De-restricting a Honda Hornet CB600 2007?
bikertomm
PostPosted: 21:59 - 12 Jul 2014    Post subject: De-restricting a Honda Hornet CB600 2007? Reply with quote
Hi all,
I have a Honda Hornet 07' that has been restricted since I bought it to 33BHP.
Soon enough, I will legally be able to take this off. Been waiting for this day for 5 years now... Drooling
All I really know is that It's a throttle stop restriction - I have limited movement on the throttle - Is that literally it?
I wanted to find out some more info, if anyone has ever come across taking one off before on a Hornet?
So far what I've found is that the tank needs to come off and I quote;
'you need to lift tank, disconnect the throttle cables and unscrew the metal plate then take it off and put the cables back on. Bit of a ball ache as space is tight.'
A plate on the side of a throttle body.
I think this may well be too much for myself (Jivebunny skillz yo) but if I can at least get an idea I can take it to someone and provide some insight! Laughing
Unless anyone capable wants some money? Laughing
Cheers lads. Thumbs Up
gavbriggs
PostPosted: 22:02 - 12 Jul 2014    Post subject: Reply with quote
Where abouts are you, maybe someone close could take a peak
Recent bikes: Varadero 125 - Mod 2 3/2/14 - Bandit 1200 SK4
bikertomm
PostPosted: 22:18 - 12 Jul 2014    Post subject: Reply with quote
South Bucks buddy,
Cheers.
Shaft
PostPosted: 23:05 - 12 Jul 2014    Post subject: Reply with quote
It's probably not that difficult, the hard part (as mentioned) will be access, because it's going to be fiddly little nuts, buried somewhere that's just out of reach, probably hard up against some other component so it only comes out a certain way.
Take the tank off, get a good torch and post some quality pictures, I bet you can be talked through it.
gavcarter
PostPosted: 23:38 - 12 Jul 2014    Post subject: Reply with quote
Tank off, then air box off.
Remove the carb / throttle body from the rubbers ( leave the rubbers on the engine)
You should see big washers similar to these
https://i14.photobucket.com/albums/a324/david_m213/zzrrestriction.jpg
Yank em out.......
Not literally you'll damage the rubbers, probably have to undo the rubbers from engine and take them out of then put rubbers back
After having a good google at new kits for the 07 hornet - i do not believe the jetting is changed when fitted so that should be job done.
Carb back, air box back on, tank back on - new undies first time you forget and "launch" off the lights Wink
PostPosted: 23:44 - 12 Jul 2014    Post subject: Reply with quote
Those washer aren't throttle stops. Laughing
The throttle stop that was on my 33bhp TL1000R was a part that was changed so the original part was needed for derestricting it.
Do you know if it's an FI International kit or something else? If it's FI International then you might be able to find the fitting instructions somewhere online. The place I got mine fitted gave me the standard part back and the fitting instructions.
Shaft
OP thinks it's a throttle stop restriction, not constrictor washers.
gavcarter
PostPosted: 23:49 - 12 Jul 2014    Post subject: Reply with quote
I read it as "plates inside the throttle body", so thought he meant restriction washers Embarassed
never mind Whistle
PostPosted: 00:34 - 13 Jul 2014    Post subject: Reply with quote
Have fun. That Hornet is a cunt stick to work on. Thumbs Up
Shaft
PostPosted: 00:43 - 13 Jul 2014    Post subject: Reply with quote
How hard can it be Shocked
PostPosted: 00:56 - 13 Jul 2014    Post subject: Reply with quote
Under the tank is absolutely everything... genuinely.
No room to move or anything Thumbs Down
Shaft
PostPosted: 01:01 - 13 Jul 2014    Post subject: Reply with quote
Sounds like a typical modern bike to me.
I'd have a go at fixing the OP's Hornet, but only if he brings it to me, so I've got every tool available.
TUG
PostPosted: 01:31 - 13 Jul 2014    Post subject: Reply with quote
Paddy is correct, the older ones where a nightmare to restrict!
Haz ER-5, innit!
bikertomm
PostPosted: 10:17 - 13 Jul 2014    Post subject: Reply with quote
Ste, yes it is an FI international one, I have the certificate etc from the previous owner.
I tried Emailing FI international but not a response. Don't think they are interested unless they are making money..
Thanks for inspiring confidence Paddy Laughing
And thanks for the offer Shaft.
I spoke to a local mechanic and he seemed to know the deal, he reckoned a couple hours labour and around £100.
We shall see, keep the tips coming!!
Cheers Thumbs Up
talkToTheHat
PostPosted: 00:59 - 16 Jul 2014    Post subject: Reply with quote
Fi are no more. They are now part of BLD group.
Bandit. does. everything.
PostPosted: 01:36 - 16 Jul 2014    Post subject: Reply with quote
Bleh, the money grabbing whores have been absorbed/bought out by even worse money grabbing whores. Bleh! Sick
I repeat... bleh!!! Sick Sick
bladerunner
PostPosted: 09:52 - 16 Jul 2014    Post subject: Reply with quote
Honda would supply a restriction kit if bought new....and they would give you the std full power option parts....with the Honda kit it was the same idea of restriction washers on the inlet rubbers...however you just changed the whole inlet rubbers for the unrestricted items! That's a pretty simple job on the hornet tbh.....interestingly Honda also supplied a different CDI for the restriction kit along with different key .......I'd guess the restriction kit you've got fitted should be a removable stop on the throttle body which has got to be a 15 min job to remove!
Conzar
PostPosted: 09:57 - 16 Jul 2014    Post subject: Reply with quote
Open up the throttle assembly and see if anything is there
Current ride: ZX6R 636 ------- Previous:KTM EXC 450 Supermoto --- ZX6R B1H --Hornet 600--CBR 600--SV650
11:05:35 Rob Fzs: i just wanna own an rd350 valve before they send us to war with durkadurkastan
Conzar
PostPosted: 09:59 - 16 Jul 2014    Post subject: Reply with quote
FI bikes are restricted by throttle stop or ECU
PostPosted: 10:01 - 16 Jul 2014    Post subject: Reply with quote
You would guess.
However, lift the tank, remove half the wiring loom, pipes and a lot more, just to remove the airbox.
Then remove all the remaining guff to access the TB's.
I would say, DIY, easily over an hour. I derestricted a GSXR750WN in 10 minutes... Laughing So the Hornet is up there in my "fuck that" job list.
PostPosted: 10:04 - 16 Jul 2014    Post subject: Reply with quote
Expect when they're restricted by washers. Wink
talkToTheHat
PostPosted: 18:02 - 20 Jul 2014    Post subject: Reply with quote
Indeed FI kits can be intake washers, throttle stops and exhaust washers (rare), or (very rarely) a combination of intake washers and throttle stop
TUG
PostPosted: 18:52 - 20 Jul 2014    Post subject: Reply with quote
Don't forget on the Yamaha R6 5EB they can also be washers in the intake and spacers in the diaphragm slides! Wink
Haz ER-5, innit!
bikertomm
PostPosted: 23:58 - 23 Jul 2014    Post subject: Reply with quote
FFS Paddy I bet this turns out you are right and there will be plenty of effin' and blinding on the day.
Will try to make sure I get a price before hand, incase it turns into a 4+ hour jobby..
2 and a bit months Mr. Green
Will update this Thumbs Up
The last post was made 11 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.76 - MySQL Queries: 16 - Page Size: 137.48 Kb
