Bandit 600 running badly...
mullen1981
PostPosted: 16:18 - 15 Jun 2014    Post subject: Bandit 600 running badly... Reply with quote
Hi, just bought a '99 bandit 600, took it for a test ride and all was fine, was told it had been standing for a year previous so got it home and it seemed to be low on electrical power on start up so bought a new battery, and that solved the power issue. Now it's sluggish on start up as in takes a few goes to start it (it attempts to turn over ok) and now when I take it for a run it goes a bit then cuts out and dies when I open the throttle. I tweeked with the idle valve and it makes the bike Rev a lot and tick over better but still cuts out when I take it out when I open the throttle? When I opened the mixture plugs petrol started coming out along with a little brown liquid then all petrol so I dunno if I was doing it right?
I've took out the spark plugs and they are all wet and black so I'm guessing it's running rich...
I'm new to bikes so I've literally only been going off the websites about this but I'm not confident enough to take off the carbs to clean them.
Anyone know the easiest way to sort
This out? Ive booked it into a garage next week but if I could
FIx it myself I would save £150
I know this question will make me sound like a total noobie so any advise would Be great thanks
CaNsA
PostPosted: 16:21 - 15 Jun 2014    Post subject: Re: Bandit 600 running badly... Reply with quote
Who or where did you buy it from?
mullen1981
PostPosted: 16:23 - 15 Jun 2014    Post subject: Reply with quote
I bought it locally private
Formerly known as
P.
PostPosted: 16:34 - 15 Jun 2014    Post subject: Reply with quote
Where abouts are you based?
Does sound like carbs really, if you are local enough ill happily come over and provide tools and guidance.
mullen1981
PostPosted: 16:43 - 15 Jun 2014    Post subject: Reply with quote
I'm in Sunderland? I would much prefer something with a hand from someone off here instead of taking it to the garage and paying
Formerly known as
P.
PostPosted: 18:53 - 15 Jun 2014    Post subject: Reply with quote
A little far from me buddy, shame!
I'm sure someone on here would be happy to assist but I can assure you, it really is as simple as removing the bank of carbs, undoing each bowl one at a time and cleaning them, removing the jets etc.
I would recommend removing the cables from the throttle rather than the carbs as they can be a pain to get back in.
If you are scared to strip and clean, you could post them and I'll do them for you. It really is quite simple Thumbs Up In reality, it won't be far different from this - https://www.youtube.com/watch?v=IdCL9DoBTo0
You'll notice minor differences but the main thing is cleaning the jets and bowls properly. Any dirt is likely to affect it.
Air filter is definitely worth a look at, however I've never liked the space constraints on the Bandit Laughing
mullen1981
PostPosted: 19:00 - 15 Jun 2014    Post subject: Reply with quote
I think I'll bite the bullet and take it to the garage, I managed to tinker with it earlier and took the air box and tank off but knowing my luck I'll break something and have to call the garage to fix my mess up ha
The spark plugs are something I could do myself but I've read up on them and it says the bike is running rich so I'm wondering if I change the spark plugs how do I stop the new ones going the same way? Ie black and covered in petrol?
mullen1981
PostPosted: 19:03 - 15 Jun 2014    Post subject: Reply with quote
Vincent wrote:
Don't make the mistake I've seen over a million times and rush it Wink
What's the air filter like?
Genuine(?) mileage?
General condition?
The general condition is not that bad, it's been standing for a year cos the tax ran out last August, so I mot'd it and taxed it with no problems and it ran ok at first in the sense it would ride a little but as soon as I opened the throttle it cut out. I knew the carbs would need a clean after reading other posts online but when I seen then plugs last night that could of been another reason.
Formerly known as
P.
PostPosted: 19:16 - 15 Jun 2014    Post subject: Reply with quote
I would definitely give it a go. You'll feel more satisfied Thumbs Up
mudcow007
PostPosted: 07:45 - 16 Jun 2014    Post subject: Reply with quote
my first "proper" bike was my Bandit, taking the carbs off is straight forward
Take seat off
take tank off (2 10mm bolts)
undue all the jubilee clamps on the airbox (back of carbs)
undue all the jubilee clamps on the inlets (front of carbs)
open the carbs with your hand (sounds complicated - move the throttle) unclip the push cable
with the carbs closed you should be able to release the 2nd throttle cable now...
take the choke cable off
push down on all the carbs - they will come off with a "pop"
careful which way you hold them as some fuel may come out
now use pete's guide on how to clean em - which funnily enough is on Bandit carbs
first time it took me about an hour to get the carbs off - an im an oaf[/url]
Moxey
PostPosted: 11:42 - 16 Jun 2014    Post subject: Reply with quote
Got your PM unfortunately I'm quite busy at present trying to sort my own stuff otherwise would have offered a hand.
What Mudcow suggests is pretty much spot on, I've done the rig ma role of carbs on and off Bandit 600's too many times they really are temperamental.
First suggestion is as others, give the carbs a clean following the removal method, be careful with the float bowl cross head screws, many a time these get chewed up by some moron and re-used rather than replaced, make sure you have a good nick posi screw driver and consider some plus gas penetrating oil before attempting them.
Whilst your in there cleaning the carbs you may as well check the float heights too (should be 17.00 + 1.00 mm) but you'll need a feeler gauge for that. (little vid of how to do that check once you have the float bowl off in case you don't know how https://www.youtube.com/watch?v=Rj52oUY7ISc).
The last post was made 11 years, 254 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.78 - MySQL Queries: 16 - Page Size: 82.08 Kb
