125cc Supermoto - 2 Stroke goodness
Bike Chat Forums Index -> General Bike Pictures Goto page Previous  1, 2, 3, 4 ... 13, 14, 15  Next
stevo as b4
PostPosted: 10:53 - 03 Aug 2014    Post subject: Reply with quote
It's got my vote for project of the year 2014! Thumbs Up
Do you reckon with that frame and suspension, it will eclipse the TZR pit bike you had for it's level of awesomeness?
Oh and the MX125 pipe will look a million times better than the AF1 pipe too! Don't junk the old pipe though in case you ever start a 125cc road bike project!
binge
Emo Kiddy
PostPosted: 11:19 - 03 Aug 2014    Post subject: Reply with quote
Cheers!
With the TZR, I was young when I built it. Fairly un-skilled compared to now, and the bike never ran quite right because of that.
I cut corners on things like an inlet manifold, and nut/bolting everything, rather than welding.
After I broke the TZR for parts, I used to talk about building another 2/ pitty, but the grueling work I put into the TZR always put me off.
I'm so glad the Rotax 123 cropped up on ebay so cheap though, because it's been a really smooth project this time. Having the MIG welder and a far better tool kit, has made it so much easier to do.
Handling wise, I can not say yet, as it really is a Frankenstein build. The frame was meant to have longer forks and swing arm, along with 17" wheels.
The TZR build, was all on a modified KLX110 (Pit bike) Chassis, with Pit bike swing arm, KTM65 forks, and 12" pit bike wheels.
The Rotax build is on the Malaguti frame, with the KLX110 pitty subframe fitted to it.
Pit bike forks, GSXR600 yokes (Modified by Pete), a pit bike swing arm, And 13" Aprilia SR125 wheels. Laughing
Oh, and a Ducati rear shock!
I've bought a pack of spacers with an ID of 30mm, as the stem bolt is too long for the frame.
I can swap the spacers to the bottom, or top of the stem bolt (On the outside of the bearings), to move the frame, up and down, between the yokes. This will really help out with the set up of the frame, as there isnt much movement with the fork legs in the yokes, they're already right at the top and the front end could do with coming up a bit.
At the moment, with no headstock spacers fitted, the frame is obvs sitting on the bottom yoke, I've got about 15mm of gap to play with, so can stick all the spacers underneath to start with, and see how it sits.
Rear shock is adjustable massively too! And there are multiple top mount holes, I can move the angle of the shock too.
And if that is not enough, the bottom mount actually unbolts from the swing arm, so I can spacer that out too!
My main concern is the wheels.
They are insanely wide! 3.5j front and rear.
The tried and tested widths on a pit bike, are 2.5j rear, and 2.15j front.
That said, there has never been a pit bike I know of, on 13" wheels.
Need to decide on some tyres, I'm warming towards the Michelins as they are dual compound.
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-xap1/v/t1.0-9/p526x296/10557188_10152578686660606_4180090319221026438_n.jpg?oh=5ad7fc9b67b84bfd1838e061717bdfb8&oe=54446291&__gda__=1413593130_2d0fdf60db73c08f4b69295a5749795c
Time will tell I guess, it'll no be finished fully for a long long time. Things will need to be changed and tweaked along the way.
- Honda XL125S - CBR400 NC29 - VFR400 NC30 - CBR400 NC29 - TL1000R - TeeZeR Pit! - Bandit 12 - YZF450 - LuckyMX125 Pit! - Demon X XLR 140 Pit!
- Stomp KZ 160 Pit! - Demon X D-link 140 Pit! - CRF50F Mini-Pit - MonsterMoto 155cc MiniSM - Honda Chaly 150cc - Yamaha 98' R1
- Honda Chaly 140cc - Thumpstar 190cc 4v MiniSM - Aprilia RS125 Pit-Bike -
binge
Emo Kiddy
PostPosted: 21:28 - 12 Aug 2014    Post subject: Reply with quote
Got myself a spanny
https://scontent-a-lhr.xx.fbcdn.net/hphotos-xpa1/t1.0-9/10530743_10152603160365606_6685145783575226573_n.jpg
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-xpf1/v/t1.0-9/10369896_10152603160940606_1675453376115403210_n.jpg?oh=1c52ed5d7de287985d8c3e5ac402efbf&oe=54757D69&__gda__=1415967766_8cb50bf238c6c498ade571c4b0769442
P.
PostPosted: 21:31 - 12 Aug 2014    Post subject: Reply with quote
This thing is sick! Let me know when it is running, I need to see this Drooling
Whosthedaddy
PostPosted: 17:15 - 16 Aug 2014    Post subject: Reply with quote
What wheels are you running?
MattWadz
PostPosted: 20:12 - 16 Aug 2014    Post subject: Reply with quote
That expansion chamber looks over 9000 times better than the other one!
Pitbike x2, Mini Moto x4, China Quad, 02' Suzuki AP50 > 03' MBK Nitro > 86' Suzuki GP100 > 02' Yamaha Jog R > 57' Honda Lead 100 > 95' Piaggio ZIP Rst 50 > 51' Suzuki TS50x > 83' Honda CB125TDE Twin > 51' Yamaha Aerox > 98' Kawasaki KX60 > 89' Yamaha DT50MX > 80's Honda QR50 > 05' CG clone > 125cc China Pitbike > 91' Honda MTX125 RW-L > 09' Peugeot Speedfight 2 LC LR > Lucky MX 140cc > Apache Tomahawk 50 Quad (current = 2010 Yamaha WR125R
1cyl
PostPosted: 22:38 - 16 Aug 2014    Post subject: Reply with quote
+1.
Its not the segmented expansion I was hoping for, but it still looks just fine so you can have some more Karma as promised.
She's really coming together nicely, good effort OP Thumbs Up .
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
binge
Emo Kiddy
PostPosted: 20:25 - 17 Aug 2014    Post subject: Reply with quote
The wheels are a pair of front wheels, from an Aprilia SR125 (Scooter) with a billet sprocket holder welded to the rear.
Exhaust is great, fits really well, segmented one would have been nice, but the extra £££ made it hard to justify.
stevo as b4
PostPosted: 20:20 - 18 Aug 2014    Post subject: Reply with quote
Sorry to off topic, but a don't rate a segmented 50cones all welded together pipe any more than a very good pressed steel sections pipe like the MX125 has. That pipe is so smoothly shaped and I bet it works very well!
I'm sure it could be powdercoated, ceramic coated or plated if you wanted more bling,
binge
Emo Kiddy
PostPosted: 20:38 - 18 Aug 2014    Post subject: Reply with quote
The guy I bought it from said it's been de-restricted, and ran very nicely on his bike. So hopefully it'll be alright.
Had a poke around with the bike today. Fitted some stem bolt spacers to the bottom of the stem, under the lower bearing, so it's brought the front end up just over 1/4".
Also packed the axles out properly, so the wheels are central etc. Just need to get the washer packs converted into ally wheel spacers now. Smile
Next thing for the list is going to be some tyres, and to fit a front brake up.
After that, electrics, and hopefully it'll run.
https://scontent-b-lhr.xx.fbcdn.net/hphotos-xfp1/t1.0-9/q84/s720x720/10610837_10152616831350606_6625753169556539889_n.jpg
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-xfa1/t1.0-9/p843x403/10603321_10152616831440606_9116322097182379400_n.jpg
BenR
PostPosted: 21:09 - 18 Aug 2014    Post subject: Reply with quote
I would suggest fitting some tyres before riding. Wink
binge
Emo Kiddy
PostPosted: 20:34 - 06 Oct 2014    Post subject: Reply with quote
Had the MIG out today, got a little bit done to the bike as I am sick of it sat in the garage doing nothing.
Made up a link pipe to fit the end can, and also made a calculated dent in the spanny to clear the oil pump cover. Assuming a 122 Rotax engine either has a different oil pump cover, or a different manifold for the exhaust. Either that, or the spanny just sits FUCKING close on the MX125.
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-xpa1/v/t1.0-9/p600x600/1453383_10152736651280606_129226162505868019_n.jpg?oh=0178340ca453cf1d6b31a8ba8776a798&oe=54CCA74D&__gda__=1420484011_99f4b1ae24f29f6ae0c56d196a96556e
https://scontent-b-lhr.xx.fbcdn.net/hphotos-xpf1/v/t1.0-9/p600x600/10523974_10152736629845606_2339914110872330052_n.jpg?oh=13f75a483cb3d3fab282d3f79410dd24&oe=54D03062
sulphur
PostPosted: 22:54 - 06 Oct 2014    Post subject: Reply with quote
I genuinely can't wait to see the finished product, and watch the vid to hear/see it go. Muchos kudos on the build, it looks awesome. Thumbs Up
binge
Emo Kiddy
PostPosted: 13:56 - 07 Oct 2014    Post subject: Reply with quote
Picked up a block of ally round bar today. Got a 240mm front disc coming for it and going to get my Grandad to turn an adapter plate to run a 5 bolt disc on the 3 bolt wheel. Will stop on a 6pence with the KTM Brembo caliper and NC29 master cylinder. Smile
binge
Emo Kiddy
PostPosted: 14:00 - 07 Oct 2014    Post subject: Reply with quote
P.
PostPosted: 17:03 - 07 Oct 2014    Post subject: Reply with quote
You have a MIG now? Any details as I reckon I could do with learning how to do this sort of stuff... that and I have some bits I need welding Laughing
binge
Emo Kiddy
PostPosted: 21:19 - 07 Oct 2014    Post subject: Reply with quote
I've had it quite a while Paddy. I'm not great with it, but I just grind all my welds back with a flappy disc to make it look neat.
As long as there is a decent Heat-affected-area then it'll be a strong enough weld. (I hope!) Laughing
Today I got a bit more done. Stripped engine back out of frame, welded up all the mounts I need etc.
While messing around with the swing arm and pivot bolt, I noticed that the chain is going to be running a little closer than I'd like to the frame. So I opened up the frame rails by about 10mm using a length of threaded bar and 2 nuts. Then welded in a brace to hold it.
Added bonus is I can now weld 2 lugs to said brace, and it'll be a 3rd engine mount for the lower engine mounting point.
https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-xpf1/v/t1.0-9/10469414_10152739816720606_5163630677070877727_n.jpg?oh=143abbba53fbc85ceea321511862685f&oe=54B28D17&__gda__=1421768040_48926aa7f0fea89a8fc53b39e301a832
binge
Emo Kiddy
PostPosted: 19:41 - 08 Oct 2014    Post subject: Reply with quote
Bargain of the year. Just won these for £5 Razz
Proper Aprilia RX125 rads, so perfect for the Rotax engine, and perfect for my bike as it's of an MX / Supermoto style. They will fit nicely behind the tank shrouds I hope.
https://i.ebayimg.com/00/s/MTIwMFgxNjAw/z/quYAAOSwDk5UFFVb/$_57.JPG
binge
Emo Kiddy
PostPosted: 19:19 - 10 Oct 2014    Post subject: Reply with quote
Set of plastics arrived today, so fitted up the remaining 3 graphics, and fitted them up to the bike.
Also bought a proper axle for the rear wheel, and a high tensile spindle for the swing arm, all fitted and spaced up nicely. PLENTY of sprocket/chain clearance now too. Smile
Slight issue / school boy error. While fitting up the exhaust, I didn't have the shock fitted. Res fouls stinger pipe. DOH! Rolling Eyes
Rather than sacrifice my Ducatti shock for some Chinese piece of crap, I think I will just start again with the exhaust end can/stinger to make it fit around the shock.
https://scontent-b-lhr.xx.fbcdn.net/hphotos-xap1/v/t1.0-9/10392429_10152748507670606_7689195393682294462_n.jpg?oh=f64b100bf10c84a423d77d648bde0f63&oe=54B3DB7F
Tomorrow I will mostly be welding the frame some more, removing any more bits that are not needed, and just double-double checking everything before it goes off for powder coating.
binge
Emo Kiddy
PostPosted: 20:47 - 13 Oct 2014    Post subject: Reply with quote
Rads have arrived. They look awesome. Going to fit them up tomorrow with some weld on brackets. And once they're done, I do think it's time to get the frame and wheels powder coated. Razz
Eddie Hitler
PostPosted: 21:13 - 13 Oct 2014    Post subject: Reply with quote
Piss?
https://i.imgur.com/Hz0Ew9d.jpg
binge
Emo Kiddy
PostPosted: 21:22 - 13 Oct 2014    Post subject: Reply with quote
If you piss that colour you need checking out bro.
Eddie Hitler
PostPosted: 21:25 - 13 Oct 2014    Post subject: Reply with quote
Will you check me out bro?
binge
Emo Kiddy
PostPosted: 21:32 - 13 Oct 2014    Post subject: Reply with quote
No but I am sure Titz will if you ask him.
Eddie Hitler
PostPosted: 21:44 - 13 Oct 2014    Post subject: Reply with quote
No Love rating when you need it. Projects looking sweet. Thumbs Up .
The last post was made 9 years, 200 days ago. Instead of replying here, would creating a new thread be more useful?
Page 3 of 15
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.74 - MySQL Queries: 17 - Page Size: 156.04 Kb
