without gas.
We fired it up on Sunday and it was a complete disaster, the fucking thing just wouldn't take. I assumed I knew how to start one, however it wouldn't work.
This is what I did.
4 firelighters spaced in one half of a grill dumped a load of charcoal on it. I then lit the firelighters and left it to burn with the lid off. Had a look 10 minutes later and nothing. The firelighter where mostly burnt but not a white coal or red glow in sight. I then added more and more firelighters then tried wafting it. I used the whole pack of firelighters and managed to get about 30% of the coal white but with no real heat coming off it.
I've watched a few videos on youtube and most just did what I did and there's was ablaze. I can't see what was wrong with my technique I think maybe there was a problem with the kit.
I notice most of the grills I see have another grill for the coals to sit on, on the one we have it has a tray with no holes for air to get in underneath. I was wondering if it was a fundamental design flaw?
Other than that is there a way the charcoal or firelighter could have been duff? None of it wasn't wet or anything all straight out of the packet.
Any other tips?
I did exactly this.
https://www.youtube.com/watch?v=cW9YIuL99Wg
But didn't get anywhere near as many flames. I was considering drilling holes in the tray, what do you think?
DRZ4Hunned
PostPosted: 16:47 - 03 Jun 2014    Post subject: Reply with quote
When mine wouldn't go I used some rolled up newspaper, I seem to be a natural arsonist though.
PostPosted: 16:54 - 03 Jun 2014    Post subject: Reply with quote
Get a chimney starter and never worry again.
swampy
PostPosted: 16:57 - 03 Jun 2014    Post subject: Reply with quote
I use lumpwood charcoal not briquettes. I break them up into pieces about the size of a golf ball give or take.
I then take a double newspaper page twist it long ways and then tie it in an overhand knot. Make three or four of these.
Make a pile of charcoal with these paper ball type things scattered throughout.
Pour some lighter fluid on rather than use fire lighters - it gets into the cracks between the coals, make sure the paper balls have a reasonable glug of this on each.
Light and leave for 10 mins.
Bung a sausage on over the blaze. This is a sacrifice to the BBQ gods and the fat will cause the coals to light further.
Leave until coals have gone white.
Cook over these embers/coals.
PostPosted: 16:58 - 03 Jun 2014    Post subject: Reply with quote
Easy way? Get the bags of self-lighting charcoal. Light the bag, walk away for 20 minutes.
Not all charcoal is the same. I always start with lumpwood then add odd briquettes once it's going.
Through draught may well be an issue but good quality lumpwood charcoal will light and burn properly in the stainless roasting tray I use as a travel BBQ and it has no ventilation at all in the bottom.
Don't put in too much at once
Ballpien
Might as well cook your ribs in the oven ffs...bbq my arse
Drain petrol from tank = much fire = proper bbq ribs
PostPosted: 17:01 - 03 Jun 2014    Post subject: Reply with quote
Once is going am I right in thinking I can add more charcoal and if should just 'catch' and burn?
swampy
PostPosted: 17:05 - 03 Jun 2014    Post subject: Reply with quote
There's a bot of lead time.. It take a while to get going, so you need to think ahead...
PostPosted: 17:12 - 03 Jun 2014    Post subject: Reply with quote
Chemically tasting shit you mean. Rolling Eyes
Poseidon
PostPosted: 17:19 - 03 Jun 2014    Post subject: Reply with quote
The whole lot of you are bothering me.
Buy some british woodland charcoal (from coppiced woodland). It's not as dense as the african wood the imported stuff is made of, consequently, it lights so much easier. No need for lighter blocks/petrol/lighter fluid, just a couple of scrunched up sheets of newspaper, a match and you're away. One time I couldn't find any suitable paper, so I took the blowtorch to the coals... About 10 seconds on each of a half dozen bits of charcoal was enough to have it blazing away within 5-10min. It gets up to heat quicker too, so it's ready to cook on sooner. It does burn a little hotter than the shitty supermarket/petrol station stuff, which takes a little getting used to. However, to my palate at least, the food tastes more smokey and less burnt when using the british woodland stuff... There's no acrid taste that I found when I was using the cheap stuff.
1977 Honda CG125
ScaredyCat
PostPosted: 17:37 - 03 Jun 2014    Post subject: Reply with quote
Use one of these
https://dl.dropboxusercontent.com/u/188253/_bcf/chim.jpg
It goes like this...
https://dl.dropboxusercontent.com/u/188253/_bcf/chim2.jpg
Use that as your bbq starter...
They cost a tenner..
https://www.diy.com/nav/garden/outdoor-living/barbecues-outdoor-heating/fuel/fire_lighting/Chimney-Starter-12718590?noCookies=false
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
PostPosted: 18:05 - 03 Jun 2014    Post subject: Reply with quote
https://www.tooled-up.com/Artwork/ProdZoom/GAZ204629.jpg
I'm super serial.
ScaredyCat
PostPosted: 18:07 - 03 Jun 2014    Post subject: Reply with quote
Rogerborg wrote:
I'm a serial killer.
FTFY... Thumbs Up
Bloggsy
PostPosted: 18:14 - 03 Jun 2014    Post subject: Reply with quote
Marinade the charcoal in petrol then fire it up,but stand well back
Ballpien
PostPosted: 18:16 - 03 Jun 2014    Post subject: Reply with quote
No Rolling Eyes
Llama-Farmer
self-lighting bags... you don't need to worry about how much to use then... just one bag, unless it's a really big bbq then use 2.
Current Bike: 1999 Honda CB600 FX Hornet
Next Bike: I want a CBR-RR. And I want an F800 GS-A. And a VFR 800. Can I have all 3?
Dream Bikes: Honda VFR750R RC30, Honda NSR500, Ducati 996 R
trevor saxe-coburg-gotha
PostPosted: 18:20 - 03 Jun 2014    Post subject: Reply with quote
Get a fire going with kindling, then half inch twigs, then one inch diameter pieces of wood/branch (let's say 20 or 30 pieces). Once that's going, start introducing any kind of charcoal you like - not too much at first, then just about 15-25 pieces depending on how many people you're cooking for. This should do 3-4 adults.
It will take about 15-20 minutes to get to the point where you can actually cook without singing the meat. Perhaps even more than that. So yeah, it's laborious - but that's what I always do.
PostPosted: 19:07 - 03 Jun 2014    Post subject: Reply with quote
When glamping, we use a Cobb. Good bit of kit, pretty shit advert.
https://www.youtube.com/watch?v=MlbLYkqsIIM
daverave999
PostPosted: 23:09 - 03 Jun 2014    Post subject: Reply with quote
Got a heat gun, like you use for stripping paint? That.
2007 Versys 650 2001 Yamaha XJ600S Diversion
HT: Imagine a bike......A bike designed by way of crude polls, assembled by cretins using the finest hammers that Lidl had on offer.
Suntan Sid
PostPosted: 23:16 - 03 Jun 2014    Post subject: Reply with quote
Use the chimney, as suggested!
If you want to make your food taste like it has actually been BBQ'd you'll need to add some proper hardwood lumps in with the charcoal.
Charcoal on its own doesn't give you a smoky flavour, (if that's what you're after)!
gavcarter
PostPosted: 23:45 - 03 Jun 2014    Post subject: Reply with quote
crappy self light disposable thingy in foil tray - wait till lots of flames - pour charcoal over top - always worked for me.....
PostPosted: 23:53 - 03 Jun 2014    Post subject: Reply with quote
Used a chimney + a couple of sheets of newspaper, job done. Cool Went up nice and easy no chemicals. Thumbs Up
Chinaboy
PostPosted: 01:30 - 04 Jun 2014    Post subject: Reply with quote
I asked my brother-in-law to start the bbq at our place a few weeks ago when I was home. I left him to it until I get a whiff of this awful smell. It was like strong burning rubber.
I go to see where it is coming from and the dozy twat has found an old slipper (flip-flop) cut it into strips and is burning these under the charcoal. He is a total pillock with the brain the size of a pea.
I put out the rubber and threw away the charcoal and started again with some paper and sticks.
CaNsA
PostPosted: 01:34 - 04 Jun 2014    Post subject: Reply with quote
Use propane.
https://www.youtube.com/watch?v=oiqO5yeNmz0
Twas a good weekend.
PostPosted: 10:57 - 04 Jun 2014    Post subject: Reply with quote
Poseidon wrote:
The fucking lot of you are bothering me.
Buy some british woodland charcoal (from coppiced woodland). It's not as dense as the shitty african wood the imported stuff is made of, consequently, it lights so much easier. No need for lighter blocks/petrol/lighter fluid, just a couple of scrunched up sheets of newspaper, a match and you're away. One time I couldn't find any suitable paper, so I took the blowtorch to the coals... About 10 seconds on each of a half dozen bits of charcoal was enough to have it blazing away within 5-10min. It gets up to heat quicker too, so it's ready to cook on sooner. It does burn a little hotter than the shitty supermarket/petrol station stuff, which takes a little getting used to. However, to my palate at least, the food tastes more smokey and less burnt when using the british woodland stuff... There's no acrid taste that I found when I was using the cheap stuff.
This is very true. You get what you pay for.
That's why I used handmade Cumbrian charcoal for my bronze casting the other weekend. Lights easily, ready to cook on in minutes. You only need a thin scatter to cook a few sausages/kebabs. It's probably quicker than doing them in the oven.
The last post was made 12 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.18 - MySQL Queries: 16 - Page Size: 137.42 Kb
